Question about Viking DFSB483 Side by Side Refrigerator
Just found a huge leak
By chance noticed I had water leaking into my basement. It seems the fridge located directly above it had an overflowing drip pan. Unscrewed the bottom plate of the fridge and found the dip pan and emptied it but am now confused - Does this need to be emptied on a regular basis? If so why do they secure kickplate with screws? Too, I have lots of ice build up at the top of the freezer and some on the fridge. Have put thermometers in both . Fridge is actually often borderline being too warm. What steps should I take next? Freezer has an automatic ice maker -could this be the problem? Any advice would be greatly appreciated. I am new owner of the house and did not purchase but I believe it is approx 2 years old.Thanks!
  • Sandra Bernick Oct 25, 2007
    Discovered the problem. First there is a known fault on my year fridge (2005) that can be resolved with the installation of a heating tray underneath the evaporization tray ($100). This waas installed and still did not fix my problem because apparently the fan was not connected and therefore did not come on. Now that the fan and heating tray works i have no more problems. Man also adjusted the doors for a better fit and adjusted the temperatures. phew! Now I have problems with my Viking range -oh bother!
  • wickey22 Jun 01, 2008
    Water puddling under front of fridge, drip tray not full so its not overflowing. About a half cup of water every 12 hours on floor. HELP!
    President:
  • 1,462 Answers
Water in pan should evaporate of its own accord. you may have two faults. first, check door seals to see they mate with cabinet. if seals don't seal properly, excessive air will get in and hence the excess of ice. second, you should not have ice build up. remove back panel of freezer and check if evaporator has excessive ice build-up. if so, this points to a fault in the defrost system
Posted on Jul 25, 2007
SOURCE:
Water dispenser leaking
Ck level sensor. the trouff holds pre cooled ice maker water,seems likely overflowing from than leaking!
Sep 01, 2012 | Maytag Refrigerators
Frigidiare side by side leaking water near compressor. I noticed water spots in my ceiling in the basement. Was able to trace the problem to the fridge. When the water dipsenser is pressed or the
You will need to look for water line leaks but water in small amounts can also come from a defrosting drip pan. The dust and fuzz that get into these things over the years also can cause water to go where it is not suppose to.
Aug 31, 2012 | Frigidaire Refrigerators
I have the Kenmore top-mount 106.76232402 leaking
hi.turn water supply to fridge first.cont drip might be a faulty valve.hope this helps.Ali
Jun 26, 2012 | Kenmore Refrigerators
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Hi, I have a refurbished RFG297AARS from Samsung that we purcased as a refurb about 7 days ago. On day 1-3, a puddle of water formed under the back right underside of the fridge, without the water line...
Chances are its either the drip line or drip tray.. there is a drain to route the condensation pulled out of the fridge and freezer that leads to a drip pan underneat the unit.
Either the drip tray was not installed.. reinstalled incorrectly or the drain tube is leaking or no longer directed to it, or it's overflowing due to excess condensate.
Best of luck!
Apr 26, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Does anyone know how to fix an ice maker?
When the ice maker calls for water it pours for about 7 seconds if more will overflow and drips into tray , but the most common problem is the dual valve that leaks even after ice maker called for water (this valve is located in the back of the fridge at the bottom where the water line is hooked up.)
Aug 09, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Amana SBD21VE No water to ice maker
your water line to the fridge is most likely leaking. You should turn it off right away. The line turn off is either behind the fridge or under sink. sometimes its in basement. The line is very easy to replace. You can get the plastic ones at home centers for under 5 bucks.
Jun 08, 2009 | Amana ASD2326HE Side by Side Refrigerator
Leak - water not evapourating
check your doors may be not clossing (ajar) or check control to high
Apr 02, 2009 | Westinghouse Refrigerators
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Viking DFSB483 Side by Side Refrigerator Logo
420 people viewed this question
Top Viking Refrigerators Experts
Jay Finke
Jay Finke
Audie Bogus
Audie Bogus
Level 1 Expert
Jose Pino
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
