Question about OKI C5100n Laser Printer
Hi I have a Oki c6100dn Printer with fatal error message 173, How can I fix that
  • mkiper2 Jan 28, 2009
    Yes, I would like to know any solution for this error
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Posted on Nov 02, 2013
  • 152 Answers
Unfortunately, a 173 error is a fatal error which requires service, or technical skill on your part. It usually involves replacing the power supply board and fan.
Posted on Feb 03, 2009
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
Hello i'm french, i have an oki c 8800 with : service call 173 fatal error. i don't understand what is this error and i want to know how to repare
Error code: 173
This error code means that the fuser temperature is low. You need to replace either the fuser or the thermistor inside the fuser.
May 27, 2011 | OKI C8800dn Led Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
I have a OKI C5500N, keep getting the message ''Service Call, 173: Fatal Error'' I have tried turning it off then on, which has worked before, but today it is not working.
1. Remove All files that were installed before 'fatal error' using 'Printer Util.exe' or similiar file available in your CD.
2. Install software 'Dial-A-fix'. (Dial-a-fix is a collection of 'known fixes' that have been compiledover the past year that really knock out some serious Windows problems....)
3. Run the 'Dial-a-fix.exe' Software and select 'Fix Windows Installer' & 'Empty Temp Folder' options and click 'Go' button.
4. Restart your computer, run the your printer CD, you should have no problem. (don't connect the printer/device until the cd Setup prompts you to)
Nov 10, 2009 | OKI C5500n Laser Printer
Fatal error 173?
It points to an internal error. It may be from the fuser unit. Make sure all the wires are connected praoperly and that you didn't disconnect anything when you repalced the fuser. If the problempersists, you'll have to take it in for service.
Aug 20, 2009 | OKI C5150n Led Printer
I have a oki 9600 Fatal error 917
Replace the transfer belt unit. A 917 is a belt **** sensor error.
Jun 19, 2009 | OKI C5150n Led Printer
Printer c6100Dn
this usually involves replacing the power supply and the fan. It requires service or, if you have it, technical skill.
Jan 26, 2009 | OKI C5100n Laser Printer
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
Aug 10, 2007 | OKI C5150n Led Printer
OKI C5100n Laser Printer Logo
1,298 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
