Manual for Sylvania TV Model No, SRT2223
Does this TV Sylvania Model No. SRT2223 have inputs to accept the output of a DVD Player?
  • 1694 Answers
SOURCE: Sony KV-27FV310
Component In is not converted to composite out (yellow)
TV monitor out normally goes to A / V receiver in......T.
Posted on Nov 18, 2007
  • 21 Answers
SOURCE: input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Posted on Jul 26, 2008
SOURCE: lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter?
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Posted on Jan 26, 2009
SOURCE: RCA model F27252GY TV has no Video button or AUX channel for DVD
try putting the tv on channel 00, that is where this tv apparently shows the input from at least one on the video channels.
Nancy
Posted on Mar 01, 2009
konzzz
  • 255 Answers
SOURCE: Yellow input/output cable broken off in TV
you can use a screw small enough to fit in the middle of the tip of the cord.the tip is hollow so just remove any plastic or hard rubber that is clinging on the said tip.(use a big needle for this.)be careful when doing this.make sure that the unit is turned off and unplugged.after inserting the small screw,slowly twist and try to pull it gently until the screw is tight enough but not breaking, to pull the tip.
Posted on May 13, 2009
How to hook up pioneer dvd player to a lg lcd tv
That all depends. What outputs does the DVD player have and what input will the TV accept? If compatible, just plug a cable from the DVD output to the TV input and then (on the TV) select the DVD as a source. For more specific instructions you need to include information such as the make and model of both the TV and DVD player.
Jan 28, 2017 | LG Televison & Video
Why can't I get the DVD player to work? I have it hooked up to a cable box.
im wondering why you did not connect it to the tv ?? but instead to cable box , does it have a pass thru capability ?? does it need to be off to pass thru ?? as most dvd player don't have a rf output but instead use a hdmi or composite signal output , would it not be easier to connect one of these to a spare input on tv then when u want to use dvd you only need to select the proper input from tvs source button to view the dvd ??
Jan 10, 2017 | Sylvania Televison & Video
How do you hook up a sylvania TV model#6313ce to a DVD player?
Connect the output leads of the player, often coded red (r. audio), white (L. audio) and yellow (video) to corresponding inputs on the rear of your Sylvania TV.
Jun 18, 2016 | Sylvania Televison & Video
How do I connect my Sylvania DVD VCR Player to my Westinghouse LCD TV?
Your Sylvania player probably has three outputs: right audio (red), left audio (white), and video (yellow). Use a corresponding three conductor cable to connect to corresponding inputs on the rear of your Westinghouse TV (if it has them).
Sep 19, 2015 | Sylvania Televison & Video
Need code for generic remote control for SRT2223 Sylvania TV 22-23 inch
Universal remote codes for Sylvania are: 0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
Nov 01, 2012 | Televison & Video
How to change sylvania tv to video without remote
I was able to get the Sylvania TV to accept a different input (the remote was lost) by connecting the DVD to a Sony VCR using composite RCA jacks then connecting that to the TV. You'll need two 3-jack (yellow, white, red composite) cables - cheap at any store. Here;s how:
1. Connect RCA output jacks from the DVD to the input female receptacles of the VCR (first cable).2. Connect output jacks from VCR to the female input jacks on TV (second cable). 3. Turn on all equipment (VCR, DVD, TV)4. Switch the VCR to "Line 1" (for my Sony VCR, this shows up as "L1") by pressing the TV/VCR button on the VCR remote (which I did have).
Your system should now work.
The principle is to "fool" the TV into thinking that it's primary input is through the RCA composite A/V jacks rather than the cable connection. No need to disconnect the cable at any time. Any functioning VCR should work well as long as you have the remote for that device. Remember, connect output on the DVD to the input on the VCR, then the output on the VCR to the input jacks on the back of the TV. If you have the connectors on the TV, VCR, and DVD, component cables should work as easily. Remember, output from the DVD goes to the input of the VCR. Theoutput from the VCR (for which you DO have the remote) goes to the input side of the TV.
Apr 07, 2012 | Sylvania Televison & Video
My component video inputs haven't worked for a while now and my wife wants to use it for DVD Player in her workout room. How can I fix it??? Model 27AF42
Most likely the output on the DVD is set for 480p and not 480i. This model of TV only accepts 480i and will not display 480p output from the DVD player. This is the first place to start and if not the issue you can always connect via the composite input which is the Yellow, Red and White jacks. Hope this helps : )
Jul 25, 2011 | Toshiba 27AF42 27" TV
I have a 19 sylvania tv that I want to connet toToshiba DVD playe
If the TV doesn't have AV input jacks, you'll need an RF converter so you can watch the DVD player on channel 3 or 4. You can find them at Radio Shack, Wal-Mart, Home Depot and most places that sell TVs for around $15. Connect the audio and video from the DVD player to the inputs on the converter, and the converter's output to the TV antenna jack. Set the TV to whichever channel the converter is set for (3 or 4, with a switch on the converter so you can choose) and you'll be in business.
Sep 14, 2009 | Sylvania Televison & Video
Sylvania vcr/dvd installation
!st) The antenna INPUT::RF (black wire usually from "cable TV", "Dish TV", even ANTENNA air wave reception,etc.) into INPUT of VCR\DVD, OUTPUT of VCR\DVD to TV RF input.
2nd) If you have INPUT\OUTPUT to what are called " RCA " jacks on your TV, on the front or on the back, then any & all output jacks from VCR\DVD goes to INPUT\OUTPUT of the TV.
In other words:: output of audio on VHS\DVD to input of audio on TV( RCA jacks). Output of video on VHS\DVD to input of video (RCA jacks)
Hope this helps
Aug 14, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
