Question about Maytag Dishwashers
LWC284 Need new faucet adaptor
Faucet connection not fitting
This Faucet Kit AM is available that can solve almost all connections. If you are connecting to a garden faucet, then Faucet Adaptor Kit Garden Connection AM or Kit Faucet Adaptor Course to Fine Thread AM works great.
If you have an issue where you don't have threads, then Kit Faucet Adaptor Internal Expansion AM or Quick Disconnect Adaptor AM works well.
RainVac
Jun 29, 2014 | Rainbow E series Canister Wet/Dry Vacuum
How do you hook up to the faust
This is an old machine. It comes with all the adaptors to hook the 1/4" water line to the faucet. You need to remove the arator from the faucet to hook it up and use the adaptors to match your faucet.
May 17, 2014 | Bissell 1631 PowerSteamer ProHeat Canister...
Leaking washing machine faucet adapter
fit the rubber washer into the adaptor that seals off on the tap face
can be obtained from any garden tap fitting
Jan 24, 2018 | Washing Machines
I need the hose adaptor that is attached to the
try AppliancePartsPro.com You will need your make / model #
Feb 26, 2010 | Dishwashers
How do I remove moen hydrolock adaptor
I NEED TO TAKE FAUCET OFF TO INSTALL GASKET ON THE BOTTOM. BUT I CAN'T GET THE HYDROLOCK OFF.
Feb 22, 2010 | Moen 87530 Touch Control Single Handle...
Faucet solution for hooking up portable dishwasher
there is a generic adaptor that fits on your faucet; take the name, model# and, hose to a hardware store and, they can show you the right adaptor for your machine
Sep 15, 2009 | Dishwashers
I have a portable ''GE quiet power'' portable dishwasher and the hose won't fit on my new faucet - is there some sort of adaptor I can buy for the sink so it will fit properly?
Yes, you need to know whether your faucet is male or female thread (threads on outside or inside) and buy an adapter that will fit into the faucet where the aerator normally sits. These are generally available in the plumbing section of your local hardware store. Make sure you know your diameters as well (O.D. stands for Outside Diameter and is usually male thread where as I.D. stands for Inside Diameter and is usually female thread)
Jul 03, 2009 | GE Dishwashers
Clarify application of straight ball valve 1/4 turn
The ballvalve is normally a compression type fitting and so would not normally require soldering, however you could use a threaded adaptor soldered to the copper supply line and then thread a 1/2" ball valve to that then reduce down to the correct thread to meet the tails from your new tap. Or alternativeley you can insert the valve in the supply line, and extend the pipe to nearer the sink to enable easier connection of the tap.
Nick
Mar 28, 2009 | Plumbing
Faucet Adapter included doesn't fit my faucet
avanti is on a metric system and depending on where you are you might not be on metric thats why they don't fit,, one has a fine thread the other is course, you will need ot go to an actual plumbing supply house, they have the converson fittings,, don't waste your time at home depot
Aug 10, 2008 | Avanti W798SS Stainless Steel
Dishwashers Logo
128 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
