Question about Honeywell DT7235T DUAL TEC Motion Sensor
False alarm The sensor is wired per spec but a few minutes after the system is enabled it beeps and triggers the alarm with no real reason for it
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
Were is it located. it maters with a motion they work on infer red motion. If it is near a heat source or anything moving it will set it off.
Posted on Dec 18, 2014
To turn the beep sound off when system is set to armed
Troubleshooting FAQs - Solve Problems Quickly by ...
www.adt.com/help/faq/troubleshooting
The ADT CorporationHow do I silence low battery beeping? ... Why is my ADT Pulse security systemreceiving an unavailable message? ... How do I fix a disconnected camera? ... by a motion detector while the system is armed, the burglary alarm will sound. ... Some common events that may cause a motion detector to set off a false alarm ...
Five Steps: How to Stop a Beeping Security System
https://www.vectorsecurity.com/.../Five-Steps-How-to-Sto...
Vector SecurityFeb 9, 2015 - The shrilling sound of a continuously beeping security system is enough to drive anyone crazy. A power outage, faulty wiring or bad batteries ...
The Top 15 Questions about ADT Home Security Systems ...
zionssecurity.com/...security/the-top-15-questions-about-adt-home-securi...
Oct 10, 2012 - How do I turn off the voice descriptions but keep the chime sound on?... If your time on the Lynx system is not set all you need to do is push your user code + # + 63. ..... When our security alarm is not armed it beeps every few seconds ....Reasons to Install Security Cameras in your Home · Small Business ...
Jan 03, 2016 | Home Security
How to reset coolant thermastat gauge sensor
the sensor is pre set and cannot be reset. If you have a light problem still on after changing the sensor then the light can be turned off using a scanner
Jul 01, 2014 | 1994 Lincoln Continental
Buick lesabre 97 car alarm goes off for no reason why?
Most likely, you have a vacuum leak if steam is coming from your defrost vent in a 1997 Buick LeSabre. There are approximately 600 million passenger cars worldwide (roughly one car per eleven people). --------------------------------------------------------------------------------------
ZED-Bull
Jan 28, 2013 | 1997 Buick LeSabre
The alarm system on my 2001 Volkswagen Jetta GL keeps turning on by itself
You must have the dealer keep the car until this fault occurs and then scan the security system to see what is causing the triggering of the security system. It is very possible that the drivers door ajar switch or latch switch is defective and it triggers a false tampering signal.
Sep 28, 2012 | Cars & Trucks
Alarm beeps every 5 mins. I have changed battery and problem still persists.
Tell me what brand your alarm is and I can help you with the beeping. Usually if you hit # it will silence the beeping for 24 hours. Something you can try is finding your main control box. Its usually located in the garage or in a closet. It is tan and 6 x6. First disconnect the battery inside the control box by jiggling off the black/red leeds. Then unplug the power supply. Wait five minutes. Reconnect the battery and plug in the control box. This is completely powering your system down and then repowering it up-essentially "re booting." If this does not correct the issue, give me the brand and I can further help you.
Nov 22, 2010 | Industrial Home Security Burglar Alarm...
Alarm keeps going off
There a few reasons for your alarm to false trigger. The shock sensor may be too sensitive. The hood or trunk pin may not be making contact. A door may be open or there could be an issue with vehicle's door latch pins.
Sep 22, 2010 | Combo Alarm and Remote Start with One For...
Alarm not beeping when doors are open. led on door goes red when door is opened and alarm box has red and green lights when alarm is actived but not chimes or alarm when doors are opened
When a zone has both red and green lights on, it means that it is in delay mode. That means when the sensor is triggered, the system will wait for a predefined time interval (30 seconds) for user to reset the trigger. During this time interval, the system will not beep or alarm. But after that, if user does not reset the trigger, system will go off.
User can reset the trigger from keypad or by remote.
Sep 05, 2010 | Skylink Group Skylink Security System Kit
I need to disable my alarm on a 1997 bmw 528i.
