Question about Big Button TV Universal Remote
Jumbo universal remote code for sceptre tv - Big Button TV Universal Remote
  • 1694 Answers
SOURCE: Innovage Jumbo universal remote
Try www.remotecodelist.com ..........T.
Posted on Jan 02, 2008
SOURCE: Installing Jumbo Universal Remote
Looking for some kind of direction-information for the innovage jumbo? I was unable to program the DIRECTV PART OF IT. I tried all of the codes.
Thanks,
Caren
Posted on Jan 24, 2008
  • 6 Answers
SOURCE: omnitech jumbo universal remote control and vizio hdtv
Here are the instructions for auto code search from the Omnitech manual:
Automatic Search
There is another way to set up your controller, that does not use the brand code lists. You can let your
controller search through all of its available codes automatically in order to set the connection to the
target device. To do this, follow these steps:
1.Turn on the target device.
2.Point the controller at the target device and press and hold the Code Search button for around 3
seconds, until the LED light stays red.
3.Next select the type of device the target unit is by using the Cable/TV/VCR/DVD/Sat Buttons (i.e. if
it is a TV that you are trying to control, press the TV button). The LED light should then blink once,
then stay red.
4.Press the On/Off button on the controller slowly and repeatedly until the device you are trying to
connect with turns off. (Note: the LED light will blink each time you press the On/Off button). When
this happens, press the ENTER button in order to store the code and the LED light will turn off.
Posted on Jul 13, 2008
SOURCE: Living Solutions Jumbo Remote
for code retrieval:
press and hold "code search" until led lights up solid red.
press the device button (TV for tv, DVD for dvd player, etc.)
press each of the buttons 0-9 untill the light blinks. that means you have the 1st number of the 3 digit code.
repeat to find the 2nd and 3rd.
After you find the 3rd digit, the led will turn off.
Now you have the code!
So, what you do is:
turn on the device you want to program.
aim the remote and hold code search until light remains solid red
press device button
enter the code, led should turn off
after that, press the on/off key.
Posted on Nov 23, 2008
SOURCE: proteam jumbo universal remote
Turn your device on.
Hold down the set button and press the button of the device you want to program (e.g. TV) then release the set button.
Press the set button again and the red light will start flashing.
Press the power button repeatedly until the device switches off.
This is now the correct code.
Press the device button once more to set the code in to the memory.
Hope that helps.
Posted on Apr 26, 2009
My remote for my 32in sceptre tv stopped working looking for a code that might work on a universal remote
You have this backwards. The code is generated by the remote. If you have a universal remote, you can use the code search routine described in the instructions to find a code that works. Those same instructions might include a list of devices the universal remote is capable of controlling and your Sceptre TV might be on it.
Dec 30, 2013 | Sceptre Televison & Video
LG codes for a jumbo remote
Check these codes. 0004 0050 0009 0005 0227 0338 0012 0057 0080 0156
Oct 22, 2012 | Jumbo Universal Remote TV DVD VHS...
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
Looking for a jumbo remote that will operate a new 26 inch Vizio Montior. The old one don't work. Is there a new version?
A remote is not designed to control and Moitor. They only run by the video/sound output from the pc. So I am taking it for granted that you meant TV instead of Monitor.
A. Before buying a new remote try replacing the batteries first.
B. I found the Innovage Jumbo Remote Control manual and it has no code for the Vizio TV, you will need to utilize the remote's "Code Search" option.
C. Instructions
1. Turn on the Vizio TV.
2. Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
3. Press the "TV" button at the top of the Jumbo Universal Remote.
4. Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. This will likely take several minutes due to the amount of available codes.
5. Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6. Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Good luck.
Jun 03, 2011 | Innovage Jumbo Remote Control
Bigmatters universal jumbo remote ero4307j
manual de codigos del control bigmatters jumbo universal mod ero4307j
Jul 05, 2008 | Televison & Video
Big Button TV Universal Remote Logo
229 people viewed this question
Top Big Button Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Big Button Televison and Video Expert? Answer questions, earn points and help others
