Question about Bush DVD142RC 14 in. TV/DVD Combo
DVD1402TVP The DVD loads but says wrong disc. Can anyone help. Jim
  • 1 more comment
  • Suelt Dec 30, 2007
    I have the same problem with it saying wrong disc. I have used a cleaner, but that hasn't helped. Any other solutions? Please! I have only had this TV for two months.
  • barbienight Jan 26, 2008
    I have the same problem , wrong disk  is shown on the screen , its a new tv./dvd combo and Ive tried brand new dvds in it ,old ones etc... nothing works .. then suddenly one worked , and another then nothing again .... just wrong disk comes up on screen .
  • terrortot Mar 26, 2008
    We have had our for about 2 months and are having the same problem..Tried a dvd cleaner still the same problem...Any ideas.
Buy one cdclener and insertion your DVD tray agay now
Posted on Jul 22, 2007
SOURCE:
My dvd player has just stopped playing disc's? I insert a disc, it loads up as the little circle comes up, saying loading. Then it says bad disc.It stops. Does anyone know what could be wrong here?
Couple things could be. I've found : the disc can be dirty, wipe it off. Or if its damaged the lens won't read it.
What usually helps the most is to put a lens cleaner in the player. they sell them. I only have a CD cleaner ( prob called lens cleaner). It still fixes it for me.
Jul 20, 2015 | Televison & Video
Disc won't load. Get
there a problem of the DVD disc...
try to insert another disc..
if "wrong disc" message appear again...
insert the Disc Cleaner of the DVD.. so that you can clean the lens surface of the DVD Player...
Oct 23, 2009 | Televison & Video
Disc not reading. toshiba dr420 dvd recorder.
Multiple problems with the DVD recorder one of them could be the lasers not reading correctly its software is messed up or there something wrong with this but to me it sounds more like the DVD recorder has a problem I've experienced this problem before not with this particular type of DVD recorder I fix the problem by unplugging the DVD player for about 20 seconds to a minute to give it a good reset.
Quick tip: most high Tech Device problems or unknown errors can be fixed by simple restart or reset hope this helps
Jul 28, 2009 | Toshiba DR420 DVD Recorder
I've had a DVD player for some time now. I borrow films from LoveFilm on line. Just recently some of the discs - ''Quantum of Solace'' for instance - won't load. After trying for about a minute, I get a...
try a DVD disc cleaner. This cleaner looks just like a disc with some extra little brushes on its surface. Some DVD cleaner kits even come with supplies to clean and modify scratches on your discs.
if this helps please leave a fixya ratinf as this is how we get paid
Apr 26, 2009 | Televison & Video
Wrong Disc
It is a bad data cable from the dvd head to the main board
Feb 14, 2008 | Coby TF-DVD7005 Portable DVD Player
Toshiba dvd player - SD-1200
Its actually in the troubleshooting manual. Pg 126. Try putting in the disk with the label face up, that might work too,
regards
Jim
Dec 22, 2007 | Toshiba SD-1200 DVD Player
LG RH177 DVD recorder
same here but cant find a place to buy a new dvd drive any one help me
Oct 18, 2007 | LG RH177 DVD Recorder/HDD Recorder
Wrong disc displayed
try to find crack for region code and set it up to be region free. that should do the trick.
Aug 14, 2007 | Yahoo Diamond Vision DVDC803-04 DVD Player
Portable DVD player not spinning says no disc
Check to see if the disc is spinning. You can do this by one of two ways either
  • a:) Listen for the disc to spin after inserting it or
  • b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
Hope this helps
Feb 02, 2007 | Centrios EDW8020 DVD Recorder
Bush DVD142RC 14 in. TV/DVD Combo Logo
99 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
