Question about Compaq Presario Notebook
Used Compaq Laptop screen not bright
Cannot find any slide/buttons to make the screen brighter...
  • 117 Answers
Usually most laptops has blue/white function keys top on keyboard they can be used together with Fn button that is left bottom side of keyboard. For example on my laptop with F4 and F5 together with Fn can adjust brightness.
Best wishes,
Chillimar
Posted on Jan 27, 2009
How do I make my kindle fire screen brighter?
Adjusting Screen Brightness The screen on the Kindle Fire uses more power than anything else, and the brighter the screen, the more battery power it uses. To increase battery life, you can lower the brightness of the display.
Unlock the rest of this book. Swipe the status bar down to open the Settings drawer.
Unlock the rest of this book. Tap Brightness.
Unlock the rest of this book. Slide the brightness control to the right to increase brightness and to the left to decrease brightness.
Jun 21, 2014 | Tablets & eReaders
Adjust screen brightness
the key f3 has a brighter sun on it it makes your screen brighter
Sep 23, 2013 | Compaq Presario CQ56-115DX Laptop
Hp probook 4520s charging time more brightly .battary off time darknessly
Laptop screen is normally brighter when it is connected to the charge adapter. When the laptop is running on the battery it is usually a little dimmer to save battery power, you can adjust the screen brightness even on battery power. To adjust the brightness hold down the Fn key and press one of the function button keys it maybe the F7 or F8 key it will have a symbol on the key to indicate the screen brightness.
Dec 18, 2012 | HEWLETT-PACKARD ProBook 4520s
I have HP Compaq 6910p and having issue with its battery/changer as laptop screen become bright on battery and uses more battery then normal.
Right click the battery icon next to the clock on your taskbar. Select "Power Options" At the bottom, there is a slider for screen brightness. Slide it left to dim, slide right for brighter.
If you want your laptop to automatically adjust the brightness based on whether it's plugged in or not, click "Change plan settings" next to the currently selected power plan (usually Balanced).
On the new screen, there are 2 sliders. I would recommend setting the Plugged In slider to max and the On Battery slider to about 1/2 to begin with. Then adjust them to personal preference.
May 11, 2011 | Computers & Internet
How do I adjust screen brightness?
Hey there,
If your Notebook doesn't have a menu button or any sort of hard-wired option of adjusting to screen brightness, there are a couple of means to doing it in Windows.
First, if you have an NVIDIA card, you can go to the NVIDIA Control Panel in your Windows Control Panel. There should be an option in there that says Adjust Desktop Color Settings. You can increase the brightness from there.
If you don't have an NVIDIA Card, right click on the Desktop and goto Personalize. Click on Windows Color and Appearance, click on Show Color Mixer, then slide the brightness scale to make your screen brighter. Click okay and that should do it.
If you require and further assistance, post a reply to this thread. I'll be happy to assist you further.
Regards,
Aaron Busch Senior Tech of LiveFix Support Services (LiveFix.net)
May 01, 2011 | Compaq Computers & Internet
I have an Acer Aspire laptop 4810T. It turns on perfectly and everything appears on the screen but it is barely visible. The screen almost appears to be black.
It would seem that backlight for your screen is out. The light may be dead, have a poor connection, or your brightness may be down to zero. To see if the brightness is just low hold the function button "FN" and if you look on the left and right arrow keys there should be a Sun on each one. The left being brighter or filled in, the right darker or hollow. Press the left key while holding the "FN" button. Keep doing this to increase the brightness. If the screen doesn't get brighter there is an issue with the backlight. This is usually covered under warranty. If you still have a warranty contact Acer and they should repair your computer free of charge. If it is not under warranty you may need to replace the screen.
Mar 17, 2011 | Computers & Internet
I can adjust screen brightness in hp probook 4510s laptop
Typically there are two ways: through the keyboard, usually a function button and brighter or darker button, and 2nd in the power settings. Lower screen brightness gives much longer battery life.
Feb 14, 2011 | HP ProBook 4510s FM849UT Notebook
Dark screen if unhooked from battery
You can use the function keys to increase the brightness. Also if you go to Start, Control Panel, Power Options you can change the settings to give you more monitor time.
Apr 15, 2009 | HP Compaq Presario R4000 Notebook
Adjusting the brightness!!
Hi Stacie,
press and hold the "blue" "fn" button (buttom left, second from left), as you press the F10 button and again untill you have the brightness you want.  But be avare, you use more power this way, whitch will result in shorter battery time.
Regards /Teis
Jan 14, 2009 | HP Compaq nc6320 Notebook
How to maximize color of monitor?
The monitor and laptop are not compatible or the cable is not properly connected.
Jun 12, 2008 | Compaq CV 7500 (Carbon, Silver) 17 in.CRT...
Compaq Presario Notebook Logo
130 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
