Question about Stoves 800DFDOm Dual Fuel (Electric and Gas) Kitchen Range
The cooker stays warm when mains cooker switch is on.
When I turn on the (main) cooker switch to use the ignition for the gas hob, my oven stays warm (no fan operating)and will only switch off when the mains is switched off. What is the problem please?
  • 1 more comment
  • Anonymous Mar 25, 2014
    Green hob light will not stay on, and is very dim
  • Anonymous Mar 29, 2014
    Tried the battery
  • Anonymous Mar 31, 2014
    Hob light to indicate hob is on stay on when switched off
  • 183 Answers
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Posted on Jul 28, 2007
    New Friend:
    Problem Solver:
  • 6 Answers
I assume you mean if the main electrical isolation is switched to on , the grill/ upper oven heats up even though the grill / upper oven switch is correctly set to off ......if this is the case you require a replacement thermostat for the upper oven I believe these are now obsolete and the alternative comes as a kit part no. 012959401 to modify the wiring and replace both upper and lower oven thermostats see instructions attachedThe cooker stays warm when mains cooker switch is  - cid:eb5fa66b-5b72-4dad-aafc-a1f3a691fb03
Posted on Jul 10, 2014
6ya staff
SOURCE:
My lower oven element will not turn off unless I turn the cooker off from the mains.
contact someone that repairs them and ask them,look on ebay for one of the boards and you will find an ad for repair,they sell their services on ebay,this is an example,but,you might find your board or repair here, 0 results found for stove main board repair
Jul 16, 2015 | Ovens Ovens
Brandt gas cooker
Just allow them to dry completely after 3 days in a dry environment. If they continue to click, then call a tech to check the electrical
Feb 06, 2014 | Washing Machines
I have an old belling farmhouse cooker the hob works fine but the oven isn't igniting manually or by the electric ignition The timer is manual and is stuck on the red patch I can't seem to shift it ...
Take the tiny screws of there are loads down right hand side then release screws on hob once you can lift hob plates up. Undo the covers on back of timer clock control . Make sure you un plug from mains . Take the neutral of back of timer clock. This will allow your oven to auto ignite again
Jan 07, 2014 | Belling FarmHouse 931 Gas Kitchen Range
Stove and oven not working
IF ELECTRICAL APPLIANCE
1. Check the fuse in your mains electric box, something may have triggered it to shut off, If off, switch on, if it doesn't stay on, you may have water/moisture in the electrtics (wait a few days, see if it has evaporated, try to switch on again).
2. Most electric ovens have a seperate fuse/switch in the kitchen normally at counter level, check to see switch is on, and fuse is working, sometimes indicated by a red light. You may need to change the fuse in the wall - MAKE SURE THE MAINS ELECTRIC IS TURNED OFF BEFORE DOING SO, BEST TO CONSULT A QUALIFIED ELECTRICIAN.
3. If using a smaller electric oven, i.e. a baby belling, it may come with a plug to connect to the mains, check the fuse.
4. Check for signs of damage in the cable leading to the mains, Best to turn the mains switch off for the cooker before doing so.
IF gas check you have a supply of gas running to the cooker, i.e. at the gas meter/pipe feed if on.
IF none of these work contact your gas / electic supplier for further advice, as dealing with mains electric / gas supplies can be very dangerous.
Feb 09, 2013 | Kitchen Ranges
My indesit gas cooker's igniters keep clicking
Hi yes it could be that if it only just done this leave it off you can still use the top the heat while cooking should dry it out.
Oct 10, 2009 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Jun 01, 2009 | Ovens
Oven will not respond
The knob won't have any effect on the flame size.  The knob controls temperature.  If you're referring to the pilot light staying on and then the main flame not going on...that's another problem.  If the main flame will not go on, the assembly that controls the main flame is likely defective.  If the unit has a thermocouple, you might change it out first.  Sometimes, that's all that is needed and they're cheap.
Nov 23, 2008 | Rangemaster 110 (Gas) Kitchen Range
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Stoves 800DFDOm Dual Fuel (Electric and Gas) Kitchen Range Logo
1,236 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Greg Bernett
Greg Bernett
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
