Question about Sharp VL-Z5 Mini DV Digital Camcorder
Camcorder shows dew all the time - Sharp VL-Z5 Mini DV Digital Camcorder
    Sergeant:
  • 250 Answers
Http://ataplow.googlepages.com/sharp-dew-problem just click this link read the instructions carefully and follow them properly to resolve this problem. thanks.
Posted on Jan 27, 2009
Bypassing of DEW sensor
there is no way to bypass it, but simple modification is available to correct this problem. contact any sharp authorized repair center.
Sep 13, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
"Dew" sitting on my Video Camera
Dew Formation
What is “dew formation”?
When cold water is poured into a glass,
dew drops form on the glass. This clinging
of water drops is called dew formation.
When dew forms in your camcorder.
Dew will gradually form on the head drum
of your camcorder and make the video
tape stick to the head. This causes
damage both to the head and the tape.
When dew forms, recording and playback
may not function properly.
Dew is likely to form in the following
circumstances:
—When moving the camcorder from a
cold place to a warm place.
—When placing the camcorder in a cold
room which is then heated rapidly.
—When moving the camcorder outdoors
from an air conditioned room or car.
—When placing the camcorder in the
direct path of air
blowing from an air
conditioner.
—When placing the
camcorder in a
humid room.
How to prevent trouble.
When using the camcorder in a place
where dew is likely to form, allow the
camcorder and the video tape to
acclimate to the surroundings for about
one hour.
For example, when bringing the
camcorder indoors after skiing, place it in
a plastic bag.
1Be sure to tightly seal the plastic bag
containing the camcorder.
2Remove the bag when the air temperature
inside it reaches the temperature
of the room.
“Dew” warning feature
If dew forms, the word “DEW” flashes on
the screen, and the power will automatically
turn off in approximately 10 seconds.
Plastic bag
1If “DEW” flashes, remove the cassette,
leave the cassette compartment open,
and wait for a few hours to allow the
camcorder to acclimate to the
surrounding temperature.
2To use the camcorder again, turn on the
power after waiting for a few hours. Be
sure that “DEW” has disappeared.
3Do not insert a cassette while “DEW” is
flashing; this may result in damage to
the tape.
4Since dew forms gradually, it may take
10 to 15 minutes before the dew
warning feature engages.
Mar 13, 2009 | Sharp Viewcam VL-Z5U Mini DV Digital...
Hello...
xiii
Dew Formation
circumstances:
direct path of air
blowing from an air
conditioner.
—When placing the
camcorder in a
humid room.
one hour.
a plastic bag.
of the room.
Plastic bag
the tape.
Oct 22, 2008 | Sharp Viewcam VL-Z7U Mini DV Digital...
Camcoder
There have been several compaints about this dew issue. I recommend calling Sharp.
Support: (800) 237-4277
May 03, 2008 | Sharp Viewcam VL-Z7U Mini DV Digital...
Flashing "DEW" Indicator shutting down the viewcam
I don't know if this will help, but when I leave the camera open with no tape in it for a day or so, "dew" goes away. Now I just store it open without a tape in it and have never had this problem again.
Hope this helps.
Feb 26, 2008 | Sharp Viewcam VL-Z7U Mini DV Digital...
Dew
I had this same problem, and believe it or not, it is very simple to fix.
The fault is a dry joint on the dew sensor circuit.
This can be fixed permanently with a soldering iron, or if you don't want to kill the camcorder you can do a temporary fix each time the message occurs.
If you remove the tape and look down inside the camcorder, towards the front, next to a green circuit board, you will see two small blobs of solder with a wire running from each.
The image below shows the most likely position that needs either soldered or pushing in with a screwdriver or other fine metal device. You can remove the batteries first, for extra safety.061fb70.jpg
Dec 18, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Dew
Model: VL-Z800 Sharp ViewcamZ
I was in Shanghai in Dec 2008 over Christmas and I experienced the 'DEW' problem. The cassette tape door would not close either. I did not experience this before even after 2 years. I suppose the cold & the rain water causes the dew to accumulate in the CAM.
Solution.
I did the reset by taking out the small tiny battery situated just above the big battery. The small battery has a cover. Pull it up & Get the small battery out and the whole camera resets. Re-entering the date & time is the only inconvenience. After reseting, I could use it again, but not for long as the problem comes back. When I came back to Malaysia (Temp 32-34 degrees celsius), the DEW problem disappappers.
You could also try this method to get rid of the dew. Buy a small sack of rice. Yes rice, the uncooked ones. Cut open a small opening just big enough to put your CamCorder into the sack. If you do not want to get your CAM dirty, wrap the CAM with tissue paper. Close the opening with a musking tape and leave it a few days. The dew should disappear from the CAM. It works for mobile phones too when it is accidentally drop into water. Of cause you should not switch on the mobile when it is still wet. It will self distruct if you do. Try the rice solution for a week before you on your mobile.
Rgds/ T.S
Dec 17, 2007 | Sharp Viewcam VL-Z1U Mini DV Digital...
DEW indicator / battery
In your owners manual on page 52 you will find a list of authorized service centers. Give the one in your area a call. Give them the brand name and model number of the camcorder. Tell them you are having a problem with the dew warning coming on while using the camera with the battery. They should be able to help find a answer to this problem.You can also call the panasonic customer support telephone number at 1-800-211-7262 between the hours of 9am-7pm EST. Give them the brand name and model number of the camcorder and ask them for help with the problem of dew indicator coming on while in use with the battery. I hope this information helps you with your camcorder problem.
Nov 20, 2007 | Quasar VM-L450 Camcorder
Closing itself down DEW
camcorder when turned on flashes in red DEW and closes it self down. i have taken all the batteries out and replaced sometimes after a few days the camcorder will work then DEW will rea ppear and shut itself down
Nov 02, 2007 | Sony HDR-HC1 Mini DV Digital Camcorder
Sharp VL-Z5 Mini DV Digital Camcorder Logo
464 people viewed this question
Top Sharp Video Cameras Experts
noel
noel
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
