Question about Zefal Bicycle HPX 3 Road Frame Pump
Zefal hp x owner's manual - Zefal Bicycle HPX 3 Road Frame Pump
How do you attach zefal z console to bike?
After a call to the customer service people who were more confused than I was, I figured out how to mount the bracket to the handle bar. Believe it or not the Zefal guys did not have an instruction manual on the product they sell. So here is how it works... You have to run the hard plastic strap around the handle bar and push it into a gap between the plastic nut . It's such a small gap that you will have award time finding it. Once you tighten the plastic nut the strap will advance slowly until the end will come appear on the other side. That's all there is to it. Now why the heck could they not put a picture of this on the box? Perhaps job security for the Zefal guys?
Jun 11, 2012 | Zefal Cycling
How to attach zefal z console
Linda, I was having problems with the installation also, but my husband finally figured it out. Just start the end of the strap at the screw, as you tighten the screw with the Allen wrench it will thread the end thru and will get tighter around the post of the bike. It works perfectly and now I can use the GPS on my iPhone to record my rides. Hope this helps!
Need to download owner's manual for HP Officejet J3640 All-in-One. Can you help?
Welcome to Fixya.
Here's where you can view and download the user's guide :
HP J3640 User's Manual
Just choose your language of choice, then click on "User's Guide" to view/download.
Thanks for using Fixya.
Jun 08, 2011 | Office Equipment & Supplies
I need the Owners manual for the HP Compac nc6000
Hello. By accessing this LINK you will be able to view the owner's manual for your HP Compac Nc600. I inform you that the link above contains a pdf. file.
I hope I helped you!
If you have any other questions, please leave a reply!
Thank you for using FixYa!
May 24, 2011 | Compaq Computers & Internet
I can't get my Zefal pump to seal onto my Pestal tires. The pump head constantly pops off. Do I need to return the pump?
If it is a dedicated presta pump, there should be a threaded cap on the head where it attaches to the valve stem - it has a hole through it to allow the stem through. Tighten that stem slightly and it should compress the rubber enough to hold on. But don't tighten too much or it will be hard to get off.
The head holds on with a rubber donut under that cap. By tightening the cap, the donut gets compressed and closes the hole tighter.
Oct 17, 2010 | Zefal Cycling
I have a Zefal HP frame pump. I'm trying to inflate a tire with a Presta valve. It just won't inflate. It doesn't latch onto the valve and seems to big for the valve body. Is there a diagram available...
Let's hope you didn't force it and snap the plastic point off.
Most Zefal pumps come with a reversible head that can adapt to either Presta or Schreader (like on cars). You unscrew the barrel at the working end of the valve, carefully tap out the rubber cylinder and the plastic internal piece behind it.
Insert the plastic piece in either of two ways. Pointy part Out (for Schrader) or just a round opening Out (for Presta). Rotate the rubber piece correspondingly to show the large opening for Schrader or the smaller opening for Presta and place it inside the valve over the plastic piece. Screw the knurled barrel on tightly.
Aug 12, 2010 | Zefal Bicycle HPX 3 Road Frame Pump
I need the owners manual for a Guardian Power drill press Model# FDM-58-16S........Help...................
I'm looking for a Owner's Manual for a 16 speed, 1/2 hp, Heavy duty Guardian Power drill press.
Apr 17, 2010 | Drills
Zefal Bicycle HPX 3 Road Frame Pump Logo
54 people viewed this question
Top Zefal Cycling Experts
John Egan
John Egan
Are you a Zefal Cycling Expert? Answer questions, earn points and help others
