Question about Pentair MiniMax NT 400 Blower Assembly with Gasket 472374
Thermal fuse blown for pentair 400 minimax plus
Spa will not heat
    Top Expert:
  • Pentair Master
  • 5,922 Answers
Fusible link bad overheated replace and check gas pressure if ok check burn tubes for blockage
Posted on Nov 23, 2017
  • 15 Answers
SOURCE: Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
Posted on Jun 23, 2009
  • 990 Answers
SOURCE: E04 message on MiniMax NT 400 DV..Help!!
Your EO4 message tells you you have a fan problem. So ether your fan is diying wich you would hear or you have a bad presure sensor in your exaust. A new fan is a little pricey but the sensor is reasonable for heater parts. I can't be sure but I believe it ether screws onto or into your exaust and it just plugs on to your control board. If your sensor is going bad their is a reason and this should be addressed. It should be in your by-pass or your gas pressure. But as far as a new heater, not untill you have water coming from the cabnit. It is sometimes easer to sell new than keep up with new, Good luck let me know how you do.
Posted on Dec 03, 2009
  • 990 Answers
SOURCE: Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Posted on Dec 12, 2009
  • 64 Answers
SOURCE: error code e04
If the fan was seized, it is likely bad, even if you freed it. If it doesn't sound the same, or is not as loud as it used to be, it is also most likely bad. If it doesn't move enough air to close the air pressure switch, then you will get an 04 fault, which is an air flow fault. HTH
Posted on May 24, 2010
  • 990 Answers
SOURCE: heater cycles on / off
This could be a water flo problem. you need to chech to be sure your by-pass valve is closed down enough to force water threw heater, There is a internal by-pass that could be a problem also, or a bad pressure switch. If the by-pass isn't the problem then you should check these also.
Posted on Jul 26, 2010
Have a Pentair Minimax Plus 400 heater leaking water. How do you get the top and flue collector (gas is turned off at source) off so you can see if the heat exchangers are leaking, or is there another way...
There are multiple screws around the perimeter, remove them then lift of the top. Then there is multiple pieces of sheet metal that also needs removal. Then the baffles sit right on top of the heat exchanger which will easily be removed once the sheet metal is removed. then inspect the exchanger.
Good luck
May 22, 2014 | Pentair Pool & Spa
Purex Triton MiniMax Plus 400 power light is not turning on nor is unit. Checked for power going to unit and no fuses appear to be blown. Thoughts on what might be the issue? Thanks, Dan
if you have incoming power, you may have a bad transformer. those systems run on 24-28v. you can check from yellow wire to yellow wire coming off the transformer to see if you have anything coming out. must check wires coming out of the transformer to each other, it won't register if you check each one individually to ground. hope this helps...
Aug 11, 2011 | Pentair Minimax NT Heater
I have a pentair minimax 400dv ,my heater burner comes on for a minute and then,the burner cuts off. The fan keeps running, the burner will ignite again. This will do this several times. Eventually the...
Cleaning the Thermal couple can work at times, however most times you will need to replace it. You may also be having an issue with the ignition control. You are in pretty deep now and it would seem like you are determined to save this heater, I would change them both.
http://www.parts4heating.com/Pool-Heaters-Pentair-MiniMax-NT-400-s/696.htm
Jun 30, 2017 | Pentair Minimax Ch 400,000 Btu Propane...
We have a Pentair 400 heater. First time to heat
You probally just need to increase your water flow. On the pipes going to the heater their should be a valve bridging the inlet and outlet pipes. This valve should be closed about 80-90% so it forces more water through the heater. I hope this helps.
Jan 01, 2010 | Pentair MINIMAX NT TSI IGNITER
Minimax 400 heater not operational
what is ok on the water pressure? th heater need from 40 to 60 gpm in order to work properly clean the filter and let me know
Sep 10, 2009 | Pentair Minimax NT Heater
Jun 06, 2009 | Pentair Minimax NT Heater
Pentair MiniMax NT 400 Blower Assembly with Gasket 472374 Logo
243 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
