Question about Sharp VL-Z5 Mini DV Digital Camcorder
Unable to start the camera
Whenever the camera is started it just shows a blue screen saying "DEW"... I'm unable to do anything, also tried to keep the cam in mild sunlight so as to dry away any moisture, no idea wat is wrong, please help
    Problem Solver:
  • 5 Answers
I had the same problem on a Sharp VL-Z3U
This was what worked for it & yours may very well be the same thing:
The solder joints to the DEW Sensor were "cold joints" which means that the solder joint is defective - is not a sound joint. This means that with temperature variation, the solder joint can intermittently separate and break the circuit, causing the DEW Indicator to come on and completely shut down the camera.
Here is a picture from the perspective of the tape cover being at the top of the picture and the rest of the camera at the bottom. The dew sensor will be on your left.
go to:
http://omlets.tripod.com/sharpdew.jpg
get a real slim soldering iron with a fine point. Open the tape cover and take the tape out. Get a strong light to shine down into the mechanism.
If your camera is like mine was, you may see a brownish material on or around the solder joint - this is flux used in soldering which was applied too heavily, and not heated long enough to burn off. The joint therefore doesn't quite connect the dew sensor to the terminal post - depending upon heat/cold ambient conditions, sometimes it makes contact and sometimes it doesn't .
Heat up the soldering iron - make certain the point is tinned (has a thin film of solder on it). Carefully just touch each solder joint for a couple of seconds - just enough for it to melt, and then quickly remove the soldering iron. You don't want to leave the iron in contact with the solder too long or it may melt other insulation around the terminal. This all probably sounds more complicated than it really is - but it really is just a 5 minute operation. If you've not done much soldering, and feel uncomfortable about trying it, you may want to take it to a radio, tv or computer repair shop and ask them to do it for you.
Posted on Feb 27, 2009
I had this same problem with my vl-z5.This worked for me. It was quick and my favorite, cheap. To fix it, first take the tape out of the camera. Look at the tape and see where the contact points are. Then look inside the camera for the contacts. They will be in the same position to line up with the tape. I just used some alcohol from an alcohol swab (Walmart for $1.15 for a box ) on a q-tip and rubbed the contacts clean with about 5 passes over them. I gave it a minute to evaporate and replaced the tape. Everything works fine again. Quick and easy, and no more DEW!
Posted on Dec 14, 2009
My laptop is on but the screen is blue and won't go to the desktop
A Mac that shows you a blank blue screen instead of logging you in may be afflicted by a malfunctioning startup item. Most people have a number of programs that start up whenever you log into your computer, and it's likely that one of these programs is causing issues. The startup item is unable to load, and so it causes the rest of the computer to hang.
In order to get your Mac past this hanging blue screen, you need to boot into safe mode and figure out which startup item is causing problems. The Apple Support article "I see a blank blue screen when I try to start up my computer" tells you exactly how to go about this procedure. Basically, you must remove all your startup items and add them back in one-by-one, rebooting each time until you find the one that causes the hanging blue screen.
Dec 28, 2010 | Computers & Internet
The computer is on, but the screen is all blue
Dec 28, 2010 | Apple MacBook Mac Notebook
My nokia 5800 shows unable to perform bluetooth operation whenever i switch on the bluetooth.
I have Nokia5800, which causes an problem regarding bluetooth.whenever i start bluetooth it show me an error message "unable to perform bluetooth operation"
Oct 25, 2010 | Nokia 5800 XpressMusic Smartphone
My main computer has stopped working. it is displaying a fatal error blue screen with code numbers at the bottom these seems to be problems with the registary stop: 0x00000024 (0x00190203,0x807ae0b0,...
BSOD - blue screen of death....sorry mate but its seems that a fatal error on your operating system occured....most probably a sure way to fix this is to re-install windows, and lose everything on the hard drive...
Feb 15, 2010 | Computers & Internet
A blue screen came up saying something about the memory module!
oh k..
so u mean whenever u start ur computer or whenever u work on it, it shows Blue screen...
This blue screen is called BSOD Error (Blue Screen Of Death)
It occurs due to several reasons but since u specified abt memory, this might be showing you Kernal Memory Dump, i hope..
Dont need to panic, try to start up computer in safe mode & restore it to previous known date at which u didn't had that problem..
It generally occurs after installing some new softwares or drivers that conflicts with the memory module.. so try to restore ur system else try removing ur newly installed software or driver...
Hope this helped u out..
Thanks....
Aug 27, 2009 | Toshiba Satellite A65-S1062 Notebook
Acer 5601AWMLi Orbicam is not working. Says camera is unplugged ( it is built in), tried a system restore, not solved anything. Not showing in Device Manager, altough it is showing in control panel and whn...
tell me about it, it seems to be an inherrent fault with this model, this sometimes works though.
swivel the camera around to face the rear of the notebook (making sure you turn it the right way) and turn it back again, now try to run the camera again, keep clicking the icon to start the cam and eventually it comes on.
Aug 13, 2008 | Computers & Internet
Unable to start camera
perform a master reset.. hold power and push reset button with stylus.
Note: you wil loose all ur data.
Jul 16, 2008 | i-mate JAM Pocket PC
Printer message: Unable to Print
5A: encoder disc or encoder strip or main circuit board or printhead circuit board or power supply defective!
Sorry, cant be fixed by yourself!
Feb 20, 2008 | Brother MFC-440CN InkJet Printer
Sharp VL-Z5 Mini DV Digital Camcorder Logo
357 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
