Question about Nikon Speedlight SB-800 TTL Flash
Reinserting the wide-flash adapter in a SB-800 speedlight
I replaced the mounting bracket for the built in wide-flash adapter but am unable to put it back into the SB 800 unit. Any suggestions would be appreciated!
  • 62 Answers
The tab normanally breaks and you have to replace it .
There is six parts to replace... two springs , tabs , diffuser and also spring .
If you want me to fix the unit contact the address below .
Berrie Smith Camera Repair
BBMW@BELLSOUTH.NET
Posted on Feb 06, 2008
How do i change from remote ttl on my nikon sb800.
Press the Menu button. Scroll to the Custom Setting Menu. Scroll to "e Bracketing/flash". Right arrow and scroll down to "e3 Flash cntrl for built-in flash" and push the center button. You now have access to the TTL, Manual, Repeating flash and Commander modes. Right arrow on CMD and a menu will appear that allows you to set up the built in flash and the external flash groups.
Aug 15, 2013 | Nikon Speedlight SB-800 TTL Flash
How do i turn off m zoom nikon sb 800 and switch back to ttl mode.
Go to menu on camera, then flash/bracketing, then set TTL (through the lens)
then set flash the same
Sep 07, 2012 | Nikon Speedlight SB-800 TTL Flash
Loose in hot shoe
Have you tried to tighten the little screws on the hotshoe?
if not you can purchase an off the camera flash mount
Multi-Flash Bracket Unit SK-E900
May 20, 2011 | Nikon Speedlight SB-800 TTL Flash
I have a Nikon D40x with a Nikon Speedlight SB-800. The speedlight is not working. I have the camera on, new batteries in the speedlight and speedlight on. Not powering up. Is there some secret battery...
With new batteries in the flash, and it being off camera what happens when you press the test button. If still it does not flash call Nikon 1-800-645-6689
Aug 14, 2010 | Nikon Speedlight SB-800 TTL Flash
Will not power on even after changing and testing the batteries. Only used maybe 30 times in last 2 years.
Check for the battery contacts inside the battery compartment. If you see them rusted, clean them gently with alcohol. Do not scrape with any sharp objects. Make sure the contacts are clean and reinsert the batteries. Get back if it is still dead.
Dec 22, 2009 | Nikon Speedlight SB-800 TTL Flash
Sync Nikon SB-800 speedlight with studio lights
keep the Sb 800on the camera hot shoe and elichrome will trigger automati or use a slave unit
Oct 20, 2009 | Nikon Speedlight SB-800 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Ready light on my SB-800 speedlight
    put in a fresh set of batteries. The ready light won't turn on until the flash capacitor is fully charged. And if your battery is weak, it can take very long (minutes!) to fill the capacitor. You still can fire the flash even it is not ready, it will just dump whatever power it stored in the capacitor.
    Jun 12, 2008 | Nikon Speedlight SB-800 TTL Flash
    SU-4 on sb800
    Unlock The Superslave in Your Nikon SB-800 http://strobist.blogspot.com/2007/08/unlock-superslave-in-your-nikon-sb-800.html
    Dec 23, 2007 | Nikon Speedlight SB-800 TTL Flash
    Nikon SB - 800 LCD Defect
    Impact has damaged the LCD assembly .
    IF you want it repaired contact the email address below
    bbmw@bellsouth.net
    Oct 29, 2007 | Nikon Speedlight SB-800 TTL Flash
    Nikon Speedlight SB-800 TTL Flash Logo
    310 people viewed this question
    Top Nikon Cameras Experts
    Ric Donato
    pictureman4u
    Geoff Hone
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
