Question about Sharp Office Equipment & Supplies
System error [ L 3-00]
  • Sharp Expert
  • 337 Answers
Scanner return trouble. Make sure the scanner carriage travels smoothly. Remove grease, clean scanner rails and re lubricate with light teflon grease
Posted on Jan 30, 2013
Dell 4 beeps
POST Beep Codes
How to fix Dell BIOS 8 beep error.
Probable Causes
Error
Beep Codes
Defective system board.
Memory refresh failure.
Faulty DIMM or defective system board.
Error occurred in first 64 KB of main memory.
Faulty DIMM.
Read or write error occurred in first 64 KB of main memory.
Timer on system board malfunctioned.
Defective microprocesor.
Microprocessor error.
5
Gate A20 failure.
6
Defective microprocessor.
Microprocessor-execption interrupt error.
7
Missing or faulty video adapter.
Video memory read/write error.
8
Corrupted system BIOS program or defective system BIOS chip.
ROM checksum value does not match value encoded in system BIOS.
9
NVRAM shutdown register read/write error.
10
Defective microprocessor or cache card.
Cache memory error.
11
Faulty video adapter.
Video adapter failure.
12
Loose video cable connection or defective video cable.Faulty video adapter.
No monitor connected.
13
14
May 09, 2013 | Dell Inspiron 1018 Notebook
2003 Passat GLX V6 4motion with 194K km. Requires 1L of oil every 4-5000 km. Is this normal?
That consumption is great, no worries.
Most healthy cars will consume a quart in 2,400 to 3,00 KM.
Car manufacturers will not repair and consider a quart in 965 km to be normal, I would be livid at that consumption.
If consumption gets too much, consider a high mileage blend, like Casteroil. It is a semi synthetic, and actually does lower consumption.
There is actually nothing that you could do to lower your consumption, but keep everything clean and maintained.
Feb 23, 2011 | 2003 Volkswagen Passat
How do i improve gas mileage?
Welcome to FixYa.com Have your oil changed every 3,00 miles. Have the tires checked for proper pressure. coming to a stop do not stop hard and on acceleration take it easy on the pedal. And, Tune up at it's normal interval. Lee
Aug 16, 2010 | 1999 Jeep Grand Cherokee
What is this error mean that i get during boot up? 312.198 Eth0:(185488) System Error Occurred (0) 312.199 Eth0:(185489) System Error Occurred (0) 312.200 Eth0:(185490) System Error Occurred...
I think this is related to to the NIC (Ethernet port).
Go into the BIOS and set it to default settings, see if that resolves the problem.
Let me know how you get on.
Regards.
Jun 30, 2010 | MSI P4MAM2-V Motherboard
2001 jetta wont rev past 3,00 rpm
sounds like something was set up wrong.timing belt ...cam/crank sensor/ or work on mechanicals not clean..valves/piston damage...or....alot of junk went through motor when this occurred and your catalytic converter is clogged
Dec 08, 2008 | 2001 Volkswagen Jetta TDI
Wifi driver
The current driver on Hå:s site is 3,00 D, not 3,00 D2.
Try to download the correct driver and test if that works
You will find the driver here:
http://h10025.www1.hp.com/ewfrf/wc/pfinder?lc=en&dlc=en&cc=us&query=presario%20c500%20&dest_page=softwareCategory&tool=softwareCategory
Good luck
Dec 05, 2008 | Compaq Presario Notebook
Is it possible to have memmory more than 3,00 GB?
first you need to update to the latest bios from asus http://en.wikipedia.org/wiki/Asus . after you have updated go to your system bios. select the advanced tab, then select chipset then set the northbridge memory remap to enable. this will fix your problem. any questions email me
christian@thepcrepairguy.net
thanks!
Apr 30, 2008 | ASUS P5LD2-VM Motherboard
How to use the scanner sofware?
Here's the link to the user manual for the copier (it says ar122 and ar152 on the front, but it is the same manual, read it as if you had a AR 122E); http://www.tradenet.sharp.co.uk/files/Copier%2CPrinter%2CMFP/AR_Product/AR153EN/AR153EN57.pdf Check this link for basic info on Sharpdesk; http://www.sharpusa.com/products/applications/sharpdesk/1,2693,3-3,00.html If you open sharpdesk, select the help menu there should be "about sharpdesk" at the bottom - this should tell you which version of sharpdesk your office is running. Check this link for the user manuals for most versions of the Sharpdesk program; http://esupport.sharp.at/html/om/index.php?StartRec=0&ListLimit=10&Lang=%&TemplateLang=nl&ProdLine=34&SortOrder=DESC&OrderBy=Title&SearchString= Hope this helps, please ask again if you have any questions :)
Jul 05, 2007 | Sharp AR-153E Copier
26 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
