Copier does not operate.
When I turn the copier on a wrench symbol appears in the window. This refers to routine maintenance. I have thoroughly cleaned the machine and the symbol still appears thus preventing the copier from operating. It worked very well before the wrench appeared. What can I do?
  • 1 more comment
  • lldearwood Jan 27, 2009
    Panasonic copier model FP-7713 When I turn the copier on a wrench symbol flashes in the window. I have performed routine maintenance on the copier but the wrench symbol still flashes. How can I remove it? Thanks.
  • micromaster
    micromaster May 11, 2010
    hi there,
    thank you for using fixya, and contacting me regarding to your problem,.
    for such clarification, may i know he exact model of your copier..?
    some additional info is appreciated.
  • Julius chuo Sep 15, 2012
    the model of my copier is canon vp7130f when i turn on it gives me error massage like E0 and 02 and turns off what can i do?
    Brigadier General:
  • 3,614 Answers
DO a Reset on the unit.
unplug the unit for an hour.
Let me know
Posted on Jan 29, 2009
You need to call an engineer. it is a maintenance counter that needs cleared
What does the wrench symbol mean
Maintenance count reminder to perform routine maintenance by technician ..
Jun 19, 2014 | Toshiba e-Studio120 Copier
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
The wrench lit up on my copier?
its the maintenance time may i know what SC code appears? so we can help you.
Aug 26, 2011 | Ricoh Aficio 450 Copier
I am getting the wrench signal that my copier needs routine maintenance. Can I do this myself? It is working fine other than the flashing wrench.
Normally the wrench symbol indicates that certain parts are near the end of their usefull life.
Such things as Developer, Drum, Cleaning Blade, possibly also parts in the Fusing unit such as the Heat Roller or Press Roller...this will depend on make and model and the number of copies on the machine.
Think of it like your car, you know that you have to change the oil,Transmission fluid, Brake pads, Tires etc, etc, etc,...but for a time the car is still running OK even tho' these parts are due to be replaced, you can keep driving till your brakes don't work at all, or the engine blows because you didnt change the oil; ...I think you get my meaning....its your choice when you want to do the maintenance...the machine just has an indicator to tell you when IT thinks it has run the appropriate number of copies for certain items to be replaced.
Oct 18, 2010 | Panasonic Office Equipment & Supplies
Have a Toshiba E-Studio 350 in the field, and just lost our Toshiba tech. Copier is showing a wrench. Any recommendations?
Wrench appear in the LCD touch screens mean "call for service". It will freeze the copier from operating until the problem is fixed.
There will be an error code appear when you press "CLEAR" and "3" button at the same time. The error code should appear next to the wrench icon you mentioned.
It is recommendable to get an experience tech to solve the problem for you.
Jan 19, 2010 | Toshiba Estudio 200L Copier
Copier will not operate due to wrench symbol
Hi the the wrench symbol appears when its time for maintenance depending of the type of service needed the copier will shut down, the only why to over come this is to call your service provider for maintenance they will replace what ever parts and or sevice thats needs to be done, they will then enter the code that is need to reset the wrench symbol..
Good Luck
Jan 27, 2009 | Panasonic FP-7735 Black and White Copier
Panasonic FP-7113 Plain Paper Copier
Service Time imageunit can be removed with two screwsand remove tank before lifting out. You can remove drum and cleaning blade section yourself 4 screws. Two on the cleaning and two on the removablr pins on the side.Then remove blade with two screws and fit cleaning blade and drum and reinstall.
Service manual for service mode to remove spanner display F9 ??
Cheers Justin
Apr 30, 2008 | Office Equipment & Supplies
Wrench and Snowflake
wrench means service problem. "snowflake" I assume you mean the developer symbol. Machien on - depres the clear key then the expose key then the clear key again then the expose key you are now in simualtion mode. depress 20 print 01 print this will turn of the maintenance or wrench code. Depress 24 print 06 print will clear the developer. turn on and off
Apr 09, 2008 | Toshiba e-Studio120 Copier
Red symbol appears. not copying.
Need more information. What does the red symbol look like?
Wrench? Paper jam symbol which kind off looks like a pair of scissors?
Need more info.
Feb 14, 2008 | Canon PC-950 Black and White Copier
151 people viewed this question
