Question about Frigidaire Refrigerators
Noise in side frig up left corner model #frs6lfjso sounds like fan hitting something
  • 184 Answers
SOURCE: LG Fridge making intermittent sound - like something hitting fan
GAIN ACCESS TO THE FAN IN THE FREEZER(EASIER SAID THAN DONE) AND INSPECT THE FAN BLADE AND FAN SHROUD. HAVE REFRIGERATOR TURNED OFF AND MANUALLY ADVANCE FAN BLADE. WATCH FOR SLIGHT CONTACT BETWEEN THE FAN BLADE AND OTHER OBJECTS NEAR IT-ELECTRICAL WIRING, FAN SHROUD, ICE CYCLE,ETC. ADJUST FAN BLADE OR OBJECT TO INCREASE CLEARANCE.
Posted on Mar 27, 2008
  • 112 Answers
SOURCE: Freezer and frig is not working
I would start by pulling it out, removing the lower back panel, and see if the compressor is running. It is the black ball on the left side. If it is not running, check voltage at the two wires at the compressor. If there is voltage, try a new overload/relay kit. If there is no voltage, try a thermostat. If the compressor is running, check the evaporator behind the rear freezer panel to see if it is frozen solid, if it is, replace the defrost timer.
Posted on Oct 27, 2008
lojacksdad
  • 121 Answers
SOURCE: Kenmore side by side - sounds like a fan or motor problem - on freezer side top left as you face the fridge behind ice maker, buzzing sound like a bad motor or fan - freezer working fine but noise dri
that,s your evaporator fan motor remove back panel
to expose fan repair cost about 150.00
Posted on Apr 29, 2009
  • 245 Answers
SOURCE: noise vibration
if you take the back panel of the freezer out you can get to the condenser fan they do have a habit of going bad and actually having the fan and shaft move forward on them usually when you start hearing the noise it is not long before it goes out completely.
Posted on May 15, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Posted on Sep 13, 2009
Fan making clanking noise like it is hitting something the part seems to be located in the lower left front passenger side
sounds like blower motor fan for heat, the motor itself can be going bad or something is hitting fan blade inside heater box, I have seen all different things in heater boxes including acorns , leaves and general debris causing noises when fan for heater runs, you need to take it apart and check for anything that might be hitting fan if not motor is going bad and needs replacement, good luck.
Apr 04, 2015 | 2005 Dodge Caravan
My whirlpool side by side refrigerator just started making this loud noise that sounds like either what an air compressor would sound like or a lawnmower. The model is ED5FHE
There are two fans running on a side by side, one is behind the back freezer panel on the side of the freezer side( if it is iced up the fan blade could be hitting ice) May be a defrost problem......
(this fan circulates air from the freezer side to the refrigerator side, as the air is pulled through the coils heat is removed)
The second fan is in the back, you have to pull out unit and remove lower back panel to listen and or look to see if condenser cooling fan is running quiet or the compressor right next to it. Could be this fan blade is hitting something or a bearing going out.......
If the compressor is making the noise you are probably not going to repair it.....
Lastly on some there is a defrost timer motor usually found by the thermostat but not always that could be making noise(least likely) May have a adaptive defrost control board, not sure.....
Hope this helps........
Feb 08, 2011 | Refrigerators
Laptop recently started to make noise on start up, feels and sounds like it's coming from the area below the keyboard in the lower left part, it's an acer aspire 5570-2067. it makes noise for a while, then...
Def sounds like the fan , from where you say the sound is coming from . normally the fan should be able to be cleaned the panned holding the fan in the left hand corner . clean the fan with compressed air , or a paint brush . if this fails then you need a new fan .
Nov 23, 2010 | Acer Aspire One PC Notebook
I have a kenmore elite side by side bottom freeze frig.There is a huming noise coming from the frig.sounds like the compressor. The freezer is starting to frost over. I can make the noise stop by opening...
Hi and welcome to FixYa. I am Kelly.
The humming noise your hearing is the evaporator fan blades striking the ice build up on the evaporator. The fact that you have ice build up is a sure sign your refrigerator is not defrosting.
The door switch controls power to the evaporator fan.
I am going to use this model number 106.57071791 as a parts reference that MAY be different from your actual model but it is close. This model is a mechanical control refrigerator. You may have the electronic control version.
Take a look at item 6 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657071791/0582/0165000/P8100197/00012?blt=06&prst=&shdMod=
It will be located in the top left of center & front of your fresh food compartment. It will be circular and will have 2 tabs on it with an incline so that if you were to rotate the tabs with something flat it would only turn ONE direction.
Either use your finger nail or something flat to SLOWLY rotate that until you hear an audible click. (Everyting stops but the lights) This is initiating an automatic defrost cycle. After about an hour come back and check to see if your refrigerator has re-started. If it has not restarted there is definately a problem with the automtic defrost circuit. That can be the timer (listed above), The defrost element under the evaporator, the Bi-metal thermostat on the evaporator or wiring.
All parts can be found via this link / section
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657071791/0582/0165000?pathTaken=
If none of the links work go to http://www.searspartsdirect.com and enter your model number where it says find it fast and choose model search.
I guessed at the model number so if this does not resemble your refrigerator or you have the electonic control board type refrigerator please respond with your model number.
Thanks for choosing FixYa,
Kelly
Oct 09, 2010 | Kenmore 53642 / 53644 Side by Side...
Refrigerator side makes noise, not getting cold
I have same fridge freezer & luckily a extended warranty, engineer has been out on numerous occasions & the motor is getting freezed up, which is why the noise stops when the door is opened. Get rid of it! No solution to the problem...its a faulty appliance & a well known fault with this model or so I have been told. Good luck.
Aug 26, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Noise vibration
May 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Whirlpool gold frig
The fan might be hitting something.
Apr 21, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Samsung Frig noise
the soiund that you hear is probebly one of the fan motors. Have ypou ever cleaned the condenser coil on this refrigerator like your suppose to do? take the back poanel off and with a long brush that you can get at Home Depot clean off the coils in the back and the fan blade then vaccum it all out. Be sure to replace the panel when your done because if oyu don't the fan will npot pull the air across the coils right.
Feb 06, 2009 | Samsung Refrigerators
Load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jenn-air refrigerator model #jcb2389grs
You need to replce the adaptive defrost control that is located in the refgerator section of the unit . it is the upper right hand corner of the contols you must disasemble to find it . you must also defrost your freezer
Aug 17, 2008 | Kitchen Ranges
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
