Question about Whirlpool GSS26C4XX Side by Side Refrigerator
Removing the water pad whirlpool gold gss26c4xx
3 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: Removal of water filter; Whirlpool Gold Side by
Turn the filter CCW and pull out. (water can stay on) remove knob from filter and put it on the new one. Insert the filter and turn CW to lock in place.
Eric
Posted on Oct 18, 2009
mc1bean
  • 3053 Answers
SOURCE: I need help removing and changing water filter in
Hello, irbdunn
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about refrigerator and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-refrigerator.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Posted on Oct 31, 2011
Whirlpool Gold Side by Side refrigerator GSS26C4XX, how to force the defrost?
With the bottom kick panel removed, look for a defrost timer. It will look like a small motor and have a slotted fitting on the end of the shaft - usually you can turn it only one way. With the unit running, slowly rotate the timer shaft 'till the compressor stops. That's the beginning of the defrost cycle, which will end when the timer makes a full revolution. It's usually 12 or 24 hours between defrost cycles.
If the box is completely electronically controlled (electronic logic board), you may not find a mechanical defrost timer.
Aug 03, 2017 | Whirlpool Refrigerators
Error message E6 F2
From investigation, I would open the control panel (make sure the power is turned off first!) Look for a ribbon cable that goes to the Touch Pad and Control pad module. It should be able to be removed from the control board. Pull out the ribbon cable, and put the ribbon cable back into the connector. Be careful with the cable as they can be broken easily. Once you have everything back together, turn the power back on and test the pad. If it still doesn't work, the control board may be bad.
Nov 05, 2013 | Whirlpool Gold Resource Saver GGE390LX 30"...
Ice maker not working
try manually filling it with 4 ounces with a cup or baster of water through the front door straight into the ice maker mold,sometimes they will take off on their own,if not remove rear cover behind the refrige where the water fill valve is located,check resistance of water valve to i/m,if ok,then burnish solenoid water valve terminal connections,sometimes they get corroded,just moving this connection will help too
Feb 10, 2013 | Whirlpool GSS26C4XX Side by Side...
GSS26C4XX
if compressor isn't running you could have a bad start device,unplug the machine,pull it away from the wall,remove the back bottom panel,look at the compressor,you'll see the start device on the side of the compressor,pop off the metal clip and slide back the device,there are three pins on the compressor and the device has three holes in it,you line up the holes and push the device onto the pins and to remove it pull back on the device to slide it off the pins,the easiest way to check it is to shake it,if you hear pieces rattling around inside the device it's bad,you can check it with a meter.if it's bad call your parts store,give them the full model number and they will send you the correct part,if the start device is good,there's also a computer board in this machine part W10446514 and it's around 90 dollars.hope this helps you out and good luck.
Jun 02, 2012 | Whirlpool GSS26C4XX Side by Side...
Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water Filter
most whirlpools have the filter located in the bottom kickplate, right below the freezer door. turn counter-clockwise and toward you to remove. if it has never been removed before, they are hard to get out the first time.
Jul 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Removing the water filter and not replacing
Not with out re plumbing the unit underneath, it would be much easier to leave it in place.
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold
Your drain was clogged. look for the drain funnel then remove the dirt.
Jun 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GSS26C4XX Side by Side Refrigerator Logo
19 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
