Question about Philips 55P8241 55" Rear Projection Television
Big Screen TV won't turn off
When I turn my television on, the tv works fine, able to change the channel and the volume. After about 30 mins, I can not turn the television off or lower/raise the volume or change the channel-neither with the remote or using the controls on the tv. I have to unplug the tv for it to turn off.
  • Anonymous Sep 21, 2008
    the same
  • Anonymous Feb 15, 2009
    I have this same issue and I am ticked. I cannot get my television to come back on. Please help.
Another method you may want to try is to take the remote and quickly and repetatively press the power button. This rapid cycling of the power is enough to unstick most stuck power relays and you don't have to get into the insides of your television.
Posted on Nov 04, 2007
  • 41 Answers
Check the voltage to the relay, usually 12v dc. Also check the relay or replace as it may be stuck after the tv warms up. The micro chip for functions could be locking up. Try spraying a little freeze spray directly on chip after tv is locked up see if this unlocks, if it does you have a bad micro chip.
Posted on Jul 22, 2007
SOURCE:
Error message on screen that says PO 1.15 V100
The error is likely to be from the satellite as the set model listed does not have that kind of error.
Nov 29, 2012 | RCA P52926 52" Rear Projection Television
Samsung TV
Based on the information you described you may have a tuner
circuit problem or power intermitent faikure fron the power supply module.
Nov 02, 2012 | Samsung Televison & Video
The digital tuner on my Olevia LT37HVS LCD TV freezes sometimes. When it does, you can't change channels, adjust the volume or even shut it off short of unplugging it. All of the other A/V inputs work just...
Tune the tv to a channel that is just blue screen. Then turn the tv off and unplug for at least 30 sec. Then plug the tv back in and turn it on. Then leave the tv on the blank screen channel go into the menu and do auto cable channel search. After the search is complete try all channels. This worked for me. My tv will not scan if the tv is on a channel that comes in. GOOD LUCK these tv's are junk .
Sep 21, 2009 | Televison & Video
MY PANASONIC FLAT SCREEN VOLUME AND TV CONTROL DOES NOT WORK!!
Try unplug the power cord while the tv is still on. plug it back after 5 mins. it should work.
Aug 23, 2009 | Panasonic TH-42PX60U Television
On screen displays not working
Unplugged the TV for 30 seconds. Then plugged it back in. Started working fine.
Mar 22, 2009 | Samsung HL-R4667W Rear Projection...
Big black box across the screen towards the bottom.
In some TV's closed captioning can cause this problem. turn off CC and see if that helps.
Dec 13, 2008 | Toshiba CF36G40 36" TV
Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Aug 24, 2008 | Samsung LN-S2651D 26 in. LCD Television
LG 42LC7D TV does not want to chg channels after 5 min of use
There are some inductors that are out of spec. LG's original SB said to replace some of these with a jumper, but it only lasted a couple months.
You need to have the Total Main Assy replaced.
Jul 28, 2008 | LG 42LC7D-UB Television
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Black out screen
I had the same problem once with my RCA television. It only happened on certain channels and didn't happen during commercial breaks. If I adjusted the volume on the tv the box went away, but came back shortly after. The problem ended up being some malfunction in the closed captioning. I turned it all off and changed the CC settings and never had the problem again.
Oct 05, 2007 | Westinghouse W33001 30 in. HD-Ready LCD...
Philips 55P8241 55" Rear Projection Television Logo
185 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
