Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Cold garage interferes with top freezer keeping cold enough
I have a kitchenaide KTRA22EMWH01 in a garage that will not keep the freezer at 0 F when the unheated garage gets cold. is there a kit to address this so the compressor cycles on to cool the freezer more often?
  • peyton thompson
    peyton thompson May 11, 2010
    To my knowledge there is no kit available for the kitchenaid refrigerator to adress this problem. I will do some looking around and see if I an come up with something for you..
  • 410 Answers
Sorry it took awhile but there is not a cold area kit for this refrig available. it needs to be used in a controlled climate so that the controls will operate properly thanks for your patience. Peyton
Posted on Jan 31, 2009
How do I keep my refrig/freezer from defrosting in the winter when store in the garage.
There is only one source of cold in many refrigerators. If yours is a top freezer, then most likely it is in the freezer.
But the thermostat that you set temperature with is in the refrigerator, not the freezer.
In the cold garages, what can happen is that the refrigerator stays cold enough that it does not call for cold. So the freezer does not get enough cold.
The freezer control works by diverting cold air into the freezer WHEN THE RERIGERATOR HAS TURNED ON THE COOLING. If it is not turned on, oh well.
The best you can do for this is to put both on max cold. Then the refrigerator will call for more cold at a lower temperature, and the freezer will get it more often and will divert more when it is cooling.
This can result in the refrigerator freezing things too. You can try raising the refrigerator setting JUST A LITTLE and see if both work, but keep freezer on max cool.
This works for my situation, but ambient temperature fluctuations in the garage make this dicey. We don't put things like lettuce in the refrigerator in the garage in the winter because freezing damages them.
Good Luck
Feb 05, 2015 | Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Our Kitchen Aid Refrigerator Is not getting cold enough to keep our food cold,What could be the problem and how can I fix ie myself?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 25, 2011 | KitchenAid Refrigerators
K68625FJBL01 KitchenAid Sidebyside Refrigerator Freezer compartment was not cold yesterday so I cleaned the dog hair off the coils and the freezer is still warm and fridge side is not cold enough now. ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 29, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
I recently had to throw away some questionable food that had partially thawed in the freezer cabinet of my kenmoore, model# 253.67882508 fridge with freezer on top. i keep this fridge in my garage and in...
probably,there is a garage kit available that willallow it to work at colder temps,listed in owners manule under accessories the thermostat senses refrig compartment temps.soif garage temp is below 40 or so the thermostat just doen't turn the unit on enough or not at all
Jan 17, 2010 | Refrigerators
Fridgedaire freezer not staying cold. I can
did anyone help you with this problem? i have a similar problem but my freezer works fine in the summer. it does not stay cold enough in the winter. i keep the frige in my garage as a spare but it's not very helpful when it doesn't work! a repair person told me it was too cold in my garage for the freezer to work...not sure why, the frige part works fine. i'm looking into a blanket insulator from appliance zone to see if that will help.
Jul 25, 2009 | Frigidaire FRT17B3A Top Freezer...
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
Ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Feb 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator in garage
Yes it is very possible that exactly what you are describing can be happening. Also try a thermometer frozen in a cup of water to get more accurate temps. Also 33 in the fridge is very normal for the cold control set on max and the heater installed. Let me know the temps in the frz with the thermometer sensing product temp not air temp which fluctuates often.
Dec 22, 2007 | Frigidaire FRT21P5A Top Freezer...
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
487 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
