Question about Vehicle Parts & Accessories
Diagnostic code 2195, 170 and 171 for hyundai elantra?
I had a diagnostic test done on my 2006 Hyundaii Elantrae today because my engine light came on. The code 2195, 170 and 171 came up. There was no record of these codes in the computer at Auto Zone Can you tell me what parts the codes are related to.
SOURCE: 2001 hyundai elantra idling high
weeeeiiirrdddd. i have a 2001 hyundia elentra gls, and my third cylinder is misfiring as well. my car also revs constantly on idle and in between shifting. it will flutter between 2-3000 or it will just stay at 5000. i replaced my plugs and wires to no fix with my cylinder. autozone also told me that it sounds like my throttle position sensor needs replaced, but every part they try to sell me will not fit and they swear up and down this is the right part...
Posted on Nov 30, 2009
  • 184 Answers
SOURCE: 2003 Hyundai Elantra GLS. Check engine light, code PO133
Did you use a aftermarket O2 sensor or a genuine Hyundai one? If it's an aftermarket one it may be bad or not as good as the OEM one. See here for more details and other potential causes: P0133
Posted on Feb 11, 2010
SOURCE: 2002 jeep liberty speed sensor
Jeep Liberty 2002 woahs !
by porth21 - 2/1/09 7:35 AM In reply to: Jeep Liberty 2002 speedometer not working by Dannywon
I have a 2002 Jeep Liberty Limited with the same problem. The main problem I have found to be the routing of the speed sensor wires located on the rear difrential. They are 2 blue wires on my jeep and probably the same on yours. The problem is that they rub on the E-brake cable and once the wire is exposed they short and the speedometer and any other options running off they speed sensor quit working and that includes the tranny shift points and can cause the torque converter to not unlock and cause stalls. I am having the same problem for the third time and chrysler and jeep are both aware of the problem and unwilling to repair the problem or post a recall.
Posted on Apr 01, 2010
ftw1952
  • 10319 Answers
SOURCE: i have a 2001 kia rio, check engine light came on.
1166 - AF sensor 1 heater circuit malfunction
Your top O2 sensor (the LAF sensor) may be unplugged or the wire may be damaged, or it may be dead.
Posted on Sep 02, 2010
Testimonial: "Thank you very much, that was very helpful.It probally saved me a lot of trouble and expense."
  • 175 Answers
SOURCE: i have a 2006 pontiac
You may need a more sophisticated scan tool for this type of analysis. Take it to a deal er or reputable mechanic who has such a tool. Without it, it can get very expensive with trial and error.
Posted on Feb 05, 2011
PO-139 I had that sensor change 3 weeks ago and the check engine light came on again this morning.Thanks
Probably replaced a good sensor. This codes could be from a bad sensor, a vacuum leak, or an exhaust leak before the sensor.
Dec 01, 2015 | 2006 Hyundai Tucson
My 2003 hyundai elantra's check engine light is on.
most of the time a engine light will set with an Evap leak code if the gass cap is not tight or left off. tighten cap, or replace cap if gasket is cracked or worn.
Mar 06, 2012 | Hyundai Motor 2003 Elantra
I have 2006 hyundai elantra with a bad camshaft sensor. I have part on hand. Anything special I need to do besides swap out the part? Cam Shaft Location?
I assume you determined the diagnostic trouble code for the sensor was TRUE/VALIDATED?
If so, then there is NO reason to do anything else but 'swap out the part.' Your second question is somewhat puzzling... the cam shaft is on TOP of the engine - the sensor's location (standing on the passenger side of the vehicle with the hood open, is on the left side of the engine at approximately the 10 o'clock position of the cam.... the connector to it is at the 9 o'clock position.
Mar 26, 2011 | 2006 Hyundai Elantra
I got 2 codes off the check engine OEM today... P0171 P2243 I'm thinking O2 sensor, but AutoZone didn't have Hyundai listed. Where can I find Bank 1, Sensor 1? How many O2 sensors does the 06 elantra...
It has two sensors. Bank 1 Sensor 1 is inside the engine bay under the metal heat shield on the front of the engine. Check out NTK sensors online. The one you need will be a 4 wire sensor. The NTK part number is 24588.
Dec 04, 2010 | 2006 Hyundai Elantra
2002 hyundai elantra gls . low idle speed, check engine light on, and doesn't shift out of low gear . ( 50,000 ) miles
Did the 'Check Engine' Light come ON? Whenever the 'CHECK ENGINE' light comes on, the ECU (Engine Control Unit) sets a Diagnostic Trouble Code (DTC). These codes identify the particular engine management system which caused the light to come on. You'll need to use/find an OBDII (On-Board Diagnostic) Scanner to retrieve any code which have been stored in the ECU computer. Afterward, we might be able to help you DIAGNOSE and perhaps eventually fix the problem.
Nov 03, 2009 | Hyundai Motor 2002 Elantra
2000 hyundai elantra car cranks but wont turn over just started fine 3 days ago
Did you scan for any trouble codes? Whenever the 'CHECK ENGINE' (Service Engine Soon) light comes on, the ECU (Engine Control Unit) sets a Diagnostic Trouble Code (DTC). These codes identify the particular engine management system which caused the light to come on. You'll need to use/find an OBDII (On-Board Diagnostic) Scanner to retrieve any code which have been stored in the ECU computer. Afterward, we might be able to help you DIAGNOSE the problem and perhaps fix the problem.
Sep 10, 2009 | 2000 Hyundai Elantra
2003 hyundai elantra gls abs/tcs light on
Two seperate problems. I would say you have a bad wheel sensor. A trip to a local big chain parts store will tell you. They will run a diagnostic and pull the code for free. Hope this helps...
Sep 07, 2009 | Hyundai Motor 2003 Elantra
I have a Hyundai Elantra 2004 sedan. 75,000
You'll need to use/find an OBDII (On-Board Diagnostic) Scanner to retrieve any code which have been stored in the ECU computer. Afterward, we might be able to help you DIAGNOSE the problem and perhaps eventually fix the problem.
Aug 10, 2009 | Hyundai Elantra Cars & Trucks
Elantra automatic trans problems
Does the Check Engine light come ON when this happens? Whenever the "Check Engine" light comes on, there is always a DTC (Diagnostic Trouble Code) stored in the ECM (Engine Control Module). You'll need an OBDII (On-Board-Diagnostics) scanner to retrieve any codes recorded/set in ECM. Once you do this and let us know what, if any codes are set, then we can go from there.
Jun 28, 2009 | 1998 Hyundai Elantra
I have a 1998 Elantra wagon. At first the air bag light came on now the check engine light came on. When I turn on the headlights the dash lights dimm. Is this the battery or alternator?
One problem at a time. Whenever the "Check Engine" light comes on, there is always a DTC (Diagnostic Trouble Code) stored in the ECM (Engine Control Module). You'll need an OBDII (On-Board-Diagnostics) scanner to retrieve any codes recorded/set in ECM. Once you do this and let us know what, if any codes are set, then we can go from there. The AirBag light's a different story - Take the vehicle into a Hyundai Service Center (dealership), pay the diagnostic fee. They will tell you EXACTLY what the problem is and what's needed to fix it (parts, labor, tax, time-frame, etc.). Once you find out what the problem is, them maybe you can repair it yourself.
Jun 27, 2009 | 1998 Hyundai Elantra
Vehicle Parts & Accessories Logo
22 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
