Question about Xerox DocuPrint N2825 Laser Printer
Toner issues for some reason the printer will not print dark enough. changed toner like 3 times still not dark enough.
If you are using generic toner it might be a big problem, if original try changing the developer assy.
Posted on Jan 27, 2009
    Sergeant:
  • 250 Answers
There r two possibilities for this problem 1)either the printersettings are not set properly.try to set all the settings on darkl mode .if not getting perfect setting.just reinstall the printer drivers again,.as reinstallastion automatically sets the printer settings to the required . 2)the other thing is that the optics lens fron where the rays gets passed on the lens which reads the cartridges is got dirty and needs cleaning. to see the picture of optics lens just click the link theimage of lens /optics of a printer
http://farm4.static.flickr.com/3104/2550956836_f1135cff1b.jpg
My Ricoh Aficio SP C420DN Laser Printer shows color tone SC366 and some time SC365, any ideas?
You just have a problem with colour PCU (SC 365 - magenta, SC366 - cyan). The main reason is that toner density is abnormal. Sometimes, when you replace toners, printer receive to much toner for a short time, and after that you have an abnormal toner density (higher). You can check in service mode (hold up and down arrows for 6-7 sec, release them and press ok button) following thing :
choose 2. engine
then with arrows choose 3. process
then choose Vt display,
for each color by default there should by somewhere arround 2.4V. If you see for some colors, for example 0.02V, then this is a problem(to much toner). In this case the only thing that you can do is to restart printer and try to print enough pages, filled with problem color. Usually you can print max 3 pages. Then restart printer and try another 3 pages. Print until the you will be able to print at least 4 pages continuously.
Good luck and remember that this is a technical problem and you should ask someone qualified for the job. I am sure that 80% of service engineers can't repair this issue. But I can.
Apr 17, 2015 | Ricoh Aficio SP C420DN Laser Printer
My Dell 1720dn mono laser printer has not printed properly for some time - in fact it's dreadful! The letters and dark images have white vertical lines going through them, and some of the printing do
Change your toner cartridge. A properly working toner cartridge will never leave that much toner lying around. The white lines are an indication that either the toner is low, or the mag roller is defective.
Dec 05, 2014 | Dell 1720dn Laser Printer
My eltron ip2844 wont print dark enough. I went into setting and turned the burn darkness to 15, but still not dark? Help!!
This may be due to your thermal paper.
This printer doesn't deliver enough heat to your paper or you have a problem with the head pressure.
Press on the bloc while printing to see if it's this reason?
You may also have a mis-alignement of the thermal head.
Try also to change the print speed?
Aug 05, 2011 | Zebra Eltron LP 2543 Thermal Label Printer
After changing toner it still has a grey spot in the middle of the page that does not print dark enough
The LED array probably needs cleaning. This is located on the lid that you open when changing the drum/toner and is a dark coloured bar going left-right across the lid. Clean this with a cloth. Also check the opening in the drum where you can see the green cylinder from the top for any small obstructions and remove if necessary. Any obstructions or dirt on the LED will line up with the print defect on the page and should be easy to remove. Be careful not to damage the green cylinder.
Dec 28, 2009 | OKI B4250 Led Printer
Printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
My hp 1200 printer is not printing dark enough. this problem just started/ I can barely read the print. MY hp 1200 printer is not printing dark enough I installed a new toner cartage but it still does the...
If you have installed the toner cartridge correctly then it is a hardware problem called the Fuser and is the most common problem with printers...the fuser is a part of the printer which actually melts the toner onto the paper. The fuser has to get up to a high enough temperature to be able to melt the toner, if it is malfunctioning then it cannot give you a dark print. You may search google for Fuser information: Recommendation is change out fuser to repair problem. Pls rate this solution.
Apr 20, 2009 | HP LaserJet 1200 Printer
HP 4100N Printer prints too light.
Hi hooperengrg:
I have worked on hplj4100's for years and have ran in to this plenty of times.You will have to have the laser motor mirrors cleaned.That means removing the top cover and cleaning the toner and paper dust build up that has accumulated on the laser motor mirrors that is preventing the laser light from a 100% unobstructive scan to the photo-conductive drum inside the toner cartridge. I hope that this helps
Paul
Mar 25, 2009 | HP LaserJet 4100n Printer
Bad photo quality after changing drum
your laser printer
1) print color quality is now distorted that means print skew (technician called)
2) print tint means the print color not enough density,
3) print mottle means print dirty
you may try
1) print distorted--- find out the skew adjustment from your printer manu, it is adjust the image before transfer to the drum.
2) print skew could be happened when the drum replace install not very accurate, so install it more carefully.
3) print tint---you may increase print density from the manu, not fix,
4) print tint---the toner caridge near life cycle or using the less compatible toner. so you have change the quality toner or cartridge (if near life cycle) to improve quality photo print
5)print mottle---toner quality ? or cartridge near life cycle also cause print dirty paper,
Feb 08, 2009 | Konica Minolta magicolor 2300DL Laser...
Xerox DocuPrint N2825 Laser Printer Logo
88 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
