Question about Audiovox Projection Clock Radio
How do You adjust the time on the Audiovox projector part of the clock
The clock has reverted back to summer time how can I change the time
you can adjust the clock on the Menu
when you turn on the projector
Nov 02, 2014 | Epson ELP LP52 - projector lamp
When I set the clock, the time does not match on the projector.. how do I set the time for the projector?
Go to this page: http://www.homedics.com/soundspar-auto-set-clock-radio-with-time-projection.html
and post your question on the manufacturer page
Feb 11, 2013 | Homedics SoundSpa Clock Radio with...
I recently purchased an Audiovox Clock Radio CR20 from the USA on a visit to that country. I am back in my home country India and started using the clock radio. I find that the clock is not keeping correct...
The reason of your problem is that your local mains frequency is 50 Hz and when you use 230V to 120V converter, this simple device can not convert frequency only the voltage. Your clock is synchronized to the mains frequency which is 50 Hz instead of 60 Hz and the clock goes slowly. It is late (60-50)/60 ---> 10 minutes in every hour.
I am sorry but I think your problem can not be fixed. ( It would be possible to convert the frequency but the cost of this kind of device would be higher than the value of this Audiovox)
Thanks.
gylacz
Aug 10, 2011 | Audiovox Audio Players & Recorders
My oregon scientific projector clock keeps changing time, I think it might be something to do with the time zone. I do not know what a time zone is?
A time zone is section of the country that adjusts for daylight savings time. The United States is composed of four time zones - Eastern, Central, Mountain, and Pacific. Each county is assigned to one of the four time zones. See the attached map to see which time zone you are in. Then you must set up your clock to match that time zone. bblue1967191.jpg
May 03, 2011 | Vacuums
Audiovox iPod Clock Radio - (CR8030iE5) looking for a manual online
Press the start button (1st button on the left) to standby and the color is dimmed when standby. Then press the function button until the time will start blinking. Then, press the hour and the minute buttons to the desired time. Press the function button again until the blinking stops. Press the start button again to the desired format (radio, ipod..) and you will notice that the time had already been changed. Hope this helps rather than paying $5 for such a request.
Apr 27, 2010 | Audiovox (CE256) Clock Radio
I can't set the time on my car stereo ,How do you set the time on a jensen mp 5720
7. Clock
CLOCK DISPLAY
Press the DISP (16) button to show the clock in the display. The clock will display for a few
seconds and then return to the previous display.
CLOCK ADJUSTMENT (TIME)
Press the DISP (16) button to show the clock, and then press the DISP button again and hold for
> 3 seconds until the clock flashes. Press the DOWN TUNING (<<-) button (18) to change the
minutes and UP TUNING (+>>) button (17) to change the hour. Continue changing the hour to
move between AM and PM.
Here is a link to the manual where this text cam from:
http://www.audiovox.com/manuals/owners/MP5720_123103_FINAL.pdf
Jun 01, 2009 | Jensen MP5720 CD Player
Clock
don't know if you fixed your clock. but you nned to turn on the radio .leave the tv in. press and hold display button till time blinks. use the enter button on radio. move it left or right for the hour up and down for the minute
Jan 17, 2009 | Audiovox PAV-1510DTV Car DVD Player
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
AUDIOVOX CDA 100 AM/FM/CD setting clock
SETTING THE CLOCK - AUDIOVOX CDA-100
  1. Turn the vehicle ignition and radio "on".
  2. Press and hold the Time/Frequency Selector button approximately 2 seconds until the time display begins flashing on the display panel.
  3. Within 5 seconds after the time display begins flashing press the Manual Down Turning button (<<) to adjust the hours and the Manual Up Turning button (>>) to adjust the minutes to the correct time.
  4. Five seconds after the last hour or minute adjustment is made, the time will be set in the unit and normal operation can resume.
Contact Audiovox.com or 1-800-688-3135 and they will email (PDA) or fax a copy of the manual.
Oct 17, 2007 | Audiovox AM/FM/DVD/CD/MP3/WMA Receiver...
Audiovox Projection Clock Radio Logo
Top Audiovox Audio Players & Recorders Experts
John
John
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
