Question about Konica Minolta Minolta Di520 Dialta Color Copier, Printer And Scanner
How i assemble di520 bottom tray lock
I have minolta di520 the bottom tray's lock of my copier is crash i want to change the lock of my copier's bottom tray.. how i assemble it.?
  • Konica Minolta Master
  • 1,297 Answers
Step 1:
Remove the rear cover and in area of wastw tonwr box remove the tray blocking unit.how i assemble di520 bottom tray lock - 2_3_2013_6_10_50_pm.jpg
Step 2:
Posted on Feb 03, 2013
Solve the plroblem in di 620
The 13xx - printer engine malfunctions
13F0 -400 dpi SOS sensor detection failure.
13F1 -600 dpi SOS detection failure.
13F2-universal tray adjustment failure maximum.
13F3-universal tray adjustment failure minimum
13F4-optical system out of adjustment
Dec 15, 2013 | Minolta DiALTA Di520 Laser Printer
Minolta DiALTA Di520 Laser Printer code 13f1
Replace the print head the device that houses the machine LASER, or the J or A printed circuit boards. Go with the LASER first if you can find one the Di520/620 are legacy machines from Minolta now Konica Minolta. Reset is Power off the Power on.
Jan 22, 2013 | Minolta DiALTA Di520 Laser Printer
Minolta di520 error code C0990
Large capacity draw bottom draw lift problem. gear might be bad or the cable snapped.
Aug 13, 2012 | Minolta DiALTA Di520 Laser Printer
Minolta di520
COF 34 is a code to refer T/C recovery failure as detected by ATDC sensor.Change ATDC sensor,if problem persist,change developer(starter) and then run F8 and F5 function operation in that order.Developer change every 1000000 copies.
Nov 08, 2008 | Minolta DiALTA Di520 Laser Printer
Minolta Di520
From the service manual
These malfunctions are concerned with faulty symptoms as they relate to software, hardware, and
communications. For remedial action change the board, check for cable connections, and turn OFF
and ON the power.
C133B - Check cables for proper connection and, if they are okay, change the finisher cpu board.
Hope this helps!
May 19, 2008 | Minolta DiALTA Di520 Laser Printer
Dialta Di 520
On the rear cover in left side down exist a hole.Insert a 40 cm screw driver,push and the bottom tray opened.Before open right door(multibypass).
Apr 01, 2008 | Minolta DiALTA Di520 Laser Printer
Minolta Di520 false misfeed
Try resetting the copier, with the copier powered on open the front door remove small cover on right hand side press reset button close front door, the machine should boot
Feb 06, 2008 | Minolta DiALTA Di520 Laser Printer
Konica Minolta Minolta Di520 Dialta Color Copier, Printer And Scanner Logo
53 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
