Question about Biostar P4M890-M7 Motherboard
My monitor didn't display anything>.....
I just bought mobo P4M900-M7, I already install it and once i turn on the power the monitor didn't display anything and 5-7 seconds after that my pc automatically turn off.....can anyone help me solve this problem....pleasee.....
  • Celenous May 11, 2010
    Please give a detailed list of the components:
    Memory, CPU, Video Card, Sound Card, power supply etc that you have attached.
    This could be several things and we will need more information to isolate the issue.
  • 56 Answers
REMOVE ALL CONNECTORS AND ADDITIONAL CARDS.
EXCEPT POWER CONNECTION,
PLUG IN MONITOR TURN MACHINE ON.
DOE IT TURN ON IF NOT IT MAYBE A SWITCH PROBLEM.
IF TURNS ON THAN TURN MACHINE OFF AND PLUG IN ONE WIRE OR CONNECTION AT 1 TME AND TURN THE MACHINE ON, IF IT DOESNT TURN ON THAN YOU HAVE FOUND THE PROBLEM.
CANDYMANGANDY
Posted on Jan 27, 2009
Windows 7 audio driver for p4m900-m7 se
http://download.biostar.com.tw/upload/Driver/Audio/Realtek/HD/VistaWin7/Vista_Win7_Win8_R270.exe
Aug 27, 2012 | Biostar P4M900-M7 SE Motherboard
When i switch my pc on i have no display?
your graphicscard not working properly, broken.
monitor cable is fitted in the graphics port?
Mar 23, 2012 | Biostar P4M900-M7 Fe VIA P4M900 Socket 775...
P4M900-M7 FE not using all of memory
i would update bios then check system for used ram at system hardware ok
Nov 20, 2011 | Biostar P4M900-M7 FE Motherboard
I need a back driver of motherboard p4m900-m7 se
Look here:
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=289
Apr 17, 2011 | Biostar P4M900-M7 SE Motherboard
My motherboard is biostar pt890775/p4m900-m7 fe. how can i get its drivers?
Biostar P4M900-M7 FE Motherboard Driver Download - [ Vertaal deze pagina ] 3 Apr 2009 ... Download driver for your Biostar P4M900-M7 FE Motherboard.
www.chipdrivers.com/driver/.../biostar/p4m900-m7-fe/ - In cache - Vergelijkbaar
Oct 14, 2010 | Computers & Internet
I purchased a barebones kit with a Biostar P4M900-M7 FE motherboard. But, after connecting everything, the system doesn't power up. I checked the PSU connector with a safety pin successfully, and the PSU...
Yes it could be the motherboard but i would go back and check all the connections before you come to the decision that the motherboard is bad.
Check that you have your connections right on the front panel header, also check the connectors to and from the PSU (power supply unit)
Check that the motherboard support the bus speed of the memory (usually its 400MHz)
Try clearing the CMOS too which is a small plastic coloured jumper next to or near the motherboard battery.
Good luck.
Aug 01, 2009 | Biostar P4M900-M7 Fe VIA P4M900 Socket 775...
Biostar GF 7100-M7 windows xp trouble
Do you see any text at all when booting up? If so, try pressing F8 on reboot to get to the Windows Boot menu. It's not real apparent when you are supposed to do this, so once the system gets past the initial Power on Self Test, start tapping it. Select Safe Mode and see if your display loads. Set your video settings to something safe and simple like 1024 x 768. Reboot to normal Windows and begin bumping your video settings up from there until you get them where you want them.
Mar 04, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
No display on monitor
no, its working as you said. try to uninstall your video if you installed to expansion slot (agp) then use the on board. that is one of the most common problems of pc specially when you're moving this from one place to another. if it boots from your onboard vga clean your uninstalled video card then reinstall to your agp. i hope that this helps you
Dec 08, 2007 | EliteGroup ECS P4M800-M Socket...
Biostar P4M890-M7 Motherboard Logo
179 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
