Question about InFocus ScreenPlay 4800 Multimedia Projector
Connect to my desktop
I need help in connecting my projector to a desktop. I do not have a manual.
    Problem Solver:
  • 4 Answers
Projector does not recognize computer
Hi Becki.
Projectors will usually be identified on your computer as additional or optional screens/monitors. Depending on your setup (laptop/desktop) you may have some alt keyboard buttons with icons for single/multi screens. You will also likely have monitor control panels or non-windows equivalents. In Windows, for instance, right-clicking the desktop will usually bring up a monitor properties page. There you may be able to then select if the projector is a mirror of your desktop, an extension, projector only, or computer only.
if the computer says it sees the monitor, then you'll likely need to toggle whatever sort of menus the projector has to select the input port. Looking through the manual (
http://www.hitachi-america.us/supportingdocs/forhome/DisplayTechnologiesGroup/lcdprojectors/SupportingDocuments/cp-x251_um.pdf ) , suffice to say that there are multiple ways to connect and, with that, plenty of ways to have your cable be hooked up and ignored nonetheless.
Hoping this helps!
D
Nov 30, 2015 | Hitachi CP-X251 LCD Projector
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
Can I connect a projector (for presentations powerpoint etc )to my HP Compac desktop? Works with my laptop but need to use the Desktop also.
You should be able to. It will somewhat depend on what video connections your PC has and what the projector will allow. If your desktop does not have the correct connections you can get a video card that should have what you need. Here is a link to video cards from a reputable dealer.
Sep 21, 2010 | HP Pavilion a705w PC Desktop
I want to connect a projector but have not cl
Going by what I could find out about this computer, you would not be able to connect a projector to it. The only output ports are speaker and mic., the video is line in only. It did not say anything about an extra VGA port or video card expansion slots which is what you would need to connect an external device.
Dec 31, 2009 | Sony VAIO V1 (PCV-V1) PC Desktop
Connect projector to HP desktop
If you are attempting to connect an LCD projector to a laptop,you connect a monitor cable to your video card and the other end to the monitor input connector. You may have to use an adapter, I know on my LCD projector I had to use a DVI to VGA connector.
Can't say much more not knowing if you are having a problem with a particular brand of projector
Sep 21, 2009 | HP Pavilion a705w PC Desktop
How to plug it in my computer
Connect the VGA cord from the Back of Cpu to the VGA IN of the projector ...
Jun 15, 2009 | Office Equipment & Supplies
I have a new Acer Aspire computer and am not able to project an image through my Sharp KR-32x projector. I have tried both VGA connection and USB connections.
please check the manual for the setup instructions also consult your notebook manual to look for the key stroke to extend the display to the projector.Ensure the little details like input mode and that the lens coveris removed etc.
Also check this video for general instruction on connecting the projector to notebook
(http://www.youtube.com/watch?v=R8UN761ODCo)
Feb 16, 2009 | Computers & Internet
Connect to laptop
Hello and welcome to FixYa
you correctly connected your projector to your computer
on your computer keyboard there should be a FN key and the numbers have a little small blue iicon representing something
since i dont know which type of laptop you are using i should assume that this little info is accurately correct
..... now find a number key with a blue picture that looks like a monitor now press FN+that picture
your laptop monitor should blink and the monitor should display something....
if it dosent try that same conbination again (FN+ #´r)
check me out if you have any problems
hope it helps..................
Oct 20, 2008 | InFocus ScreenPlay 4800 Multimedia...
Video projector from a laptop
You can connect the Projector to the VGA Port of the Notebook which is a Blue Port which can be seen at the rear of any desktop computer to which we usually connect the Monitor to.
The VGA Port will have 15 holes on it and should be in Blue colour.
You can locate the VGA Port at the Left side of the Notebook.
Locate the port according to the information available below :
http://h10032.www1.hp.com/ctg/Manual/c00726464.pdf
Refer to page number 14 (18 of 32) in the manual.
Once you connect the Projector to this port, hold the FN key and press F4 key once.
This wil get the Display on the Projector connected to the Notebook.
If you just want the display only on the Projector, hold the FN key and press the F4 again.
Now, if you want the display back on the LCD of the Notebook, Press the FN + F4 third time.
Hope this helps..
Aug 31, 2008 | HP Pavilion dv2000t Notebook
Help
The projector probably has a user manual, right? Have you followed the steps in connecting pc with projector? You might have missed a setting or something and need to re-check it.
May 30, 2008 | Toshiba Satellite L20-S310TD Notebook
InFocus ScreenPlay 4800 Multimedia Projector Logo
89 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