Now im not sure since the manual says your model has the same alarm system as the 328i and on the 328i you can remove the module to disable by doing the following. you can unplug the control module. It is located under the glove box. Climb under the dash on the passenger side and remove a few screws on the trim panel under the glove box. Theres a black control module with a green connector. There should be a lock tab on the connector. press the lock tab and pull out the connector. The alarm should now be disabled. But if it has the special transponder key this may not work.
But if the only reason you want to disable it is because of the motion sensor setting of the alarm for no reason there is a solution for this. To disable the motion sensor, hit the lock button to arm, then hit lock button again within four seconds to disable motion sensor. Red light on rearview mirror should flash four times, then pause, then start flashing on regular intervals. this is most likely the reason if your having the issue where the alarm goes off every 20 minutes.
If you want to completely remove it below is a wiring diagram taken from the manual for you alarm system.
this is from the manual its the alarm wiring diagram.
Battery Constant 12v Positive Wire ( ): Red/White or RedBattery Constant 12v Positive Wire Location: Ignition Switch Harness
Starter Positive Wire ( ): Black/Yellow or Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire ( ): Green
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire ( ): Purple/White or Purple
Second Ignition Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire ( ): Gray/Purple and Gray/Yellow. Use Both Wires. This vehicle has a dual parking light system that will require 2 extra relays.
Parking Light Positive Wire Location: At Headlight Switch
Power Door Lock Positive Wire ( ): White/Red
Power Door Lock Positive Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Power Door Unlock Positive Wire ( ): Blue/Red
Power Door Unlock Positive Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Door Trigger Negative Wire (-): Brown/Gray
Door Trigger Negative Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Domelight Supervision Wire: Turns On With Unlock
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Brown/Red or Brown/Yellow
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Instrument Cluster
Brake Light Positive Wire ( ): Blue/Red or Green/Red
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): Disarms With Factory Remote Only. Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: Transponder Anti-Theft System, Requires Bypass And Extra Ignition Key. The 1997 model year vehicle may require a bypass module and an extra ignition key, if vehicle is equipped with a special key from BMW.
Factory Anti-Theft System Location: Transponder At Ignition Switch Tumbler
if you require further assistance please let me know and i will help assist you from there. Thanks, Midwest-Tek
Aug 27, 2010 | 1997 BMW 328
My alarm keeps going off
Most alarms would kick off only when triggered or when faulty.
triggered - could refer to even false triggering, that is even if no intrusion, the sensors senses something and falsely triggers the alarm. This is the most common cause.
Almost all alarms make use of the door switch (the same door switch that triggers the dome light). Since these switches are more prone to being wet, dirtied or accumulate dust and grime, they are more prone to be the culprits. In most instances, it is a matter of remove, clean and reinstall. In some cases, it could be the wire 9to these switches) that were crinked by the door, panel or any metal part thus creating a short to the ground;
Another possibility is the alarm itself. Most alarms have a logic circuitry with external sensors to provide state/condition of its sensors. It is a simple low/high condition. Dust, weather condition (dampness, cold) could affect the sensitivity, electrical characteristic and therefore be falsely triggered. For this, it would require familiarity with electronic circuitry and components, use of a DVM and perhaps even a soldering iron. Should you be uncomfortable performing a DIY, then perhaps your best bet would be to seek the services of a qualified electronics professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 04, 2008 | Nissan Armada Cars & Trucks
Laser warning - Multiple false alerts
Although the detector could have internal problems, it is possible that it is coming from a real source.
A route I took between home and business triggered mine along the same stretch every time I passed it and after looking a a map and comparing it with the stretch I drove, I found that the Marine airbase at Miramar California was visible (line-of-sight) between two mountains only along that stretch.
Note if the falsing happens at about the same point each time.
I just learned to ignore the laser alarm if it triggered during that 1-2 mile 'window.'
Jul 11, 2008 | Passport 8500 Radar Detector
Honeywell DT7235T DUAL TEC Motion Sensor Logo
118 people viewed this question
Top Honeywell Home Security Experts
Steve
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
