Question about Brother MFC-9420CN All-In-One Laser Printer
Brother MFC-9420CN printing & copying very faint
Thought the problem might be the OPC belt, but fixed that with the 1&7 trick.
Seems I have 0% life on the PF Kit 2. whatever that is - is it relevant?
  • justin289 Jan 29, 2009
    Thanks for the feedback - how does the paperfeed kit affect the faintness of the printing? Could it be anything else?
    OK, thanks. I'm getting the technician to replace the PF Kit & I'll let you know the result.
    Genius:
  • 1,550 Answers
PF Kit2 is paper feed kit. You are right you need to replace it .
Posted on Jan 28, 2009
  • SAM ANDERSON Jan 29, 2009
    Since the paper is not feeding properly the colors are off a little bit.
    This affects the printing .
How do I reset the OPC belt on MFC-9420CN using the menu?
hl-2700" OPC Reset
press GO and "+" at same time
press "+" until OPC BELT appears
press "SET"
that will reset the counter on the expensive OPC.
Since the "MFC-9420CN" is build on the same chassis and engine, the "OPC belt reset for the 9420CN" is as follows:
Press 1 and 7 at the same time
Press 1 to reset the life counter.
Oct 20, 2010 | Brother MFC-9420CN All-In-One Laser...
OPC belt is replaced and has 100% life but the OPC
make sure all components are properly seated. also try turning the printer off and waiting a few minutes and turn back on.
Aug 19, 2009 | Brother MFC-9420CN All-In-One Laser...
MFC-9420CN All-In-One Laser Printer Install OPC belt message
Perhaps your OPC belt is at the end of its life and needs replacing
Apr 07, 2009 | Brother MFC-9420CN All-In-One Laser...
Brother MFC 9420cn printer message
Check to make certain that the OPC belt is both seated correctly and that it is not damaged as even though it may have what you consider to be sufficient life left in it, if damaged, it needs to be replaced.
OPC Belt needs replacing
Try pressing 1 and 7 at the same time
The LCD will show "OPC belt 1. Reset 2. Exit
Select 1 to reset the life counter.
This is supposed to be done when replacing the drum unit...but I've found that I can get 1.5 to 2 lifespans from a single unit.
Jan 31, 2009 | Brother MFC-9420CN All-In-One Laser...
NO OPC BELT on MFC-9420cn
The opc sensor is not sensing the belt. Open the front cover and remove all the toner trays. You will see the green OPC and the sensor is located in the left upper corner. Also open the top cover and remove the OPC. Clean the sensor with a soft bristle brush. Also make sure the OPC left side is free of toner deposits. This may incorrectly trigger the OPC position sensor. Hope this helps.
Jan 14, 2009 | Brother MFC-9420CN All-In-One Laser...
Loud and Grinding noise
I had the same problem, except my 9420cn is just over 1 year old. The parts life section says everything has atleast 75% of it's life left. I checked the toner cartridges and found the gear on the cyan cartridge was jammed.
I replaced it and no more noise....
Mar 28, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother MF 9420CN is asking for troubleshooting and routine maintenance 'unable to print'
Via the control panel (This is a Factory Reset)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN and press Set or Menu/Set.
  4. Press up or down navigation key to select Factory Reset and press Set or Menu/Set.
  5. Press 1 to select "Reset".
  6. Press 1 to select "Yes".
  7. The machine will re-start, re-connect cables once this is complete.
Jan 21, 2008 | Brother MFC-9420CN All-In-One Laser...
MFC 9420CN
As far as the OPC belt - don't replace it until you start seeing ghosts and image defects! Reset it by:
Jan 03, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-9420CN All-In-One Laser Printer Logo
158 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
