Question about Panasonic CT-32SL14 32" TV
Hi, My 3-year old Panasonic CT-32SL14 32" TV started not turning on suddenly. No audio or video or any sign of getting any power (red light in the front does not lit). what are the possiblities for happening this and possible repair costs for each possible problem. any info will be greatly appreciated. Thanks. Dickson
Re: Panasonic CT-32SL14 32" TV - Panasonic CT-32SL14 32" TV Standard (CRT) Televisions
Do you have any electronic skill ????
Posted on Jul 24, 2007
0 characters
3 Points
Panasonic CT-32SL14J green picture after blown fues replaced
no there may be loose contact or dry solder in circuit board attached to video driver section ..resolder
all the solder joints cleanly...&also resolder the long ic ie
chroma ic...u can find where the problem is by gently tapping the main board or video board by a tooth brush
when tv is on. if the color changes by tapping u can get the loose contact..have a nice day
Mar 10, 2010 | Panasonic CT-32SL14 32" TV
Our Panasonic CT-27HL15 set is only 4 years old and suddenly decided not to turn on. When you press the power button, it turns on for a second then makes a noise inside and shuts off. Any ideas is it worth...
I have one of those that is the same age and the 6.3 amp fuse was blown out. I replaced it with a 6 amp fuse (i could not find 6.3 nearby) and got a few more weeks use until the fuse blew out again. someone suggested i get a slow blow fuse next time.
Jun 20, 2009 | Panasonic CT-27HL15 27" TV
Panasonic CT-36SL14J White screen
my Panasonic CT-36SL145J won't turn on
Dec 25, 2008 | Panasonic CT-36HL43 36" TV
TV does not power up
Check Power Cord is Plugged into Active Outlet
Adjust Brightness and Audio Controls Change Channel Check Cable Connections Program the Remote Control Again Check Second Video Source Operation As warranty has expired, check if fuse at power supply input is ok.
Consult online manual for troubleshooting.
Feb 14, 2008 | Panasonic CT-36SL13 32" TV
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
No picture no sound nothing
We had a TV repairman look at our 3 year old (Oct 2004) Panasonic CT-32HXC14J FLAT SCREEN TV. It suddenly stopped working and appeared to have no power getting to it. It was a high voltage supply or transformer that was bad and has to be replaced - estimated cost is around $400. In a year we will also need to spend around $125 for a digital converter box. We went for the repair since that is still cheaper than a $1,000 plus equivalent size LCD or plasma.
Our old tube tv was still working after 15+ years. They aren't making them like they used to. Way to go Panasonic.
Nov 09, 2007 | Panasonic CT-32HXC14 32" TV
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
If you are a tech then you can get a schematic from
Apr 01, 2007 | Panasonic CT-32HX42 32" TV
Panasonic CT-32hX41 vertical picture problem (hourglass)
this product has a pincushion problem and requires servicing but unfortunatley it is what we call in the business NECO
Dec 05, 2006 | Panasonic CT-27HL14 27" TV
No video/audio when TV is turned on..
This set is popular for the main voltage regulator to be bad. If you have a meter check the input voltage . it should be between 135 to 159 vdc. Now pin 4 should be aroud 125 to 130 when you switch the set on. Hope this helps Good Luck
Jun 02, 2006 | Panasonic CT-27SL14 27" TV
Panasonic CT-32SL14 32" TV Logo
196 people viewed this question
Top Panasonic Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Panasonic Standard (CRT) Television Expert? Answer questions, earn points and help others
