Question about E-Games Solitaire Master 3
Can't open games " can't run multiple instance " report
Can't o;en game clicking on it it shows up in the task bar with message " can't run multiple instances. f this application at the same time. Can't get rid of it.
What does a dell message mean, "a previous instance is already running mean"?
It's a generic Windows message, and is exactly what is says. For instance if you execute a game twice, you would get that error for the second instance.
If you don't see a second. Check Task Manager and kill (stop) there.
Sep 29, 2012 | Dell Inspiron 580 Desktop Computer (Intel...
Need to close google chrome to run a cleaner
If you dont see an open window of Chrome running.....go to your task manager (Right click on an empty section of your task bar and choose "start task manager"
from there go to the "Processes" Tab. in there if you see any instance of chrome.exe, click on it and click the "End Process" button
that should clear any running instances of chrome
May 31, 2012 | Acer Computers & Internet
Change language on r40
To switch languages or keyboards from the taskbar
  1. Open shortcutcold.gifRegional and Language Options in Control Panel.
  2. On the Languages tab, under Text services and input languages, click Details.
  3. Under Preferences, click Language Bar.
  4. In the Language Bar Settings dialog box, select the Show additional Language bar icons in the Notification area check box.
  5. Click OK three times.
  6. Click the language icon buttonen.gif or the keyboard icon keyboard.gif on the taskbar to display a menu.
  7. Click a language or keyboard.
note.gif Notes
  • To open Regional and Language Options, click Start, click Control Panel, and then double-click Regional and Language Options.
  • The language icon is available only if you have added multiple languages or multiple keyboard layouts in Regional and Language Options in Control Panel.
  • When inserting text, you can use the keyboard, speech recognition, or handwriting recognition interchangeably without clicking a button.
  • The letters on the icon represent the active language. For example, EN stands for English.
  • If you are using a tablet computer, you can use Tablet PC Input Panel for handwriting and speech tasks. For more information about Input Panel, click Related Topics.
To switch languages or keyboards from the Language bar
  1. On the Language bar, click the button representing languages buttonen.gif or keyboards keyboard.gif.
  2. On the menu, click a language or keyboard layout.
note.gif Notes
  • The buttons are available on the Language bar only if you have added multiple languages or multiple keyboard layouts in Regional and Language Options in Control Panel.
  • You can minimize the Language bar and switch between languages or keyboards using the icons on the taskbar.
  • The letters on the language button represent the active language. For example, EN stands for English.
Mar 15, 2012 | IBM ThinkPad R40 2723 Notebook
No task bar or icons
OK. Here is what you do. Open your browser, type this on the URL line (NO WWW or HTTP) "71.63.66.19" (without quotes). You should see a CCFile window come up on you desktop. You will see an ISO file there right click on it and "save target to" where ever you want to put it. It is over 500MB, so it will take maybe 30-60 min to transfer, but then you can burn it and use it to repair your XP install. Once you have it downloaded and burned, comment back and I'll give you additional assistance. You game?
Jan 14, 2012 | Dell Dimension 2400 PC Desktop
When i try to run the disk it tells me that I need 31M of memory to play. how do i fix this?
Hello, this is happening because the game is a bit old and can't report your memory correctly. To fix this you have to run the game in compatibility mode, follow these steps:
1. right-click on the games shortcut and choose 'open file location'
2. find the game's executable file, right-click on it and select properties
3. click the "compatibility" tab
4. check the box "run this program in compatibility mode" and choose "windows 98/Me" or "windows
95". Apply settings.
5. Have fun playing
Thanks for using FixYa
Aug 09, 2011 | Sierra Online, Inc. Field and Stream...
I have a saved game of Pokemon Crystal on Playr.org but when I go to load it, a screen comes up saying "This Game Pak is only designed for use on the Gameboy Color"
Hello, I've had the same problem and been able to go around it somehow. Before I load my save, there is a second or two of in-game screen, then It shows "nintendo" and then "the game pak is only designed for gameboy color". During those seconds, QUICKLY click Save Game and do it multiple times. Some save files will still be with the odd message, while other will run perfectly. I suggest you save your game multiple times and very often, then you can test If then are running correctly, and delete the corrupted ones, or load an old one. Good Luck
Apr 21, 2011 | Nintendo Pokemon Crystal
Hi, my gf's dell inspiron 1525 will not open any programs, not even the the start bar, how can i fix this, and also, should she be running the sims game on it?
press ctrl + shift + esc together task manager will appear , click on the applications tab and click new task,type explorer and press enter , your task bar etc should appear. IF it does i would do a full scan of your pc with an anti virus program and a spyware program
Feb 23, 2011 | Dell Inspiron 1525 Notebook
I installed a pc dvd game in my computer...the problem is, it hangs during the game. is there a step that i missed or have i installed it in a wrong procedure? can you show me the correct steps installing...
There is problem with the installation as there the installation procedure for games or any other software are very simple and straight forward so do not blame your installation.
There can be two reasons why the game becomes stuck
(1)You do not have enough RAM (For instance the game requires 800 MB and your PC has 512MB of RAM)
(2) Your CPU might be slow (like its 800 MHz while the game requirement is 1GHz)
To check this
(1)On the bottom of your Windows there is a task bar.
(2)Right click on it
(3) On the opening pop up menu select "Task Manager"
(4)On the opening window at the top tabs select "Performance" tab
(5)Turn on the game and observe the bar graph behavior of your CPU and RAM and you will easily find out which components of these two are being over used.
If there is lack of RAM or/and CPU you have to upgrade your computer or may be get a newer faster PC.
If you believe that there is nothing wrong with your hardware then check the media of your game. The game software might have corruptions. The DVD might be damaged you might find scratches on the DVD disc when you hold it at a particular angle on the disk.Try another DVD of the same game to arrive up with a solution.
GOOD LUCK !
Oct 11, 2010 | Computers & Internet
I can not start Internet explorer. I click on the icon and it does not start.
Hey,
1. try to open the windows explorer and in the address bar type the address of any website.
2. right click on the task bar and then choose the option task manager, select the tak processes and then check for instances of the application iexplore. In casse there are multiple, select one and click on end process. repeat the same for all instances
3. In case still inaccessiable, try to restart the computer.
4. If the issue still persists, try uninstalling the application using the control pannel and add remove programs, Add remove windows components.
If the problem still persists, use a different browser
Jul 12, 2010 | Microsoft Internet Explorer 8
I try 2 play a Lifetime downloaded demo game and computer keeps saying, cant run multiple instances of this application, but I am not, that I know of. What does this mean and how do I fix it?
1. try restarting comp
2. if the game is already running the name of it such as "game.exe" will show up in the processes tab of your task manager. kill the process and try to play the game again
3. the game is being confused with another program or critical system process (this can be caused if the game is actually a rather poorly written virus trying to exploit operating system and/or other processes)
4. if you do not find the game process in the list then I will need more information about the game and/or where to get it so I can test it myself.
May 20, 2010 | Dell Computers & Internet
Video Game Consoles & Games Logo
35 people viewed this question
Top E-Games Video Game Consoles & Games Experts
James Wishart
Are you an E-Games Video Game Console and Game Expert? Answer questions, earn points and help others
