Question about Frigidaire FEF336BC Electric Kitchen Range
Element light is on but no heat from the burners
The element light comes on when a burner contol is turned on ,however none of the burners heat up. Also the clock is off but comes on only when a burner control is turned on. The oven also is inoperable.
  • melissa vincent Jul 23, 2007
    thank you for your help that was the problem Im sure glad i found you guys before i spent a fortune on repairs
  • 76 Answers
You only have voltage coming in on one leg of the 240 line. Either the terminal block connectors are loose or burned or you need to check the circuit breaker in the house and reset it. It is also possible that one of the wires burned off in the back of the unit between the terminal block and the clock.
Posted on Jul 21, 2007
SOURCE:
Burners and oven on Hotpoint free standing electric stove won't heat at all.
Find someone with a good electrical meter and have them test the sockets to see if there is any electricity to the burners.
Also, check each burner and check for continuity through the burner itself.
These elements can all burn out, I've see it happen.
Be blesssed.
Apr 17, 2013 | Kitchen Ranges
Our dryer stopped blowing out warm or hot air. All the buttons still work and cool air still comes. Any suggestions?
Check the heating element, burner operation, ignitor, thermal fuse, and the wiring (power cord).
  • Visually inspect your heating element for any broken or burned areas. The heating element is a coil made from a nickel-chrome alloy, called nichrome.
  • When the burner is operating properly, the flame should be clean and blue.
  • If the ignitor is cycling without the burner lighting, you probably have defective electrical coils in the gas valve. These coils look like black cylinders with wires coming out the top of them, and are located near the burner valve assembly. When they get power, they open up and allow the gas to get through to the burner. If this is a new installation, make sure the gas valve is turned on.
  • If the ignitor doesn’t glow, look for a white or yellowish discoloration, or for a break in the ignitor. If this is something visible, just replace the ignitor.
Good Luck and have a nice day.
Jun 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My frigidaire oven won't heat. The burners work
You have two elements turn on the broil and see if the top element comes on if it does replace the bottom element.
Aug 23, 2009 | Frigidaire Ovens
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
[email protected]
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
My goodman furnace (model gmp 108-3) is not working. If I turn off the unit and turn it back on the fan comes on and the little filament heats up, then the top burner will light, but it will not stay lit...
All of the burners should light. Could be a dirty flame runner. I recommend that you get a good clean and check.. Burners, flame runner, flame sensor should all be cleaned. If this does not solve your problem than the gas pressure needs to be checked.
Good luck....
Jan 17, 2009 | Heating & Cooling
I have a frigidaire #fef355asg electric range. The burners on the left side do not work. Replaced the elements , still no heat and lights do not come on by the knobs. The 2 burners on the right side work...
check for power at the burner if none there take off the top back panel and check for power at the switch coming in and going to the burner. if you have power in and not out then the switch need to be replaced (i like to change all 4 as a set). if there is no power going into a switch then trace the wire back to a broken wire good luck
Dec 11, 2008 | Kitchen Ranges
The right front burner won't heat
The switch probably failed. Remove power. Take off the top rear cover and inspect the switch for signs of discoloration (burned or brown areas). If looks OK then maybe the element failed.
May 28, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire FEF336BC Electric Kitchen Range Logo
250 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
