Question about MGA Entertainment Bratz TV
Sound but no picture
We recently ordered a bratz tv, model 309321, and it has sound but no picture. We are wondering if maybe the picture tube got messed up during shipping. If anyone has any ideas, please let us know. My daughter is upset that her Christmas present did not even work.
  • MGA Entertai... Master
  • 19,396 Answers
Try using the input selector, and also try unplugging TV from main , waiting ten minutes, and plugging back.
If this does not work, then there is an internal fault. Probably the unit has been damaged during shipping.
In that case contact immediately the seller and ask a replacement.
Posted on Jan 27, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Since the unit is new, the normally suggested option is to seek warranty repair.
If however you would like to perform some checks of your own, then visual inspection is required. This would mean removing the rear cover with the unit unplug and looking over for anything out of the ordinary. Common jarring problems are:
  • detached rear PCB (printed circuit board) from the pins of the very rear of the CRT;
  • loose connector(s);
  • mis-aligned, dislocated, warped or punctured main board.
Pls exercise caution as all TV units retains electrical power even when unplug for some time.
Inidentally, the only probable physical damage that the CRT could sustain while in transit would be a broken neck. However in most instances, there would be slight circular discoloration on the front screen.
Pls post back updates. Good luck and thank you for using FixYa.
    President:
  • 1,990 Answers
Welcome to Fixya! That is Exactly what happened. The only Solution for repair would be an Exchange as Repair would cost as much as the TV did. Please Rate my Response, I need all the Help That I can Get! Thanks!
  • 15,935 Answers
Yes, the CRT tube has failed, please return it under warranty.
What are the universal codes for mgm entertainment. bratz tv/dvd model number 309321
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Oct 10, 2015 | Televison & Video
We recently adopted a Akai TV model PT50DL24 and the sound and the picture is fine but very very dark. I tried adjusting contrast, colour,and brightness but remains a very dark picture. Please help!!
Tv have a word "LAMP" on it front face frame bazel?Yes,than this tv model have a projection lamp it is dying requirement of the projection lamp replacement.Tv can be save.Not no "LAMP" word on it the front bazel frame.Not repairable,because it is using CRTS-tv tubes tech.Sorry it is garbage tv time,those CRTS tubes are dying,not worth replacing and cost almost the same as a new tv itself,if u can buy it refurbish CRTS tubes anymore all.
Jun 07, 2011 | Akai PT50DL24 Television
Sony KP-51WS500 lossed it's green color...
FIRST YOU NEED TO LOOK INSIDE THE UNIT FROM BEHIND WITH THE COVER OFF AND SEE IF THE TUBES ARE LIT. AT THE BOTTOM OF THE TUBES BY THE CIRCUIT BOARDS, SEE IF ALL 3 ARE GLOWING ORANGE,(FILLAMENTS). IF THEY ARE ALL THE SAME THEN LOOK INTO THE LENSES AT TOP AND SEE IF THERE IS ANY LIGHT INSIDE. THESE SETS ARE COMMON TO HAVE BAD SOLDER CONNECTIONS ON THERE CRT BOARDS. EITHER LOST THE FILLAMENT CONNECTION OR LOST THE VIDEO DRIVE SIGNAL. LET ME KNOW, WE CAN GO FROM THERE. CAN YOU USE A SOLDERING IRON?
Dec 27, 2009 | Televison & Video
No picture, no sound
sounds like the main board maybe going out or is gone and the lamp may have went as well
Jul 20, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a bratz tv model # 263371 i need a remote control for it
try going to toys r us or where u got the tv and get the model remote
May 31, 2009 | MGA Entertainment Bratz TV
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Phillips model # 9P5034C101 Projection TV picture tube
I have a Philips 50 inch rear projection when I power up I have no sound or picture is it done or fixable?
Feb 13, 2008 | Televison & Video
Picture and sound went out suddenly on a Sony KV-35S40
sony has problem with bad picture tubes as well as flyback transformers .if you have shorted hori output then replace it if set shorts it out again your looking at bad flyback transformer as well as maybe leaky tube.
Oct 27, 2007 | Sony KV-35S40 TV
MGA Entertainment Bratz TV Logo
21 people viewed this question
Top MGA Entertainment Televison & Video Experts
Electro Med Services...
Are you a MGA Entertainment Televison and Video Expert? Answer questions, earn points and help others
