Question about Nautilus Sport Series T518 LEX Treadmill
Error 1 on a Nautilus sport series T518
Treadmill stops and the error message appears
3 Suggested Answers
  • 64 Answers
SOURCE: I have a Nautilus Bowflex 5 series treadmill.
I will have to check the error code but sounds like a heat problem. When you get too much friction between the walk belt and the deck it builds a lot of heat which creates more drag on the motor. This causes the motor to overheat which in turn usually shuts the machine off. You can let it cool and go back exercising until the cycle repeats. If this sounds like your issue, try lubricating the walking belt. If it's not in bad shape it should make a difference. The machine should run longer. 10-15 is pretty quick though so it make take a couple of application of lubricant. The belt may need replacing if the need for lubricant becomes too regular.
Posted on Nov 17, 2009
Daniel S
  • 4323 Answers
SOURCE: Our Nautilus T514 treadmill stops
Hi
Try clearing the error by unplugging the treadmil. if it doesn't clear then try and press stop button for 10 seconds. Insure cable is connected securely to Console. All wires in cable should be intact. If any are cut or crimped, replace cable. If error doesn't go then lubricate the treadmill as given in this manual---
Nautilus Treadmill 514 Manual
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 04, 2010
Can I find service in Europe
Customer Care Number: +1-800-628-8458, +1-800-605-3369
See More Detail Email Address: csnls@nautilus.com
Contact Person:
Address: 17750 Southeast 6th Way Vancouver, Washington 98683, United States
Website: www.nautilusinc.com
Contact Nautilus Inc
Nov 02, 2015 | Nautilus T914 Commercial Series Treadmill
PLO5 error message on Quinton Clubtrack treadmill
Try to clear the error message. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Jan 25, 2013 | Quinton Stairmaster Clubtrack 3.0 GymTough...
System overload
Step 1:
see the video and lube the rollers bearings too
Step 2:
test the input voltage motor, if there are the motor need repair
see the diagram attached.
Step 3:
test the output voltage board, for input voltage motor, if there are NOT the board is faulty,replace
see the block diagram
Jan 09, 2013 | Nautilus T914 Commercial Series Treadmill
T916 treadmill gives me an system overload error
Dear Sir:
In all case this error indicate tha lack of maintenance, specially lubricanting in Deck vs Belt DECK, do oit. By that reason the machine will Shut down for to prevent the electronic system, in order to preserve the electronic component.
see my personal TIPS for diagnose and trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Mar 06, 2012 | Nautilus Commercial Series T916 Treadmill
Nautilus tc5000 treadclimber has e5 error. Will run for 5 seconds, then stops. Thanks
The E5 error code indicates the electronics on your treadmill require calibration. Recalibrate the machine per the instructions in your manual to clear this error code.
Apr 25, 2011 | Sport & Outdoor - Others
E1 not ERR1 error appears on the display of diamond t300 york fitness treadmill??
Your problem might be that a magnet has fallen off. Here's an illustrated guide that will make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jul 04, 2010 | York Yankees Bedding MLB Comforter
T518 keeps shutting off
Did anyone address the issue of lubrication for the unit since the increase of friction will overheat components thus causing the unit to shut down.
May 10, 2010 | Nautilus Sport 5.18 LC Treadmill - Huge...
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
I have four Treadmills of Stairmaster(clubtrack510), when I try to start the machine the error (1)ERROR CODE EPLO & (2)ERROR CODE E211 message I am getting please kindly help me how to over come these...
I will start from your Question 2 than Question 1 :)
Now,
Error 211 - Clear the error by pressing Power or Clear. Attempt to operate the treadmill again. If error persists, replace VSD or grade motor. Belt and display may continue to be used during Fault conditions by pressing Clear.
Error EPLO - It refers to an electrical problem or might be a Blown Fuse.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 27, 2009 | RTO Stairmaster Clubtrack 510 Treadmill
Nautilus Sport Series T518 LEX Treadmill Logo
53 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
