Question about 473v Viper Remote Case Three Button
How to reset a vipor 473v remote starter
My remote car starter just quit. Do they have a reset button?
No reset. How old is the remote system? Your really lucky if you get more than 5 years out of one of these. And when they start dieing, replace it or remove it. Because eventually they keep the car from starting at all.
Mar 01, 2015 | Cars & Trucks
My 2008 Saturn Vue won't crank or start!? We have tried everything to get the Saturn started but nothing working. It's not the starter or the battery. We have lights and everything works just won't crank...
If you have a voltmeter, Connect one end to the hot terminal on your starter. (Making sure that you don't get any body part or anything stuck in any moving parts in your engine compartment!) Turn the key and look at the meter. If it goes up to 12 V or higher, that means that power is getting to the starter, and the problem is either the starter or a bad ground. If the voltage stays at zero, the problem is before the starter and could be your alarm, a relay, a fuse, etc. It would help you to have the wiring diagram for your car.
May 25, 2014 | Cars & Trucks
How to program a ezsdei474 remote to a viper 130xv
Open door, turn on ignition. Press and release valet switch then, press and hold valet switch. Press lock button on remote. Release valet switch, turn off ignition. Test.
Feb 08, 2014 | 473v Viper Remote Case Three Button
How to program 473v remote
Open the door, turn the key on, press valet switch one time and press it again and hold it until alarm beeps if it dosent beep it means that alarm hasn't read the door open if it beeps press lock on the remote and it should beep again and its will be set. (if the alarm dosent beep you have to put the door trigger wire (green) to ground and repeat steps from beggining
Sep 16, 2013 | 5101 LE 1 Way Car Remote Starter System
Have the STX Vipor electric car. Fully charged but won't go, just hear clicking noise.
If this was a real car this could be anything from anti-theft to a blown battery. Being as its a power wheels it would probably be the battery is ruined because it was charged sitting on concrete bare. Which will quickly destroy a battery. You may have to buy a new battery. The only other thing I can think of to check is if the motor is ruined powering the wheels. Which will be a much more expensive fix. Hope this helps:)
Sep 20, 2012 | Fisher Price Power Wheels Rechargeable...
Hello
Hi. Do you have a problem I can help you with?
Jan 13, 2011 | 473v Viper Remote Case Three Button
Alarm does not beep when locking and unlocking
take it out of valet, open the door push the valet switch one time, turn the key off and hit the valet button again, problem solved.
Nov 05, 2010 | 473v Viper Remote Case Three Button
The remote for my Vipor 5101 remote starter, doesn't always unlock the doors. Sometimes the engine has to be running for the doors to unlock. Any ideas?
you probibly have a ford and the R.A.P system needs to wake up on the first signal then does what you want on the second
Feb 22, 2010 | Remote Start System
Need to disarm the alarm because the remote is not
i have an 02 WRX my alarm keepes going off and i cant start my car and it keeps honking and honkin this viper system cam with the car n there is no button to press my blue button is flashing n my car is honking loud ! help! RPN 473V
Jul 20, 2009 | Viper Vehicle Parts & Accessories
473v Viper Remote Case Three Button Logo
20 people viewed this question
Top CAR Plus Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a CAR Plus Vehicle Part and Accessory Expert? Answer questions, earn points and help others
