Question about Emerson Audio Players & Recorders
Where can i find a replacement transformer for an emerson radio model es16
Radio was manufactured in 2001, looking to replace the transformer to get it to work. Part #: E201615 LDW 48-50H1 Cannot find any websites that have info on replacement parts for this.
hawkwatcher
  • 67 Answers
SOURCE: Bose Wave Radio/CD Model AWRC1P
Yes There is a pigtail fuse in unit. It solders to main board. In order to replace you have to pull main p.c.b to get access to bottom of board.
Posted on Jan 18, 2008
SOURCE: Emerson Home theater system
I was just given the number to Funai 1-800-256-2487 you can call them and ask but they couldn't find this model number in any of their sources and I have been referred to contacting Sears., the place I bought it. He said they should be able to help.
Posted on Oct 17, 2008
SOURCE: 2001 dodge stratus radio
I researched and found I needed to reseat or replace the IOD fuse. In my Dakota this is labled "Interior Lights". By pulling this fuse it allowed the radio to reset and everything came back. Hope it works !
Posted on Feb 15, 2009
emissionwiz
  • 77186 Answers
SOURCE: Battery replaced on 2001 grand dodge caravan now radio dont work
U will need to enter the radio anti theft code, this lock out was triggered by the loss of voltage to the radio during the battery change, this code is unique to each radio and cam in the owners information packet when the cat was sold new.
Posted on Apr 13, 2009
SOURCE: Blown transformer
I also have the GPX under-counter TV, same problem. I believe the transformer is AC-AC, because both wires out are red... I actually have two of these units, one doesn't work at all, the other has enough power to play the radio, but not the TV. I swapped the transformer from 1 into the one that was completely dead thinking #1 had a bad tuner, but the same symptoms exist now in #2, making me think that one transformer is completely gone and the other is malfunctioning. I'll try the VX 79NP on both and try to remember to post the results back here....
Posted on May 04, 2009
Replace light bulb in emerson projector alarm clock
Make sure of the model.
Bulb Replacement The flashlight in this unit use LEDs (Light Emitting Diodes) instead of incandescent bulbs. These LEDs should last for the full useable life of the product and they are not consumer replaceable. There are no user serviceable parts inside this radio. Please refer all service problems to a qualified service facility
http://www.emersonradio.com/resources/owner_manuals/manual_1312918603.pdf
Dec 04, 2012 | Emerson Smartset Clock Radio
Where can I get a replacement antenna for a Emerson weather radio model # 6250
Due to the value of this item there are no Direct Replacement Spares for it.
I think your only option is to find an equivalent from the likes of eBay.
Search for FM Telescopic Antenna.
Apr 28, 2011 | Emerson RP6250 AM/FM/Weather/TV Radio
E190246 Transformer Power ? Secondary Voltage ?
The transformer that i had. PN: E190246 Mfr: HF-4822L2TN (single in/output) (ie... two wires in and two wires out)
(Hang Fung Eletronic Ltd.) has a 42.2 vpk >15watts
(power supply for an Emerson 4 in one Entertainment system
(record, CD, cassett, radio)
Emerson Model: NR305TT 19watt
Found info here http://www.olilio.com/file/detail/FQGS2.E190246.html
I hope this helps somebody..
wildhoss109
Apr 25, 2011 | Teac DC-D2831 CD Shelf System
Power transformer appears bad. What is the ac voltage out of the transformer?
Check the part number on the transformer: the link at the bottom may help it if it is listed there..The transformer that i had. PN: E190246 Mfr: HF-4822L2TN (single in/output) (ie... two wires in and two wires out)
wildhoss109
Jan 15, 2011 | Emerson NR303TT CD Shelf System
My clock radio CK5250 was plug to a 220 voltage and no longer work. what would i do
If you mean a US 120 volt clock radio was plugged into 220 volts -
it's shot - not to be fixed
Dec 10, 2009 | Emerson Audio Players & Recorders
My Emerson clock radio was manufactured in 2001. Model #CKS2000N; S/N10339233BA. Need to set clock for DST. I do not have a "month" year button - only a "time" year button. Can you help? Thank you
For this model Clock radio you will have to call Emerson Customer support at this telephone number.1-800-909-1240 between the hours of 8am-4:30pm CT. Tell them the make and model number of your Clock/Radio and ask them for assistance. You will probably be told that,your Clock/Radio has no updating feature. This is because at that time there was no need for such a feature. The best way to get the new features is to buy a new Clock/Radio. Thank you for using FixYA and have a nice day.
Mar 05, 2009 | Emerson Smartset Clock Radio
I have an Emerson Smartset Clock Radio (CKS1862) and it doesn't
This Clock/Radio has had a problem with component failure. Since Emerson doe not support out of warranty repairs, you will not be able to get it repaired. Due to the low production cost of these short production run products, parts and service information are usually available to the manufacturer and service centers only. This mean that there is no parts and service information for independent repair shops. Even if you could get it repaired it would cost more than purchasing a new Clock/Radio. Thank you for using FixYa and have a nice day.
Jan 25, 2009 | Emerson Smartset Clock Radio
I have a 2001 Acura CL S-type, I took out the radio to install a converter, the fuse had blew out so replace and now the radio screen keep saying code, I need the code to unlock the radio.
Assuming your radio is the original for this vehicle you simply take your vehicle ownership and registration papers to the workshop of your car manufacturer and they can get the code from the Ford computer network on the spot.
If the code does not work then it means that this radio is not the original for your car as it would have been replaced with them radio model.
If your radio is an after vehicle purchase, you may need to contact the radio manufacturer.
Or get their contact details through your local car audio dealer.
Sep 16, 2008 | Car Audio & Video
EmersonResearch Smart Clock Radio
Sorry it took so long to reply to your question. [http://www.mysimon.com/9000-11681_8-0.html?sdcq=keyword-emerson+ckw2000] Copy this web page link and paste it into the address bar of your web browser. It will take you to a web page selling this new model of Clock/Radio, you can look at the Clock/Radio and check the features before you buy it. The replacement model appears to be CKW2000 Emerson Clock/Radio. This Clock Radio can be purchased at Target stores. I hope this information helps you find the new Clock/Radio you are looking for. Thank you for using FixYa and have a nice day!
May 20, 2008 | Emerson Smartset Clock Radio
Bose wave radio does not turn on
Considering that power is present and all fuse are OK, check R406 for open. Check for Q401 also, the 5V supply to display.
Hope this will help.
Dec 01, 2006 | Bose Wave Radio
49 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
