Question about Microwave Ovens
Microwave will not heat anything
The fan works, the turntable works, but will not heat anything.
Can not find user mannual
  • 52 Answers
Inside the unit there is a fuse that protects the power circuit, replace and all should be well. check all other fuses at same time
Posted on Feb 21, 2009
Doesn't heat anything
It sounds like the micro generator has died.
Yes, you should buy a new one as the cost of repair is likely to be high.
Jul 01, 2010 | Amana ACO1860 Microwave Oven
Not heating
If the oven is doing everything else properly (light comes on, fan runs, turntable goes around) but there's no heat, you may have a failed magnetron tube (the microwave source). There's also a relay that controls power to the tube that may not be working correctly, or the control circuit board is bad. It's also possible one of the door switches is not working (so the oven thinks the door isn't closed), although this usually keeps the turntable and fan from running.
Microwave oven service is not for do-it-yourselfers. There are potentially deadly voltages present even with power off, and a chance of microwave leakage if repairs aren't done properly. Let a professional give an estimate to repair it, or just replace it if it's under $100. (When I was servicing these things it wasn't unusual for a repair to cost over half the price of a new one. That's one of the reasons so few shops still work on small appliances.)
Jan 31, 2010 | LG MV-1444Y Microwave Oven
Light, turntable and fan don't work
Possibly the light bulb has blown, which has blown on a track on the board which has taken out the turntable motor and the fan. Also, there could be a problem with the door switch.
Mar 27, 2009 | Panasonic Microwave Ovens
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Jun 20, 2007 | Sharp R-1490 Microwave Oven
Microwave Ovens Logo
63 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
