Question about Dimplex SS5858N Mid-Size Heater
Dimplex air heater
Just replaced the 60 watt bulbs yesterday.
it was working fine . and next day the whole unit just went out .
and the power switch on the back will not move on or off.and i also replaced the 7 watt bulb on front top.. The power switch would not turn on. I unplugged unit to get on and off for 2 days and then entire unit stopped working totally.
Dimplex Air Heater Part #6900331000-Cat #D55804 Mod. C 120 volts-1500 watts
5 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: dimplex air heater
my guess is the power switch is shot.
Posted on Nov 04, 2007
Buffalo12980
  • 625 Answers
SOURCE: quartz heater parts
check out this site for heater parts.
http://www.infraredheaters.com/quartz1.htm
Posted on Nov 29, 2007
  • 80 Answers
SOURCE: How do you wire a dayton electric unit heater?
red, white, and black will be your high voltage. Green will probably be for ground and yellow and orange go to the thermostat. I can confirm on Monday when I have access to manuals.
Posted on Oct 04, 2009
  • 4736 Answers
SOURCE: the flame effect isn't working.
You can either purchase one from DimPlex or online from Granger Electric.
Posted on Feb 02, 2011
How do I change the bulb in my dimplex wynford inset fire?
On the back of the cabinet, about 3" to 4" up from the bottom, you should see a removable rectangular panel. Removing it, will give you access to the bulbs. Which are 60 watt, small base chandelier bulbs.
Turn the unit OFF & Unplug it, before removing the rear access panel.
Hope this helped you and thanks for choosing FixYa.
Aug 24, 2011 | Dimplex DS5603 Heater
Light and flame effect not coming on dimplex springborne electric stove.
The light bulbs that provide the flame effect, may have burned out. You can access the bulbs by remove a rectangular access panel on the back of the stove, just above the bottom edge of the stove. Be sure to turn the unit OFF and unplug it before attempting the bulb replacement. The bulb type is 60 watt, small base, clear chandelier bulb.
I hope this helps you and thanks for choosing FixYa.
Jul 25, 2011 | Dimplex Compact Electric Flame Stove...
How do I replace the light bulb in a Dimplex Springborne electric stove?
You can access the bulbs by removing the rectangular access panel on the back of the stove, just above the bottom edge of the stove. Be sure to turn the unit OFF and unplug it before attempting the bulb replacement. The bulb type is 60 watt, small base, clear chandelier bulb.
What type of bulb is required for the mcn20 dimplex fire thank you
Steve, a 60 watt, small base, chandelier bulb is what is required. There are usually 3 to 4 of them in most electric fireplaces.
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Flame effect has stopped but fans still working. Can it be repaired. I am in Christchurch.
More than likely, the bulbs that produce the fame effect have burned out and need to be replaced.
Robyn, you can access the bulbs by removing the rectangular cover on the back of the stove. It's located just above the bottom edge on of the back cover. The bulbs are 60 watt, small base chandelier bulbs. They simply unscrew to remove. Be sure to unplug the unit, before attempting any maintenance.
May 27, 2011 | Dimplex Compact Electric Flame Stove...
I can't to find the area to replace the bulb. Everything works except for the light To eacy to leave on without the light. Where is the bulb located and what should I purchase to replace it. model #...
On the back of the heater stove, you will see a rectangular panel in the center, near the bottom of the stove. If you remove that (by removing the screws that hold it in place), you will have access to the small base, 60 watt. chandelier bulbs that you will need to replace. Be sure to turn the stove OFF and unplug it, before attempting to replace the bulbs.
Hope this helped you and Happy Easter!
Apr 24, 2011 | Dimplex Compact Electric Flame Stove...
HOW TO REPLACE BULB ON DIMPLEX CLUB STOVE HEATER
On the back of the stove, you will see a rectangular access panel near the bottom of the stove. If you remove that, you will have access to the bulbs. They are 60 watt, small base chandelier bulbs.
Hope this helps you change the bulbs.
Mar 28, 2011 | Heating & Cooling
The light has gone out on my dimplex ASP20 fire.
There are several light bulbs that create the flame effect. However, it's unusual for all to go bad at one time. If you still have your Owners Manual, it will tell and show you how to access and change the bulbs. In the meantime, turn the Master ON/OFF switch to OFF and Unplug the unit from the wall outlet. Wait 12 to 15 minutes and plug the unit back in. Turn ON the Master ON/OFF switch and test each function one at a time. Hopefully, the time unplugged gave the unit time enough to reset itself. However, if this continues to occur on a regular basis, contact Dimplex USA, Technical Service at
888-346-7539
If you want to Troubleshoot and access the bulbs yourself: Remove the Plexiglas from the front of the fireplace and carefully remove the logs. The ember bed below where the logs were sitting will lift out and you'll have complete access to the bulbs. The bulbs are 60 watt, small base, chandlier bulbs.
Hope this helps you solve the problem
Mar 21, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
The "flame" on my unit
The circuitry that controls the flickering flames may have gone bad. Or a wiring connections to the bulb harness may be loose. In some cases it's just hard to know because these electric fireplace/ heaters aren't intended to last a long time. I'm not throwing stones at just Dimplex. That's the case with 98% of the manufacturers. We stopped selling electric fireplaces 4 or 5 years ago, just for that reason. Just to many callbacks on them, after as little as a year..
I think too, that most people who have them don't thoroughly read their Owners Manual and provide the routine maintenance that's required. And, I'm not saying that's the case with you. But, I wish I had a dollar for every questioner I have provided a possible solution for.
If you still have your Owners Manual try to trace the circuitry and trace the wiring for the light bulbs. You may find the answer there.
Hope I've been of some help to you.
Feb 14, 2011 | Dimplex DS5598 Mid-Size Heater
Dimplex air heater
Oct 31, 2007 | Dimplex DS5598 Mid-Size Heater
Dimplex SS5858N Mid-Size Heater Logo
189 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
