Home | Sharp | AL-1661CS All-In-One Laser Printer | Cant get scanner or fax...
Sharp AL-1661CS All-In-One Laser Printer
Problem for Sharp AL-1661CS All-In-One Laser Printer
Cant get scanner or fax to work in all in one
By sbruce709 on Jan 27, 2009
Hi we have an extened warranty on out Sharp 16661 all in one. We moved office's and now we can get the scanner or fax to work. The photo copier and the printer works
Solution #1
posted on Aug 05, 2009
Not Rated)
russel23
Rank: Wiz  Sharp Expert
Rating: 82%, 14 votes
1st u install the drivers n for fax check ur tel line
Was this helpful?
Yes
No
Solution #2
posted on May 15, 2009
Not Rated)
tehnik_bdg
Rank: Guru  Sharp Expert
Rating: 88%, 35 votes
Remove the printer/scanner driver and reinstall the driver. Be sure to unplug the usb connector while installing. After the installation step ask you to connect the usb or after restart, plug the usb
Was this helpful?
Yes
No
Popular Solutions for Sharp AL-1661CS All-In-One
Questions and Unsolved Problems for Sharp AL-1661CS All-In-One
Do you recommend Sharp AL-1661CS All-In-One Laser Printer?
Answer
Answer
tried clear exposure clear, but cant get into the simulation mode to reset a fuser code...
Answer
I have reviewed a previous solution you gave regarding reseting the drum counter on my printer. Your... (More)
Answer
I have replaced the drum but do not know how to reset the counter I don't understand the interrupt,... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AL-1661CS All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 1506
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
