Question about Olympus Stylus 710 Digital Camera
I have a problem "D: 5f08 5e02". with my camera
  • Anonymous Mar 24, 2009
    D: 5f08 5e02
Someone else posted the fix for this and it worked for me!
Hold the camera with the lens facing straight up toward the sky. Turn on camera. I had to do it 4 or 5 times before my camera started working correctly. Amazingly simple solution that I'm so glad someone shared with us!
Posted on Feb 07, 2009
I have the same exact problem ("D: 5f08 5e02" on my Olympus Stylus 710) but after 10 times trying Rain123's solution, I just gave up. Feels like the "solution" is a hoax. Ha ha ha!
Posted on Mar 09, 2009
Theres a stripe line if I use my samsung SL30 digital camera in a bright place but in dark place the camera sa good and thers no stripe line.
Is the "Stripe line" appearing when you use an arftificial (LED or Fluorescent) light source?
They flicker and can cause a line or interference pattern on the camera.
Apr 07, 2016 | Samsung SL30 Digital Camera
In my 4 camera surveillance system two cameras stopped working
The screen should say a message similar to "VIDEO LOSS" if it does The power packs or multi power supply to your cameras are easiest to check for starters. Unplug the power to a working camera and plug it into the non working camera close to the dvr. If the camera that didn't work came on, then the power pack is most likely the problem. If it didn't have a message saying "VIDEO LOSS" then it may be the sensor that switches to day/night vision. I have had cameras that when it switches to night vision the screen goes black and unplugging in the power to the camera and re-plugging it in gives it a boost and then comes on. If switching the power from a working to non working camera don't work get the ladder out and unplug and re plug in the connectors at the camera in case it is a connection there. Last if that didn't work would be to take the camera that don't work off and plug it into the end cables to a working camera, if it works then I would suspect the cable to the camera to be bad. Just a process of elimination.
Nov 29, 2014 | Sony 1/3 Sony Super HAD CCD Outdoor IR...
Why does camera close down when I plug USB cable to pc have replaced cable & batteries
As soon as you connect a camera to a computer, the camera shuts down, because it only can act as a "dumb" memory stick.
Only more advanced camera's and special programs allow the camera to be connected and be monitored on a computer.
Nikon has Camera Control Pro 2 for its DSLRs. Only the software is over 100 dollars.
When you have installed Kodak Picture easy software, you can connect the camera to the computer and then after you switch on the camera, you can download the pictures from the camera to the PC.
Jun 11, 2014 | Kodak EasyShare C143 Digital Camera
I can't transfer photos from camera to computer
Go to Nikon website and load up the Nikon Camera Control Pro2 software.
Then connect camera with the USB Cable from camera to computer.
Turn on camera.
Wait or click on Nikon Camera Control Pro2's Icon.
Jun 05, 2014 | Nikon D7000 Digital Camera
Have put in the SD card into my camera before doing the set up via the PC on my new olympus sp800UZ camera can you help as I cant seem to use the camera
If you did not format the internal camera memory, you can initialize and install: Set the camera to OFF. Remove the SD card and connect the camera to the computer with the USB cable. The computer and camera should negociate and the camera should initialize and it asks to install the software.
Jan 06, 2011 | Olympus SP800UZ Digital Camera
STylus710 gives me a blue screen with code 5f08,5f0a,5f08,5e02 when i turn it on any idea?? wont take pics but will play back photos.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Sep 26, 2010 | Olympus Stylus 710 Digital Camera
We cannot view camera images on TV from G2. We could in the past. Image in camera viewer goes blank when plugging tv cable into camera. Tried new cable. Still the same. Has something failed in camera?
Hello. I'm not sure if the camera has failed but try this sequence.Plug camera into tv then turn on camera then push review button. This is the only way 2 of my cameras will work for tv viewing.
Builderdale
Feb 26, 2010 | Canon PowerShot G2 Digital Camera
Olympus Stylus 1000-- The camera is not reading the battery. I know the battery is good because it works in my other Olympus camera, but reads 'empty' when put in this camera
Your camera may be ok. Every and each camera has different reactions to a battery condition depending on the design of the circuit. Your battery may work ok on the other camera but this camera needs more juice (assuming the camera is working ok). If the camera demanding more power from the battery, try the rechargable batteries. Hope this helps. -James
Mar 28, 2009 | Olympus Stylus 1000 Digital Camera
Blue screen error code
the lens open halfway, the picture on the LCD is blurry and one second after the lens close and an error appears of the screen saying "D: 5f08 5e02". what does this mean??? can you help me fixed this one??
Oct 13, 2007 | Olympus Stylus 700 / 700 Digital Camera
Olympus Stylus 710 Digital Camera Logo
879 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
