Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool model ed5lha ice maker not making ice
catriver
  • 878 Answers
SOURCE: Ice maker sotp making ice / red light blinking
J, As you open the freezer door the LED on the right should flash 2X with a pause repeatedly. When you hold the left side emmiter down the light should stay on steady. If you have this, you know the optics are good unless the ejector blades are not home. First thing to check is where the ejector blades on the ice maker are parked. They should be resting in the 2:00 position. If they are not, you could have a broken module. If they are in the 2:00 positon the next thing to check would be the fill tube. You want to make sure it is not frozen over. You can disconnect it from the back and see if you can blow through the line or visually inspect it. If all of the above mentioned check out, jump start the ice-maker. Remove the quarter inch screw holding the harness cover on the right side. Remove the harness cover. Pull the ice-maker straight out but be carefull not to smash the emmitter flap on the left side. Leave the harness connected. Get a jumper wire with the ends stripped apout a 1/4 inch. Unplug the refer and place the jumper in test holes T&H. Leave the jumper in and place the ice maker on the shelf where you can close the door. Close the door and plug the refer back in. Wait 30 seconds and open the door. The ice maker should be cycleing. Pull the jumper and place the module cover back on. Put the ice maker back in the rails. It should fill at approx the 12:00 position. Let me know how you make out. Catriver.
Posted on Jul 08, 2007
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Posted on Mar 08, 2008
SOURCE: ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Posted on Mar 26, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
Posted on Apr 04, 2009
TheMobilian
  • 8220 Answers
SOURCE: Ice maker won't make ice
The water valve has 2 solenoids one for water and another for ice. The water solenoid is connected to a larger hose than the icemaker solenoid. The water solenoid is working but the Ice maker solenoid might be dead. BUT the ice maker might not be calling for water. It is the ice maker that powers up the solenoid to fill the ice mold. At the end of harvest a tiny copper plate mounted behind the main drive gear rubs across a copper contact. To tweek the amount of water a small screw is mount at the 3 oclock position of the ice maker head.HERE are some repair tips and photos
Posted on Aug 05, 2009
I have a Whirlpool Model GD5YHA. The icemaker is not making ice. The red light is blinking.
Your have not given the full model #. Anyway most likely you have the Ice Maker Optical Level Sensor.
Just red light blinking does not mean faulty here. There is a Optical Sensor check sheet. You have to follow those instructions.
Google "Whirlpool Ice Maker Optical Sensor check sheet". You will get the instruction sheet and/or youtube videos on the subject.
Not making Ice means either the ice maker is faulty or Optical sensor faulty or water valve cannot feed water due to malfunction or line frozen. Also freezer should be below - 12C to ice maker sensor to work.
Oct 25, 2017 | Whirlpool Refrigerators
Whirlpool ice maker not working
Ice makers are some of the most worked part of a refrigerator and have about a five year lifespan. There are just too many things that can go wrong that can stop the ice making process. To explain the process of a Whirlpool ice maker I am going to post a Whirlpool Ice Maker Troubling pdf and a short YouTube Icemaker Repair toutorial. If you have any questions I will be here to assist you, Thanks Sea Breeze
May 23, 2012 | Whirlpool Refrigerators
I have a Whirlpool gold french door model # GI5FSAXBY02. The icemaker stopped making ice -please advise. Thanks. Charles Mara chrlsmara@yahoo.com or cjmara@cox.net
Could you double check your model number. I am unableto pull that model number up. You mentioned that your ice makehas stoppedworking. This could be several things, like water control valve,defective ice maker, defective ice maker thermostat and more. Let me know,Thanks, SeaBreeze b8e6bdd.jpgWHIRLPOOL PRODUCT MANUALS
Sep 26, 2010 | Whirlpool Refrigerators
Whirlpool Gold Model # GD5SHGXLB01. The ice maker does not make ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 06, 2010 | Whirlpool Refrigerators
It just stopped making ice yesterday. A question.
Here are some basic tips for ice maker troubleshooting2_bing.gif...
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 11, 2010 | Whirlpool Refrigerators
1 week old Whirlpool Gold refrigerator. model FI7FVCXWYO ice make
Call for service as the "wet ice" indicates freezer is warm.
May 20, 2010 | Whirlpool Refrigerators
Whirlpool Model ED25DQXXN side by side with ice maker running.
either lift the arm up and this should stop it or u can unhook the plug for the icemaker thats about ur only 2 ptions
Feb 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Oct 01, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Ice maker sequence is out of syncronization
I believe your ice maker is the reason for the problem. If you have a model number it is possible that parts are avaiable. Sometimes the complete ice maker will need to be replaced because the controls are electronic in some model ice makers. Could you send the model number of your Whirlpool Refrigerator? Thanks, Sea Breeze
Aug 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Model GS6NBEXRL01 ice maker not making ice
Most likely the water control valve on back of the refrigerator near floor or the thermostat inside the ice maker is defective. You can fill the ice maker with water from tap and see if it cycles one time or you can check the control valve solenoid that feeds water to the ice maker. Click on link below and then paste your model number in model search feature. That takes you to a page with breakdown photos of the parts I mentioned. On the left of your screen click on photo # 12. If you need help with this I am here, just let me know, Sea Breeze
May 18, 2009 | Whirlpool GS6NBEXRL Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
105 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
