Question about Octane Fitness Q37ci Elliptical Trainer
Octane elliptical squeaks - Octane Fitness Q37ci Elliptical Trainer
Octane elliptical brake cable
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 01, 2016 | Octane Fitness Q47ci Elliptical Trainer
How can trun on the octane fitness q37e
There is no on/off switch, if that is what you are asking. If it is plugged in, it should be turned on.
Mar 22, 2014 | Octane Fitness Q37c Elliptical Trainer
Need manual
Front right side - it may be hard to find - easier if you tilt it up a bit.
Dec 12, 2013 | Octane Fitness Octane xRide xR6 Seated...
Octane fitness q47ci shows a "break error"
Hello, I have this problem now. Did you get an answer?
Thanks!
skr125@gmail.com
Sep 18, 2013 | Octane Fitness Q47ci Elliptical
Error 20 on Q47 Octane Eliptical
Sounds like it needs to be fixed. It will need a new left motor and cord most likely, less likely a lower board.
Apr 14, 2013 | Octane Fitness Octane Q47 Elliptical...
My Nordictrack E9.0 Elliptical machine has a loud squeek
I have found a possible source for your squeak. I have the same elliptical and had an annoying squeak in the front end of the machine. The squeak could be coming from the roller arm flex bracket and/or the pedal arm flex bracket. These brackets are secured to the front of the roller arms and the pedal arms with a single bolt. Tightening these bolts may help get rid of the squeak. If you don't have your manual, you can download the manual at the nordictrack website. The manual will have an exploded drawing of the elliptical. The roller arm bracket and the pedal arm bracket are numbered 135 and 136 and you will see which bolt I am talking about. I have had numerous issues with my elliptical but after changing some parts under warranty, it is working like new. Good luck.
Mar 19, 2013 | Exercise & Fitness
Life Fitness 9100 Elliptical Squeaks
You can use the link below to purchase a suggested form of lubrication. You may end up needing to replace a bearing or bushing.
Silicone Spray Lube by SPORTSMITH 9 Oz SPORTSMITH net
Nov 24, 2012 | Life Fitness 9100 Elliptical Cross Trainer
Left side its sqeak when i peddle
My Precor EFX 546 elliptical trainer began squeaking when my weight was on the pedals. I thoroughly cleaned the track and wheels with Windex and then used my finger to apply a thin coat of teflon based lubricant (Tri-Flow brand) to the outer surface of the wheels. After 2 applications of lubricant, the squeaking has been eliminated completely. Hope this helps!
Sep 24, 2012 | Exercise & Fitness
My elliptical trainer is starting to squeak. What should I do?
Don't worry; this is a common problem in elliptical trainers. Over time, parts of the machine may start to squeak. I am going to attach a how-to guide that will explain what to do when this happens.
http://www.livestrong.com/article/269134-how-to-stop-an-elliptical-from-squeaking/
Aug 02, 2012 | Exercise & Fitness
Squeaking is definitely coming from the Ramp area either at top or lower. Hard to tell when I'm on it, and it does not squeak without weight on it...Everything seems to be fine outside of the squeaking....
Tip it over - there was a version that had a problem with the frame cracking where the ramp attaches. There is a kit to fix this, if that is what you find.
Jan 03, 2011 | Precor EFX 546i Elliptical Version 4
Octane Fitness Q37ci Elliptical Trainer Logo
460 people viewed this question
Top Octane Fitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Octane Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
