Question about Watches
Battery for bulova C876763 - Watches
Battery size for bulova 98g48
If there is a dead battery in the watch, when it is opened, that is one way to identify the battery size.
A second way, if no battery left in it, is to go to a local jeweler or watch battery replacement kiosk at the shopping mall.
Third, contact Bulova at phone number shown:
https://www.bulova.com/pages/manuals-parts
Parts Manuals
Jun 15, 2018 | Bulova Watches
What size battery do I need for a Caravelle by Bulova watch C860429 ? Tks
Have the watch opened by a jeweler or trusted technician to see the battery type inside the watch.
Or: contact Bulova:
Bulova parts department at parts@bulova.com or call 800-233-3350.
You may also view or download a manual/PDF with information specific to your watch. Find the style number on the back of your watch case, then simply click on search icon at the top right, type in the style number, to find it immediately.
For all other inquiries or assistance, please contact service@bulova.com or call 800-233-3350.
Parts Manuals
Apr 13, 2018 | Bulova Watches
I need to replace Battery for C969908 Bulova Carvelle ? How, where, what's the stock number?
Take your Bulova Caravelle to a jeweler who, for a reasonable sum, will replace the battery.
Dec 03, 2016 | Bulova Watches
Which battery number should I use on a bulova 96t63
Most likely...
Bulova 228 = S05 American Watch institute, USA: 357 (303)
Japan: SR44W .. (SR44SW)
Possibly...
Bulova 606‎ = S32 AWI... Energizer/Duracell 377 or SR626SW
Which battery number may use in this watch bulova 96t63 thanks
and
Specialty Battery Finder
Jul 28, 2016 | Bulova Crystal Ladies 96T63"
Wich battery number may i use in this watch bulova 96t63 ??thanks
cant see that model watch on the Bulova web site user manuals
http://www.manualslib.com/brand/bulova/watch.html
if unsure if it needs a battery go to a jeweler or watch or battery seller
some model Bulova Watched instructions
IF YOUR NEW WATCH IS A MECHANICAL WATCH
(no battery)
Mechanical watches differ from Quartz watches in several
respects:
1. No battery changes are needed - they are powered by a main-
spring, which is wound either by wrist movement; or in some
models by daily winding of the setting crown.
2. Because it is a mechanical device, it's accuracy is subject to
the effects of gravity and temperature. You can expect, on the
average, a daily variance of up to 10 to 20 seconds for
mechanical watches.
3. Just like automobiles, these watches require routine mainte-
nance. Due to their mechanical complexity, mechanical
watches require cleaning and new lubrication every 3 to 5
years to run at optimum efficiency.
FOR THE AUTOMATIC SELF-WINDING
MECHANICAL WATCH
it must be wound at least six or seven times before you wear it.
After that, your daily activity should wind the watch sufficiently
to keep it running at night when it is not being worn. If your
normal daily activity is not sufficient, occasional supplementary
manual winding may be necessary. It is suggested that your
mechanical watch be cleaned and oiled periodically to insure
optimum performance. As a mechanical watch, quartz watch
accuracy cannot be expected. References to the power cell do
not apply to Automatic watches
May 02, 2016 | Bulova 96T53 Watch for Women
Bulova 96b34 watch is not working
Batteries do not last forever. They corrode contacts, loose power even while in storage. Go to a different shop and have the battery replaced.
Feb 21, 2014 | Bulova Watches
I have a Bulova westminster chime battery operated clock that the chime is off. how do I reset it?
You may call Bulova customer service at 1-800-233-3350 they are usually open 9 until 4 eastern time. It may just be a setting or you may need the battery movement replaced. I hope this helps you!
Sep 18, 2011 | Bulova Watches
I have a bulova 96b34 that has a rechargeable battery but needs a new one.the battery has a little welded contact on the back and i have no idea where to find one.
Batterie model is Panasonic MT920. You can order a Citizen part no: 295-5600 who is a rechargable batterie for watch mouvement Miyota model BR10. That mouvement is use in Bulova motion quartz, Invicta automatic and Citizen eco drive.
Jan 08, 2009 | Bulova Millennia Motion 96B34 Wristwatch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
