Question about Nordic Track iFIT Performance Treadmill Workout Cards
Black rubber powder off treadmill belt - Nordic Track iFIT Performance Treadmill Workout Cards
What lubricant to use for the belt?
you have to use Teflon silicone lubricant. Also check the video to know how to lubricate the treadmill belt
www.electro-medical.blogspot.com
Oct 30, 2015 | Exercise & Fitness
How do I lubricate the walking belt ?
Video about How to Lubricate a Treadmill using Liquid Lube
  • This video will demonstrate how to properly lubricate your treadmill belt and deck. This demonstration is for the application of liquid lube.
  • To begin, clean the deck and belt by loosening the rear roller bolts 10 turns as seen in the video. It is best to loosen each side five turns and then repeat the process.
  • Now that the belt is loose you can take an old towel and place it under the belt as shown in the video. Move the towel up and down the deck, then using your hands pull the belt around half way to ensure you have completely cleaned the back of the belt. Then remove the towel.
  • Open your lube packet and use half of the package to make a half circle on the deck, from the front outer portion of the deck toward the center and then back to the outer edge. Use about half the package for this arc. Now repeat the process on the opposite side. Be sure to wipe up any excess oil as it is very slick!
  • Use your hand to move the belt around some more to begin spreading the lubricant out.
  • Now tighten the rear roller bolts back to the exact amount of turns they were loosened previously.
  • Power on and start the machine; let it run slowly for a few seconds to make sure the belt is staying aligned in the center of the deck area. If it is not centered correctly, make minor adjustments to correct the issue. Tighten the left bolt to move the belt to the right and tighten the right bolt to move the belt to the left. Now walk on the belt for a minute or so to fully distribute the lubricant.
  • This concludes today's demonstration of how to lubricate a treadmill using the liquid lube.
How to Lubricate Treadmill Using Liquid Lube Video Video about How to Wax a Treadmill Using Powder Wax
  • Our video demonstrates how to properly wax your treadmill belt and deck. This video will be about applying the powder wax.
  • To properly lubricate or wax your belt and deck you will first need to clean between the deck and belt to remove any contaminants.
  • To do so, begin by loosening the rear roller bolts 10 turns as seen in the video. It is best to loosen each side five turns and then repeat the process.
  • Now that the belt and deck has been cleaned; Open your wax bag and using approximately a teaspoon, place the wax on the deck as seen in the video. Now repeat the process on the opposite side. Be sure to wipe up any excess wax as it is very slick!
  • Use your hand to move the belt around some more to begin spreading the wax out.
  • Now tighten the rear roller bolts back to the exact amount of turns they were loosened previously. Remember to tighten only half way on each side then repeat the process.
  • Power on and start the machine and let it run slowly for a few seconds to make sure the belt is staying aligned in the center of the deck area. If it is not centered correctly, make minor adjustments to correct the issue. Tighten the left bolt to move the belt to the right and tighten the right bolt to move the belt to the left. Now walk on the belt for a minute or so to fully distribute the lubricant.
  • This concludes today's demonstration of how to wax a treadmill using the powder wax.
How to Wax Treadmill Using Powder Wax Video
Dec 07, 2014 | Exercise & Fitness
Lubricating walking belt
How To Re-Wax a Wood Deck for a Trotter Treadmill
How To Re Wax Wood Trotter Treadmill Deck
Video of How to Lubricate a Treadmill using Liquid Lube
Apr 02, 2014 | Exercise & Fitness
Makes a loud rubbing noise on one side
To be honest with you, these could be symptoms of a few different problems. Here are the most common ones and what it possibly sounds like:
1) It could be that the front roller has dislodged itself from the roller pulley. In other words, the motor keeps turning, and when you step on the walk belt, the pulley (the one with the small rubber belt) keeps turning, but the roller stops. This can cause grinding noises, and the pulley to "skid" the black belt, which can account for the black dust. You can usually tell this is the problem when it runs fine with nobody on it, but when you step on it, it grinds
2) It could also be that the walk belt is rubbing on the sides of the deck and/or side rails. This happens when the belt shifts over from the center. It would definitely sound like a grinding noise, and the black dust could be from the walk belt particles wearing down due to the rubbing.
3) It could also be the drive motor brushes. Let me explain. The motor has two small blocks on either side of it (inside the metal casing). Those two blocks actually carry electricity into the spinning part of the motor (called an armature). They actually make contact with the armature at all times while it spins. Those "small blocks" are made of a graphite (what pencil lead is made of). Well, with so much spinning, and so much contact from the armature, those things grind down with time. They sometimes grind down until they are stubs only. Then they start grinding. The powder in this case would be the brush graphite piling up (this would often be shiny dust, and is a dark grayish).
4) The grinding could also be roller bearings going bad.
**For #3, and 4 above, you have but to remove the small belt that attaches to the motor (rubber, black, and small attached to pulleys), and let the treadmill run for a few seconds by itself. You may get a "speed error code' after the treadmill does not detect speed, but at least you'll know if the grinding is coming from the motor. If it runs super quiet, even for a few seconds, then you know it may be #1, 2, or 4 above.
These are the most common issues based on your symptoms.
Mar 16, 2014 | Bowflex TreadClimber TC5000
The belt on my proform 680LT has an excessive amount of rubber powder rubbing/shedding off. It makes a mess.
Is it rubbing off the sides of the belt? If so, adjust the lateral movement of the belt with the hex bolts at the base of the treadmill. If not, you may need a new belt. See Treadmill Parts
May 03, 2011 | Proform 680 LT Treadmill
Belt was slipping (sticking) lubricated underneath belt with silicone purchsed from fitness centre and now it appears belt not only sticks but suddenly surges forward. I took paper towel and wiped...
check the tention on the w/belt.after that check the drive motor belt if you find lots of black powder your belt is worn out. it dose not have the grip to move the front roller
Feb 27, 2011 | Proform Exercise & Fitness
After storage treadmill belt wont' turn
Hello. A year without use often causes the belt to adhere to the front and rear drum. Pry the belt loose and toss some talcum powder in there to get it going again. Joe
Mar 21, 2010 | Dmm Vision Fitness T9500 Treadmill
My treadmill has been running fine until recently when i was on it the running mat starts chugging. I have tried loosening and tightening the tension but with no success. What else might it be.
Depending on the age and use, the belt's wearing out. You can try some talcum powder under the belt. If there is any sticky buildup, the talc will pill it up and it will come out the bottom.
Nov 05, 2009 | Reebok Vista Treadmill - RBTL13305
The track of our image 19.0r treadmill slips when it's up at 6-10 mph. I just replaced the belt because I thought that would solve the problem, but it didn't. Help please!
I had the same problem..the fix was easy. Remove the cover from the motor area, examine the belt(its on the right). My belt was simply loose. I took a wrench (1/2 or 9/16 I think)...loosened the bolt, wedged the motor so that the belt was tighter, and tightened the bolt. Volia. Cured...Good Luck.
Oct 15, 2009 | Icon Treadmill
A scratching noise
One, or both drum idler wheels has failed, the noise is the drum shaving rubber of the now stationary wheel.
Belts and Idlers are a standard item that fit many dryers, and your local parts guy has them on the shelf.
Replace both idlers and the belt at the same time, the other wheel and belt will fail soon cause of the extra load, and they are both as old as the first one, and you dont want to pull the dryer apart twice.
Jan 16, 2008 | Hotpoint NLL113EYWO Electric Dryer
Nordic Track iFIT Performance Treadmill Workout Cards Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
