Question about GE WSM2780W Stacked Washer / Dryer
Washer smoking wsm washer model is smoking, the dryer is stacked on top of it
    Problem Solver:
  • 14 Answers
If the WASHER BELT is burnt or broken or the WASH TUB is not rotating properly.
You can unplug the unit, remove the front panel of the washer and then slowly remove the belt. The replacement belt is easy to put back on. Finding a belt on the internet for under $10 is easy - just search for a belt with part number 134161100. Potentially the plastic pieces are from the damaged transmission. Replace the belt first to see if you can keep using the unit. If the transmission is damaged it is a bit expensive to replace and difficult to do yourself. I'll keep you posted if I have to do the same to my unit.
Remove and replace the washer belt (order part # 134161100 from google or ebay), arrived in two days and noticed busted plastic pieces and two semi-circular metal bearings that would have fit into the bearing.
Step 1: Keep the front panel of the unit off and run the unit in a normal wash mode. You can do this without filling up the wash tub with water by simply rotating the WASH dial to the proper setting (eg. RINSE). Be very careful as the moving parts could cause injury while the front panel of the washer is removed and the tub is turning.
Step 2: Watch to see if the belt is still slipping and the tub does not turn. If it rotates properly, then congratulations, you have fixed your problem with a new belt. If the belt still slips, ... proceed to step 3.
Step 3. Some web sites (and the user guide) say that the 'tension spring' may not be working. I don't believe this is the case. Upon closer inspection take a look at the 'transmission' which is the large metal part that rotates the tub. Unplug the unit and using your hands, see if you can rotate the tub simply by turning the transmission part. Turn the transmission in both directions. If you see that it gets STUCK from time to time, then the transmission needs to be replaced due to some worn bearings.
NOTE: From here you must first consider three things:
A. Do I want to get into a major repair with this washer, or simply purchase a new stack set?
B. Should I call a GE repair guy and have him replace the transmission?
C. Should I do it myself?
HOW TO FIX (If you chose "C" above):
FIX Prep Step 0. Gather a bunch of old towels around to clean up any water that spills
Step 1. Empty the wash basin and disconnect all external hoses, gas lines etc.
Step 2. Arrange the stack set so that you can lay it down on its back. Always good to have two people to do this step.
Step 3. Disconnect the tub basin springs and all electrical wires from the motor (this is easier to do while the unit is laying down; some channel lock pliers come in handy)
Step 4. You can stand the unit back up for this step. Slowly remove the tub basin from the unit, and position it upside down.
Step 5. Remove the transmission (requires standard socket set)
Step 6. Order the Transmission Assembly Kit online (I found mine at SEARS PARTS ONLINE, and when I called to check if they had it in stock, the customer service rep even gave me a code for 10% off the online order - not too shabby and makes me want to go back again. Great support service!)
Step 7. When the part arrives, re-assemble everything and test.
Tub Assembly Part Number: WH38X10014 (aka. GE part # 1603 on their 'break away' diagram)
Available on
Note: The GE Parts people were unfortunately not helpful at all during this troubleshooting. In fact, when calling their support line I was told that they would not even sell me a transmission because I was not a certified repair man. The GE service rep was insistent that I could not find the transmission anywhere else except through them. Although they have nice diagrams of all the WSM2780 machine parts on their web site, don't look to them for any extended repair support.
You can contact me if you have any questions.
Thanks, Chringram
Posted on Aug 24, 2009
  • 42 Answers
If you can actually see smoke; I would recommend you DO NOT USE and clean your dryer and house exhaust/vent line, ensuring you have a fire-resistant aluminum vent line connected to your dryer. Especially, as it may back up into or near your heating/ignition system and catch fire.
If you are smelling a burnt or smoldering rubber smell, that is different. Possible washer/dryer belt/motor going out.
- C
Posted on Jan 27, 2009
How do I detach my Bosch drier from yhe stacking kit as I need to replace the drier
most model have some bolts or screws to keep dryer safe on top of washer
just remove bolts and screws and pull back the dryer
Feb 11, 2015 | Bosch Washer And Dryer Stacking Kit...
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool dryer model # WED9270XW1? If yes, what stacking kit do I need to use?
You can stack just about any dryer on any washer, so long that the controls of the washer are on the the top of the washer has no penetrations and no control.In general, dryers are independent from the washer and are light weight.
So the conclusion: so long that the dryer does not interfere with operating the washer - YOU ARE A OK :-)
Oct 14, 2014 | Whirlpool 8541503 Duet Stack Kit 8541503
I have a Frigidaire front loading washer, model FTF530FS3. The dryer that is stacked on top of it just quit. I have discovered that the new model of the dryer for this type, now called Affinity is slightly...
I would bet the manufacturer has an adapter for just this kind of problem. I did an installation on a stacked unit with a similar situation and there was an offset angle piece that attached the base of the dryer to the top of the washer. The front had a molded plastic piece to allow the dryer to rest on the front of the washer. Hope this helps
Oct 18, 2013 | Frigidaire FEQ332E Electric Dryer
I want to try to put my washer (Frigidaire FTF model) on top/bottom of my dryer (also frigidaire). However, we didnt receive any brackets which are standard for stacking, so we are curious to how to stack...
Hello the advice about removing the top of the washer and bolting the dryer to it is exactly what to do.Under the washer top is built in brackets to do that.Every front load Frigidiare washer leave the factory pre-equipped to stack the dryer to it by removing the top and bolting the dryer to it
Aug 21, 2011 | Frigidaire FTF530FS Front Load Washer
Kenmore top load stacked washer/dryer (model number : 110.98575120)
Yes - you are correct.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 03, 2010 | Kenmore 88752 Top Load Stacked Washer /...
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
Where is the model #on my Kenmore stacked unit?
possible locations
Top- or front-loading washer-dryer combination unit
  • Inside the dryer door, on the door frame
  • On the top of the dryer
  • On the side of the washer, near the bottom, front
  • Under the washer lid
  • Feb 13, 2009 | Kenmore Washing Machines
    Removal of front panel of a stack washer and dryer mod
    Their are screws between the washer and dryer. Undo those and the screws inside the dryer, next too and below the lint trap.
    Jan 17, 2009 | Maytag LSE7806A Top Load Stacked...
    Stacking Frigidaire dryer on washer using stacking kit 5303937141
    You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
    Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
    GE WSM2780W Stacked Washer / Dryer Logo
    401 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
