Question about Singer 3116 Simple
Hand wheel will turn backwards, but not forward
I have a new singer 3116 and the hand wheel works fine as long as your turning it backwards. But when you turn it forward it lowers the needle but when it gets to the bottom the hand wheel stops turning.
  • 3 more comments
  • Anonymous Jan 27, 2009
    I have the same problem and i have only used this twice. No one knows how to fix it my mom nor my granny. Somebody please help!!!!!
  • adam_658 Jan 27, 2009
    Hey I just watched the dvd that came with the machine, and anyway the problem was the clutch was engaged. I don't really know what that means, but if the guest who was having the same trouble wants to email me, I can give a better explanation.
  • 81georgia Feb 23, 2009
    I have the same problem. I have used the machine approx. 4 times. Any ideas? I have had several singer machines through the years and never had this problem.
  • call2humanit
    call2humanit Jun 17, 2012
    I just had the same problem, and lo and behold it was the bobbin winder shaft was pushed to the right i.e for when you're winding the bobbin. So you guys can check that out cuz i just spent an hour reading up solutions to a similar problem and it was that easy :S
  • Anonymous Mar 22, 2014
    Can't turn hand wheel
  • 65 Answers
Here is some troubleshooting
Download your manual.
Ok I know that youve checked this, but I have to ask.
Pg 39
Check and make sure the reverse lever isnt engaged.
I'm looking at pg 27 and see you have a traditional bobbin casing (not a drop in) make sure your bobbin is wound well and the case is inserted correctly. (they are picky)
Change your needle make sure its in right and tight. (I have bent many a needle just slightly, and it causes huge issues with this particular type of bobbin casing)
Pg 35 gives a test for the bobbin tension. If your thread rolls, the tension is too loose, OR the case may have gotten damaged.
Lets see if this helped.
Good luck
Posted on Jan 27, 2009
  • Michaelle
    Michaelle Jan 29, 2009
    I am glad your able to sew again.
    Happy Sewing!
My hand wheel will work manually going backward but not forward
then the machine needs to be taken to repair shop and timed bobbin and needle are not in sync anymore
Oct 21, 2015 | Singer Sewing Machines
I can turn the hand wheel backwards and the needle goes all the way down but if I turn it forward it only goes half way down,why?
It could be a matter of timing. Try taking the needle out and then turn the wheel forward. Using the foot pedal without the needle will give you an idea as to how much off the timing is. It might just need to go to a machine mechanic.
Sep 05, 2014 | Singer 3116 Simple
I need to know how can I unlock my sewing machine
When you say unlock. i suspect you have a thread jam. Remove the needle, bobbin case and rock the hand wheel backwards and forwards. It may need lubrication internally.
Aug 27, 2013 | Singer 3116 Simple
hand weel drive parts
Aug 15, 2012 | Singer 3116 Simple
Hand wheel turns bobbin but not presser foot
it needs to be checked by a sewing machine repair shop to see what wrong with it
Jan 28, 2012 | Singer 3116 Simple
Whenever I press the petal, I can hear the machine but the needle doesn't go up and down. I try to turn the hand wheel, but it won't turn counterclockwise. I have no idea what to do!
Hi - The bobbin holder (on top) has two positions. Back (toward the wheel) and forward (toward the head). Try moving the bobbin holder forward. Moving it forward will cause the motor to engage. Good Luck.
Aug 18, 2010 | Singer 3116 Simple
Turned the hand wheel the wrong way (clockwise) and I threw off the timing of the machine. How can I re align the machine? It's a Singer Simple 3116 18 stitch.
I think that all you have to do is put a new 80/12 needle in,that is what they set the timing with, and clean your machine thoroughly, take out your bobbin and brush the area. I do not think that it is your timing from turning your wheel the wrong way,
Jul 06, 2010 | Singer 3116 Simple
Sewing machine arm wont come down
You need to remove bobbin case and turn hand wheel backwards and forwards by hand till needle comes up and remove race hook cover and hook....remove all thread remands.. and reassemble.
Apr 01, 2009 | Singer 3116 Simple
Hand Wheel Won't Turn
The "Bobbin stopper" is in the incorrect position. It moves from side to side in a switch like motion. In one direction, it locks up the machine. That is, you can turn the wheele backwards, but not forward.. The bobbin stopper can be found in the book that cam with the machine. In our book, it is item #9.
Mar 12, 2009 | Singer 3116 Simple
Needle jams and breaks off
Needle jams....Thread is caught in the hook...solution...Remove the upper thread and bobbin case,turn the handwheel backwards and forwards by hand and remove the thread remands.
Needles breaks
1. Needles is damaged..Insert new needle
2. The needle is not correctly inserted....insert flat side towards the back
3. Wrong needle size for the fabric...Choose a needle to suit the thread and fabric.
Mar 24, 2008 | Singer 1116 Mechanical Sewing Machine
Singer 3116 Simple Logo
1,201 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
