Question about Miscellaneous
Case 850K dozer. What does code 4531 indicate?
Parking brake wont release and wont drive . Have a code number 4531 coming up. Any sugestions?
  • 3 Answers
The typical failures of joysticks show fault codes 4533, 4532,4531
Posted on Nov 20, 2015
ABS light stays on if car is started with parking brake engaged.
The ABS light illuminates when there is an "out of specification" condition. From your description, it sounds like your parking brake cable may require tightening, or there may be an issue where the rear brakes are not properly releasing when the parking brake is released. With car that is nearly 20 years old, it is not inconceivable that the rear brakes and parking brake assembly may require regular service.
A good first step would be to have error codes read out by a local mechanic or auto parts store. This may give you a better indication of the specific problem. In any case, ANY brake warning should be taken VERY SERIOUSLY and corrected IMMEDIATELY, as you may have a potentially dangerous potential of catastrophic brake failure. PLEASE GET THE ISSUE FIXED RIGHT AWAY!
May 08, 2015 | 1998 Toyota Camry
Adjust handbrake in Hyundai tucson
The adjustment is made at the handle under the console:
ADJUSTMENT OF PARKING BRAKE STROKE
1.Pull the brake lever with a force of approx. 196 N (20 kg, 44 lbs.) and check the number of clicks.
Parking brake lever stroke (Standard value) : 8 clicks
2.If the number of notches is not the standard value, adjust the cable length with the adjusting nut on the equalizer.
3.The indicator light will go out when the brake lever is fully released, and will light up with the lever pulled one notch. If it does not operate properly, replace it.
4.After the adjustment, check that the rear brakes do not drag with the parking brake lever released.
Mar 05, 2015 | 2007 Hyundai Tucson Limited
What causes a brake light indicator to come on and off
Check your parking brake pedal, pull the "brake release" and lift up on pedal then let go of release.
Feb 01, 2015 | Cars & Trucks
Parking light wont go out and keeps dinging
Reach down and release the parking brake at the same time pull up on the parking brake pedal. Sometimes the pedal gets bumped just enough to engage the switch indicating the brake is engaged.
Apr 13, 2014 | 2005 Pontiac Aztec
Brake light in dashboard coming on when driving
I am assuming that you are talking about the RED brake warning lamp and not a YELLOW Anti-lock Brake Warning lamp. If this is not correct, please let me know. There are several things that can cause this. The parking brake my not be released properly. The switch for the parking brake may be defective. Your brake fluid level could be low. (If it is, it is EXTREMELY IMPORTANT that you find out WHY!) Or you could have a brake system hydraulic failure.
In any case, it is NOT SAFE to drive the vehicle until the CAUSE has been determined. It may be safe to operate the vehicle temporarily if you find it is being caused by a defective parking brake switch, but any of the other possible causes make the vehicle DANGEROUS to drive.
May 15, 2011 | Toyota Corolla Cars & Trucks
Parking Brake Indicator Light stays on. My 1988...
pull the breck release and kick it at the same time same thing i had to do hey it worked for me
May 21, 2010 | 1988 Pontiac Bonneville
Parking brake assembly diagramneeded
Item Part Number Description 1 2553 Rear Disc Brake Caliper 2 4234 LH Axle Shaft 3 2C026 Rear Disc Brake Rotor 4 383609-S Push Nut (2 Req'd each side) 5 2C189 Rear Brake Anti-Lock Sensor Indicator 6A 3912205-56 Nut (4 Req'd) 7 2C220 Rear Wheel Disc Brake Adapter 8 1177 Inner Wheel Bearing Oil Seal 9 390317-S190 Bolt (4 Req'd) 10 1225 Rear Wheel Bearing 11B 2B296 Disc Brake Caliper Locating Pin A Tighten to 27-54 Nm (20-40 Lb-Ft) B Tighten to 26-35 Nm (19-26 Lb-Ft)
The automatic (vacuum) release-type is standard equipment on all vehicles. The automatic vacuum-type parking brake system contains the following features:
  • A parking brake release control motor (2A843) with mounting bracket bolted to the parking brake control .
  • The vacuum-actuated diaphragm within the parking brake release control motor which is connected by a rod to the upper end of the parking brake release vacuum hose (2B653) .
  • The parking brake release vacuum hose which connects the parking brake release control motor to the engine manifold through a vacuum release switch at the steering column tube (3514) .
  • The parking brake release control motor which is actuated to release the parking brake whenever the engine is running and the transmission is in a forward-driving gear.
  • The automatic parking brake control which has a manual release feature that releases the foot parking brake control by applying force to the parking brake control pedal in the "apply" direction to the point of initial application.
  • The parking brake control will return to the full-release position after removing the force.
Apr 14, 2009 | 1994 Lincoln Town Car
Rear brakes
you probably have the parking brake set, in which case the drum cannot be removed. release the parking brake
Sep 13, 2008 | 1999 GMC Suburban
Parking Brake Alarm
inset the key and switch on to position 2
Scroll through the warning display untill you get the service indicator apears
Press and hold the reset button on the left of the dash apnel for about 4 mins
You will be asked if you want to reset
Press anh hold the reset button again until you hear an audible warning
It should now show the new interval to a service
Jun 13, 2008 | 2008 Mercedes-Benz Mercedes Benz C Class
Miscellaneous Logo
555 people viewed this question
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
