Question about VeriFone VX510
VeriFone VX510 displaying GO FILE NOT FOUND after Flashing Files
Followed the instructions given here to FLASH Files (F4), which seemed to have worked okay. There are no errors on the LOG, however terminal displaying: DOWNLOAD NEEDED GO FILE NOT FOUND please help
  • Sergio Rosa Feb 04, 2013
    Thank you for all the sugestions and recomendations.
nayabkhil
  • 31 Answers
SOURCE: I have 5 used Verifone Omni 3730 vx510 terminals
At the sales screen hit F2 & F4 together password is 1 Alpha Alpha 66831.
Then hit the button under the arrow on the left of the screen one time.
choose flash files the clear all files password again same as above.
Then clear Ram files clear all files and confirm and then you are on easy street.
www.greenlightpayments.com
Posted on Jul 24, 2009
edward16
  • 59 Answers
SOURCE: VeriFone VX510 "TCP Error 10030003" is the error
Im glad you got it, but the next time you have a problem or any question about your VX 510. specially if it is a hardware problem, give us a call and maybe we can help you. (775)358-2922 look for randy or check out http://freshpoint.org.
Posted on Nov 07, 2011
  • 113 Answers
SOURCE: download needed no*Go variable in monitor verifone vx510
what you need to do is call your service provider ( bank ) and have them download the program in to the unit what the unit is telling you is the there is no files in the memory
Posted on Nov 21, 2011
  • 113 Answers
SOURCE: How can we resolve bad
bad RTC can be repaired. the machine is equipped with multiple sensors inside. if one of them goes bad, or the Battery is dead tampering or bad RTC will show this can be fix by replacing the sensor and or the battery if you need this to be done call me @ (775) 358-2922 hope this help : - )
Posted on Jan 13, 2012
  • 113 Answers
SOURCE: I have two verifone vx510 cc machines. 1st) Need
Posted on Mar 01, 2012
Why is screen indicating download is needed?
PDF]Verifone VX510 User Guide - Moneris Solutions
www.monerisusa.com/support/~/media/Files/.../Vx510_qrg.ashx
VeriFone Vx510 with SoftPay. Quick Reference ... their PIN, and encourage them to protect their PIN. ERROR ... the terminal screen. ... PINpad display is blank: See "PIN Pad Error" ... the ALPHA key (repeatedly if necessary until the desired.
[PDF]Vx 520 - User Guide - Verifone Support Portal
Dec 19, 2015 | VeriFone VX510
Verifone vx510
At the sales screen hit F2 & F4 together password XX X Alpha Alpha 66831.
choose flash files the clear all files password XXXXX same as above.
Jun 30, 2014 | VeriFone Computers & Internet
File group password for Verifone vx510
You need password reset software to reset Group1 password in Vx510.
psoftware109@gmail.com
Jan 10, 2013 | VeriFone VX510
I bought a verifone vx510 and it apparently has a password already on it. I have used your reset formula: At the sales screen hit F2 & F4 together password is 1 Alpha Alpha 66831. No help. All
hi try 23378463 this maybe work but if dint work the only solution to your problem is to send it to a repair shop you need to reset back to factory default and you can only do it with the virfone software i hope this work for you if you still have question call me @ 775-358-2922
Oct 16, 2012 | VeriFone VX510
How do i reboot
To Reboot the Verifone VX510 or VX570 terminal you will press the "F2" and "F4" buttons at the same time. When it prompts you for the password, you will enter it (this depends on which credit card provider you use) and it will bring you to a "sys mode menu 1" screen. The "F4" option should give you a "RESTART" option, which is the same as rebooting the machine.
Aug 31, 2012 | VeriFone VX510
My verifone vx510 is displaying the wrong date, how can I change it?
Simultaneously press [F2] & [F4].Key in 1, Alpha, Alpha, 66831 and press [Enter].Select CLOCK [F3].Key in the Year, the Month and the Day and then press [Enter]. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered. Use the down arrow to scroll down to check/adjust the time. Key in the hour, using military format (ex: 3 p.m. = 15), then key in the minutes and press [Enter] to complete and return to Menu 1. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered.when finish Select Restart [F4].
Aug 22, 2011 | VeriFone VX510
Verifone vx610
#1 You need the Vmac and Comserv applications that were deleted when you cleared memory in order to perform an IP download. Without them you can only perform a dial only download.
#2 The programming for your VX510 will not load in your VX610 because they doth identify to the server as different models. If you did get the vx610 to connect and request your vx510 file you would only recieve an error "Application not configured" or "file not found"
Pro Tip: You can still clone VX terminals reguardless of model with the correct cable. Enter system mode and press 0 the # or 0 then * to send and recieve. This would put the application from the vx510 into the vx610 but your vx610 may not work through a com method other than dial depending on your processor.
Feb 10, 2010 | Computers & Internet
I have 5 used Verifone Omni 3730 vx510 terminals that I would like to sell on Ebay. How do I remove all my bank information from them and reset them?
Jul 23, 2009 | VeriFone VX510
I have verifone vx510
GO ON LINE
VERIFONE OMNI 3700 SERVICE MANUAL
OR
VERFONE VX510 SERVICE MANUAL DRIVERS
ENTER
OR
VERFONE 3700 VX510 FLASHING LIGHTS
ENTER
ROD
Feb 10, 2009 | VeriFone Omni 3700
VeriFone VX510 Logo
2,293 people viewed this question
Top VeriFone Retail Supplies Experts
Da Doc
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
