Question about Dell Latitude D610 Notebook
Having trouble turning on my laptop
I installed a new hard drive on my Latitude d610, and now I am having problems turning it on. Sometimes I have to push the on botton several times before I can get it to start, once it's on I have no problems with it. It's fustrating because I'm not sure if it needs a new switch or maybe something got mix up when I installed the new hard drive. The Old Hard drive was Hitachi Travelstar Model # HTS548080M9AT00 80gb The New Hard Drive is a Hitachi Model# HTS541616J94T00 160gb I hope this helps.
  • 2,229 Answers
Installing a new hard drive has nothing to do with the power switch. It may have become dirty or worn, but I would recommend that you hold it in just a little while when turning it on. That should work.
If, as you say, everything works once it's on, then your hard drive installation is not at fault.
If the problem gets worse and the computer finally doesn't start at all, then perhaps you have a problem with the switch and you'll have to deal with that--many times this means a new motherboard (unfortunately).
Posted on Jan 31, 2009
Error code 1000-0146 on dell d610 even with new hd
format ur harddisk using windows 98 bootable cd in D610 this will definately help u
Jul 07, 2012 | Dell Latitude D610 Notebook
I just bought a Dell DHS computer without a harddrive at a yard sale, how do I install a hard drive for it
First you have to make sure you bought the right kind of hard drive (IDE or SATA) to make the installation and connection easier. IDE drives have a set of prongs or pins that stick out. SATA is the later type and does not have prongs or pins sticking out. You just turn the laptop over and remove the cover where the hard drive will be housed. Usually it will have an icon of 3 circular discs on it. Most laptops will also require a Caddy that the drive sits in before it goes into the laptop. And some might require a interface.
I suggest you look on ebay and see if your computer's make and model requires a hard drive caddy or interface.
http://www.ebay.com
In the search box just type your computer's make and model followed by hard drive caddy. Example: Dell Latitude D610 Hard Drive Caddy
In the search box type this is see if it requires an interface: Example: Dell Latitude D610 Hard Drive Interface
May 20, 2012 | Computers & Internet
I got a new cd dvd rom drive for my dell latitude d610 and it is not working it does not open
it must not have been installed properly. Check the device manger to check whether it registers & if so update the driver
Dec 16, 2010 | Dell Latitude D610 Notebook
Dell latitude D610 drivers
You didn't say what the problem is, but if you're looking for the drivers you can go here and find all the ones you need and see which ones might need updating - http://supportapj.dell.com/support/downloads/index.aspx?c=sg&cs=sgdhs1&l=en&s=dhs
If you're having problems with your drivers, you should have a program called "Dell Quickset" or something similiar from Dell that should be pre-installed and it can do scans on your system to see what could be wrong and/or see what you might need.
May 20, 2010 | Dell Latitude D610 Laptop Computer -...
My Dell D610 starts and operates properly, but completely locks up after about 10-15 minutes. I let it cool, and it will start again. I have checked and the fan does run. I cleaned the area around the fan...
you can download this to see if it is getting really hot first.
http://www.diefer.de/software/i8kfangui31.exe
after you install it you can go into the settings and turn on the monitors for the cpu, gpu, ram, and sometimes the hard drive. you can turn on the fan monitors too to make sure they are working. you can control the fans as well. i use it on all my dell laptops. it its not freezing becuse of overheating then it might be the hard drive or you might need to reinstall windows
Apr 26, 2010 | Dell Latitude D610 Notebook
Dell latitude d610 DST Short Status Test 1000-0146 and 1000-014
you might have jarred the memory loose. take it to a local technician to have them check it out.
Oct 10, 2009 | Dell Latitude D610 Notebook
Dell latitude D610 laptop
You may be using the wrong USB port for the device.
Try disconnecting the USB device, restart the unit and use the rear USB port.
It sounds like you are having a conflict with one of your devices. example: using two mouse, USB2 device, running on a USB1 supported port, external Hard disk or drive setting not configured correct.
If you are still having problems, check the BIOS setting and reset to default. Save and restart unit.
Next, check your device manager for flags.
If you see anything outstanding, remove it and reboot.
Once completed, try the USB port and see if your device is usable.
Next time you may want to list the device and your operating system used, to help the tech understand your problems.
Hope this helps you.
Sep 26, 2009 | Dell Latitude D610 Notebook
Trouble Turning on my labtop
The power button is simply a push stick to the circuit board underneath. Remove the bezel by prising it up on the right hand side. You can then press the button underneath to determine if the problem is with the bezel or the circuit board. Usually the problem is that the bezel button is broken or has lost is springyness. A new bezel can be purchased on Ebay for around £5.
Jan 11, 2009 | Dell Latitude D610 Notebook
Upgrade Notebook hard drive capacity
hi there,
you Dell Latitude D610 can support large hard drives from 100gigs up to 250gigs ... but i very much think this is the limitation of your system bios if u are looking to go higer ... u might need to upgrade your system bios.....
Apr 07, 2008 | Dell Latitude D600 Notebook
Dell Latitude D610 Notebook Logo
98 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
