Question about LG W1934S-BN 19" Monitor
Lg flatron w1934s schematic diagram - LG W1934S-BN 19" Monitor
tomhar
  • 20 Answers
SOURCE: How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Posted on Mar 08, 2009
Geekman
  • 32281 Answers
SOURCE: Lg Flatron W1934S Moniter Problems
You could have a faulty inverter board or a faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp and the CCFL lamp is a mini fluro tube.
Have a look at LCD Patrs WEB site for service, parts and DIY info Use this link to their WEB site :-
www.lcdparts.net
Posted on Oct 02, 2009
  • 37 Answers
SOURCE: my lg flatron model w1934s was working fine but
Try turning it off and hold the power switch in for about a 30 seconds. This may help to reset the monitor. Afterwards, try and power it up again.
Posted on Oct 10, 2009
neutronrace
  • 66 Answers
SOURCE: LG FLATRON W1934S
hi,
check first if the connector has no connector pins wha are broken or shifted. if not chack cable for hard nobs or turns maybe cable is interrupted.
take other schreen to check VGA output of PC.
if all this not helps mail me back
greetings cis
Posted on Feb 16, 2010
CameraParts4
  • 109 Answers
SOURCE: i want lg flatron w1934s
Hi, i would search on DriverGuide.com.... its the safest place. Most other driver download
sites are infested with pests that can bug you to no end.
Posted on Jan 23, 2011
My LG FLATRON W1934S was working fine last night. went to turn it on this morning and nothing happened. no orange or blue lights and it wasnt left in sleep mode either. what could be wrong with it?
I would suspect a problem in the monitor power supply, either a fuse or possible bad filter caps especially if you had to turn it on several times to get it on just before it failed.
If you are able to open it here is what bad caps look like:
Dec 17, 2012 | LG Electronics W1934S Flatron W1934S...
I want lg flatron w1934s drivers.please tell me how can i search them.
Jan 23, 2011 | LG W1934S-BN 19" Monitor
LG FLATRON W1934S
hi,
greetings cis
Feb 16, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
My lg flatron model w1934s was working fine but now it will not come out of power saving mode at all. What should I do?
Oct 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
www.lcdparts.net
Oct 02, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
What is the best method for cleanig a flatron
Take a clean cloth and spray some windex on the cloth and then wipe down the screen and it should come nice and clean. Never spray it directly on the screen cause if the liquid goes down inside of the screen then it could damage it.
Mar 01, 2009 | LG 22" FLATRON LCD Monitor
LG W1934S-BN 19" Monitor Logo
46 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
