Question about Toshiba 61HX70 61" Rear Projection Television
No picture/no sound
I came home one day and turned the TV on and it had nothing, no picture and no sound. This is the first time that this has happened to this TV which is almost 7 years old BUT it did have the blinking red light issue which I fixed by unplugging the TV for awhile, the problem would come back every now and again and when it did I would do the same thing unplug it and wait then plug it back in. I took the TV apart hoping it would be something as simple as a fuse, I only found 1 fuse and it was located by the power cord it looked good, and since I am getting power I figured that couldn't be the problem. My knowledge of electronics is VERY limited and as of right now so is the repair budget so any help would be greatly appreciated.
  • Danny Crum Jul 26, 2007
    I had a repair man look at it today and he told me that the "IC fuse was open on 3 resistors burned up est cost to fix would be $400. HE said that it was an unusual place to have problems and it looks as if a possible lighting strike might have caused the damage. He said if thats the case the problem could be much worse and end up costing upwards of $1000 to fix.
    My question would be does this sound right and if so is the $400 price reasonable??
  • 41 Answers
If you have the ability to remove some of the connectors to the main chassis & flip it over so you can see the chassis from the bottom, inspect the solder connections around the power supply and near the high voltage..the flyback area, you could have a cold , cracked solder joint or several of them due to age of the tv. Use a magnifer & bright light to try & spot them, resolder & put the chassis back together, see if this helped.
Posted on Jul 22, 2007
SOURCE:
Sound but no picture
Hello!
Does sound comes out of TV speakers? Or you have "home theater" hooked up to?
In first occasion: TV turns on, stays on, display blinks once, then nothing?
Inverter is at fault. Second occasion: TV turns on, stays on, display glows dark, sound OK, no picture: T-con board at fault. Third occasion: TV turns on, shuts off, sound is coming through "home theater"-OK. Power supply or inverter, or T-con are at fault. TV need major diagnostics and repair in every case. Let me know if you can handle that. Will guide you through the process.
Thanks,
Alex.
Dec 15, 2011 | Toshiba Televison & Video
Sound no picture, picture;no sound
a panasonic tv will shut down after a short time with no video input. it sounds like the setup menu in the receiver has defaulted and needs to be setup again to coordinate the audio and video signals. ive seen many yamaha menus default. dont let geeks in your house.
Nov 03, 2009 | Yamaha RX-V663 Receiver
RCA 61" SOUND NO PICTURE HDTV
Contact a Technician to check your HV section of your TV, sometimes the heater on CRT have no supply.
Jun 01, 2009 | RCA P61940 61" Rear Projection Television
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
standby button blinks no picture no sound have tried to reset and restart nothing has worked to get tv to back on
Mar 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
have a 42 inch rca 42PA30RQ NO PICTURE OR SOUND WHAT CAN I DO MY SELF BEFORE SPENDING A LOT OF MONEY TAKING TO A REPAIR SHOP
Dec 14, 2007 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
Picture turns off still have sound
I have the exact same problem with my tv. Unfortunately, I'm not sure what is wrong or how to fix it either. I notice your post is from July. Have you found a solution since then? - Sarah
Jul 30, 2007 | RCA HD50LPW175 50" HDTV
Toshiba 61HX70 61" Rear Projection Television Logo
367 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
