How do i reset my vibe mini digital pocket scale model eq100
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
SOURCE: when I turn on the pocket digital scale there are
threw it out the f____n window
Posted on Jan 17, 2010
SOURCE: mini digital scale displays out2
I just had this problem on set Salter scales (says 3309 on label on back so assume that's model no) which came up OUT2 solidly after hadn't been used for a while.
Looking on WWW this means on other scales they need to be recalibrated. There are only 2 buttons on ths model ON/Zero and 2nd is mode for grams, oz etc. Discovered by trial and error have to hold down the on button and repeatedly click the measure button as it powers up, screen says err2 press on button again and says 5000g, put 5000g weight on scales, press on button again display says CAL press on button and it at first came up with EEEE and failed but next attempt it said PASS and it all worked again. I used 2 x 1.5kg bags flour and 2 x 1Kg bags sugar to make 5kg with bit tipped out of one to make exact and checked on another set scales. So trick appears to be finding how to get your scales in to calibrate mode and what the weight it expects is.
Posted on Oct 02, 2010
SOURCE: I have a nexxtech mini
I don't have a solution - I have the same problem and can't find any place to solve it!
Posted on May 02, 2011
mrstanskaggs
  • 118 Answers
SOURCE: How do I fix a manlloro digital pocket scale when
I thinkn there is a reset button to press with no weight on the scale if I remember correctly. Might have to calibrate with the test weight too if the calibration is messed up (not likely though).
Posted on Jan 03, 2015
My digital pocket scales say over
You did not post the make and model but they have been knocked out of calibration. There may be no way to reset them. When they are turned on there is a sensor in them that is queried by the processor and there is an expected response. The response is wrong and you get the error that you stated.
Nov 26, 2017 | Pocket Health & Beauty
How do I fix a manlloro digital pocket scale when it reads HHH?
Jan 03, 2015 | Health & Beauty
How can you fix error on screen can it be reset
It often just needs recalibrating. Try turning the scale on while holding the mode/tare button with nothing on the scale. Then press the tare button again. It should show a calibration weight which you should put onto the scale. Then it automatically calibrates.
Nov 30, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Numbers flashing on my digital scales
Check to see if you need new batteries, or just remove batteries and reinstall to reset device.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
May 23, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Wont turn on tried new batteries
I have repaired 1479 model with same problem.
check the battery contacts especially the + side i found that it retracted 1-2 mm back thus not making contact
jb
Mar 06, 2011 | Tanita 1479V - Digital Pocket Scale /...
My scales i turn it on and the number keep going different and there is nothin on it
  1. First, try recalibrating the scale with nothing on it.
  2. If there is a reset button on the device, press it.
  3. Try replacing the battery.
  4. If it still acts up, it's probably time to get a new scale.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 18, 2011 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
My unit will not flash so I can calbrate.
This unit scale may need to be reset. see if there is a reset button, if not, try removing the batteries for a minute or so, then replace them with new ones.
Jan 28, 2011 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
My scale is frozen displaying f--h how do I fix this? I tried holding mode and tare and turning it onon and that doesn't work any other suggestions?
Reset it!
Turn off the scale. Press and hold the MODE button and turn the scale on. Release the MODE button you will see the scale's internal count.
Press and hold the TARE button then press (don't hold) the MODE button you will see the full capacity is changing. Keep pressing the MODE while holding the TARE button until you see 100.00 on the screen. The reset is completed. You may need to recalibrate the scale after the reset.
Nov 09, 2010 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Scale displays OUT2
you need just to recalibrate it:
The procedure is standard for semi-all models of pocket scales, but the way how to get to calibration mode differs from model to model (or vendor to vendor).
In brief:
1.While turn-on get to the calibration mode (by pressing and holding the ON button, or holding TARE while turinig on) You should hold this "magic" combination until the LCD will show a number (large number - it was more than 2000 in my case). This number is a raw data from the sensor.
2.Now release the "magic" button.
3.Press it one more time, the display will show 2Ero and then 100.0
4.Now put calibrated weight of 100 grams on the scale and wait 3 seconds.
5.Press "magic" button again.The display will show CAL and then PASS.
6.Now remove the weight and turn off the scale.
7.Thats all - now you can use your scale as usually.
Jul 26, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
23 people viewed this question
 Grubhead
Grubhead
